Question about Bladez Ion 9.9 Fold-up Treadmill
Where is the speed sensor connection for a blade z
Where is the speed sensor connection located for a blade z treadmill
    President:
  • Bladez Master
  • 832 Answers
Their is two place any of the treadmill either on the frame by the front roller/ pulley or on the motor itself by the fly wheel or the opposite end.
Posted on May 18, 2010
2 Suggested Answers
bwinton
  • 83 Answers
SOURCE: Where is the speed sensor connection for a blade z
The speed sensor is under the motor cover next to the front roller on the user left side.
Posted on Mar 24, 2010
Testimonial: "This was vey helpful. I actually found it after talking with the person I bought the unit from . Thanks for following up. "
Precore 9.31 error 23
Precor Error Code 23 Error Code: 23 Manufacturer: Precor
Model: All Models
Error Description: Error 23, Motor Pulses Missing after Start Up - Indication that the speed sensor signal was lost while the unit was in operation. Possible Reason:
  1. The line of sight between the speed sensor and the speed sensor target is obstructed.
  2. Incorrect gap between the speed sensor and the speed sensor target.
  3. Incorrect adjustment of the speed sensor potentiometer (when equipped).
  4. Intermittent connection of speed sensor or drive motor wiring.
  5. Badly worn drive motor brushes not able to make proper contact with drive motor commutator.
  6. Faulty lower PCA.
  7. Faulty interconnect cable between upper and lower PCA.
  8. Faulty upper PCA.
Recommended Action:
  1. Using a static safe vacuum cleaner, carefully vacuum out the drive motor compartment. Be sure to thoroughly clean the area between the speed sensor and the speed sensor target.
  2. Inspect the gap of the speed sensor to the speed sensor target. Proper gap is 3/16" and the speed sensor photo eye should be aimed at the larger portion of the targets wedge shaped section. If unit has a magnetic speed sensor, the gap between the end of the sensor and the flywheel tooth needs to be 3/16".
  3. Locate the speed sensor potentiometer (when equipped) on the lower PCA. Set the speed sensor potentiometer to mid-range. Start the treadmill and increase speed to 6 mph. Carefully adjust the speed sensor potentiometer until the treadmill is operating the smoothest. Increase the speed to full speed and again adjust the speed sensor potentiometer until the treadmill is operating the smoothest. These two adjustments are typically small and are generally only a matter of fine tuning.
  4. Test all wiring and wire connections of the speed sensor and drive motor. Replace or repair necessary wire connections or wiring.
  5. Inspect and replace drive motor brushes if necessary.
  6. Determine if the lower PCA is bad by swapping with a known good lower PCA.
  7. Determine if the interconnect cable is bad by swapping with a know good cable.
  8. Determine if the upper PCA is bad by swapping with a know good upper PCA.
Jan 25, 2014 | Precor Exercise & Fitness
TX 5.0 RC just stopped a # 3 came on the screen. After reading several posts we looked at a wheel within the motor compartment(not the wheel with the belt, it's the wheel to the left if your looking...
Info from PDF files located on Sportcrafts website under manuals.
E3 - No speed sensor reading. Unit shuts down. This is the most difficult repair diagnose. The speed
sensor is connected to the frame of the treadmill near the drive pulley on the front roller. There is a
small magnet on the side of the pulley wheel. The sensor tip must be no more than 5mm from the
magnet. If for any reason the distance is greater than 5mm the treadmill will shutdown
Adjust or replace speed sensor.
Treadmill: Speed Sensor Replacement
1. Make sure your treadmill is unplugged before you begin.
2. Remove the motor cover located in the front of your treadmill, it is held on by a few screws.
3. Locate your speed sensor; it is the small T shaped part with a red and black wire coming from it.
4. Remove the 2 screws in the speed sensor and remove the old sensor.
5. Place the adjustment holder on the frame with the open holes facing the pulley wheel, the prongs facing
up and way from the pulley wheel. Insert the screws but don't tighten fully.
6. Now place the speed sensor over the prongs with the square part facing the pulley wheel and the red and
black wire to the far right.
7. Plug the treadmill back in and slide the speed sensor until it is 5mm from the magnet inside the pulley
wheel, you may have to do this several times until you can position it so it no longer shuts down. Use 2
nickels to figure out the spacing. The width of 2 nickels is 5mm.
8. Once you find the correct position tighten the screws all the way; being careful not to touch any of the other electronics
9. Place the motor cover back on and enjoy your machine.
Also:
Use an epoxy to glue it. It is a plastic that is difficult to adhere to.
Jan 22, 2013 | Sportcraft Tx5.0 Tx 5.0 Rc Treadmill Motor...
Nordic track treadmill stuck on highest speed
Adjusting the speed sensor:If the calibration does not pass you may need to check the speed sensoralignment.1) Remove the motor cover hood by loosening the 4 screws that hold it inplace (you do not need toremove them completely).2) The speed sensor is located on the left side of the frame, right nextto the front roller pulley (thepulley will have a belt around it that also goes to the motor). Thespeed sensor is small and blackwith a wire connected to it.3) Make sure the sensor is as close as possible to the pulley withouttouching it. You will see a magneton the face of the pulley; make sure the sensor is aligned with themagnet. There is a screw thatholds the sensor in place that needs to be loosened to adjust thesensor. Re-tighten the screw whenfinished.
sincerely.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Oct 09, 2011 | Nordic Track NordicTrack Commercial 1500...
Nordic track treadmill stuck onfull speed
GOOD LUCK.SINCERELY
Where is the sensor for reading speed and mph
The speed sensor is located on the frame next to the front roller pulley. It will be clamped to the frame on the left side of the treadmill under the motor cover.
The pulley has a small round magnet mounted to it. It may have come loose and attached itself to the metal frame of the treadmill. Check for the magnet, and position the speed sensor as close to the pulley as possible without making contact.
If the speed still doesn't work, replace the speed sensor.
Jan 02, 2011 | Treadmill Doctor Proform 525 Si Treadmill...
E2 Code on Treadmill after starting
This is a speed sensor error. Unplug the unit then remove the motor shroud locate the power board with LED lights plug in unit locate the 5v DC if this is on then replace the speed sensor.The sensor is located on the frame by the front roller pulley or on the Drive Motor itself. Call IconFitness @ 1800-999-3756.
Jun 26, 2010 | York Barbell Home Use Fold-Up Treadmill
Where is the speed sensor connection located on the treadmill?
Unplug unit the remove motor shroud most sensors are next to front roller/pulley assembly it will be either a black rectangular or cylindrical (reed switch) component adhere to the frame or locate on either end of the drive motor.
May 14, 2010 | Bladez Ion 9.9 Fold-up Treadmill
Mar 22, 2010 | Bladez Ion 9.9 Fold-up Treadmill
Track will only turn for a few seconds when turned on and then quit
E3 – No speed sensor reading. Unit shuts down. This is the most difficult repair diagnose. The speed
up and way from the pulley wheel. Insert the screws but don’t tighten fully.
Feb 19, 2010 | Proform Exercise & Fitness
TX 4.9 sportcraft treadmill
Aug 13, 2009 | Exercise & Fitness
Bladez Ion 9.9 Fold-up Treadmill Logo
205 people viewed this question
Top Bladez Exercise & Fitness Experts
Electro Med Services...
Tom Chichester
qa1012
Are you a Bladez Exercise and Fitnes Expert? Answer questions, earn points and help others
