Question about Swimline Blossom Triple Tier Floating Fountain
NO PROBLEMS, JUST WANT TO PURCHASE ONE EXTRA HOSE
No problems just want to purchase one extra hose P 36749 four elbow pieces P 36773 foru clamps P 36889. Please advise where I can purchase these items and the prices. Thank you
  • 8,404 Answers
FixYa.com is not a store. Please go to your pool supplier for these parts.
Thank you
Posted on May 16, 2010
How do I properly hook up the metal tubing to vent my dryer?
-There are many way to connect it. You can use
big hose clamp about 5" Diameter, or connect together then use 2 screws and then use duck tape over to seal any gap.
Good Luck
Mai Lor
Nov 12, 2014 | Dryers
How do I put a 90 degree elbow on the outlet pipe for a DLG0452W. I want it to exit at the prepunched factory left side exit.
you can do it either by cutting down the pipe inside the dryer,stick an elbow on the inside and run your pipe off of the elbow or cut the pipe and attach flexable vent line to the pipe and run that out of the dryer,or if you want to keep the pipe in case you change the dryer around in the future,remove the pipe from the blower wheel housing,buy another piece of hard pipe,cut it down and install it where the other pipe was,stick an elbow on it and either run hard pipe or flex line,use either hose clamps or the silver high heat tape to connect pipe,don't use duct tape it drys out and falls apart.hope this helps,it's kind of basic,just cut the pipe there or use another piece of pipe,cut it so when you put the elbow on it it will line up with the hole in the side.
Oct 08, 2013 | LG DLG0452W Gas Dryer
Replacing the drainage hose on Asko dishwasher
Lay it down there is no bottom.
Mar 05, 2013 | Dishwashers
Culligan n8 black hose fell off and water was flowing out until i turned off the valve how and where do i re attach thx
If the "black hose" is about 1/2" in diameter it attaches to the drain elbow on the left side of the valve. Use a hose clamp, cut some of the drain line back (about 2") slide it back on the drain elbow and clamp it on the elbow.
If the black hose is 3/8" it attaches to the fitting on the salt tank, which attaches to the float.
If it broke because it is brittle I would go to any water treatment dealer and get a new piece of "brine line" to replace it.
RJ
Oct 10, 2011 | Culligan Under Sink Water Filter
I own a 2004 Buick Rendezvous, its a 3.4 liter engine and it's leaking coolant from an elbow on the engine firewall, on the passenger side. It only happens when the heater or the a/c is on. Would you...
That elbow goes to the heater core. Just go to a auto parts store, and ask them for a new elbow, remove and replace and everything will be just fine. The heater core controls the heat and cooling for the cabin of the vehicle.
Is there any fluid leaking onto the floor of the passenger side of the vehicle?
May 29, 2011 | 2004 Buick Rendezvous
Behind the water pump it leaks antifreze its not the water pump but the hose from the radiator hook up to this metal tube and goes to the water pump that join is leaking does it have a gasket in between or...
you talking about water pump bypass heater pipe the metal elbow piece to the water pump hosing.the metal elbow piece is held in place by small bolt or bolts you should have either gasket or o ring betwween where metal elbow mounts to water pump housing.replace the hoses also.some times the hose will be leaking not gasket or o ring at the metal elbow.make sure screw or screws not loose or missing to the metal elbow pipe.
Apr 17, 2011 | 1997 Geo Metro
How do you change out a heater hose elbow in a 2005 buick lacrosse
cool car down and drain the radiator, usually a spigot or valve at the bottom. remove the clips or clamps holding the hose on, pull hose off. get a new hose from any parts store, sometime helps to have the old one with you. install new one, put on new clamps and tighten firmly, pour in new coolant. check your owners manual to see what kind of coolant Buick recommends.
Oct 04, 2010 | 2005 Buick LaCrosse
This is no joke, I can,t fine where my thermostat is in my 1997 merc sable, ,i even followed the top hose back to the engine block
if you follow the "upper" radiator hose from the radiator to the engine it should have a metal piece that bolts to the car ( usually with only 2 bolts) and also the hose is clamped to it. it most likely has a domed shape to an elbow looking piece. take the "upper " radiator hose from where it connects to the engine. remove the bolts that hold this metal piece to the engine that you just took the hose off of. the thermostat "should" be located under this piece. you must take that metal elbow thing off from car to access the thermostat. where it bolts to the engine it most likely will have only 2 bolts and where that connects to the engine will be a gasket and it will be kinda football shaped. a lot of cars will also have a brass flat screw on top of this domed shaped elbow. that will be the give away to that that is where it is. what you do is when the car is running and the coolant starts to get warm, you back out the brass screw a little. this will let the air escape thats trapped and when coolant starts to escape tighten the screw back down. now you have the air out of the system after youve replaced the thermostat. I hope this helps....
Jun 13, 2009 | 1997 Mercury Sable
2000 zx2 escort, zetec engine, need a elbow piece
I'm sure you've solved your problem by now, however your best bet is a junkyard.
Mar 29, 2009 | 2001 Ford Escort ZX2
Whirlpool dishwasher leaks everywhere
CHECK YOUR HOSES FOR CRACKS. BE SURE THEY ARE ATTACHED SECURELY TO THE PUMP OULET.
THERE IS ALSO A BLACK HOSE FROM THE VALVE THAT GOES UP THE LEFT SIDE TO A VACUUM BREAK ON THE SIDE OF THE TUB. BE SURE THE HOSE HASN'T BEEN DAMAGED OR DISCONNECTED. IF THERE IS SUFFICIENT SUPPLY HOSE, PULL THE DISHWASHER OUT OF IT'S INSTALLATION AND TURN IT ON. WATCH FOR WATER DRIPPING ON THE FLOOR AND TRACE IT BACK TO FIND THE PROBLEM.
Mar 25, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Swimline Blossom Triple Tier Floating Fountain Logo
91 people viewed this question
Top Swimline Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Swimline Pool and Spa Expert? Answer questions, earn points and help others
