Question about Hunter Ceiling Fan Control Switch
Three-way switch for hunter ceiling
I have a hunter ceiling fan approx. 15-18 yrs old. The chain pull broke so I changed the 3-way switch. Now the fan only works on high speed and at one spot, the other spots are all off. I have tried 3 different brands of switches. I was carefull to put wires back in same numbered slots on switches. This is the second Hunter fan this has happened with, The first one I just replaced the whole fan. Does Hunter make its own unique 3-way switch?
  • Anonymous Jun 20, 2008
    FAN RUNS AT HIGH SPEED ONLY. REPLACED 3 SPEED SWITHC. DID NOT SOLVE THE PROBLEM.
SOURCE: 3-speed switch replaced with hampton bay switch. Only low speed works.
The cause to the problem was replacing a HUNTER fan switch with a Hampton Bay switch. Before removing the old switch, I noted and marked the color and position of the 4 wires. I then duplicated the connections to the new switch.
But the wire positions of Hampton Bay vs Hunter are not identical, therefore 2 wires
were crossed.
The correct way is to note the color of the wires with the corresponding NUMBER
marked on the switches, then duplicate this on the new one.
Du-uh!
Posted on Jul 24, 2008
hardrocko
  • 1476 Answers
SOURCE: 3 speed Hunter Fan only has 2 speeds
Assuming that the unit was wired properly from the factory and without being able to look at the switch I would have to agree that the switch is bad. The different speeds are obtained by having a different winding for each speed. If the unit was wired properly at the factory and never had three different speeds then the switch is not rotating between all the contacts. The switch should only be a couple of dollars and would certainly be a cheap solution to try. You can check the existing switch by removing it from the circuit completely and checking the continuity with a DMM from the input to each output as you switch it. Continuity should move from one to two to three. If not the switch is bad. If the switch checks out OK then you have a bad winding in the fan and probably need a new unit. Good luck.
Posted on Jul 12, 2006
Crossedwires
  • 44 Answers
SOURCE: Hunter Ceiling Fans
Unfortunatly that is a common thing with most manufactorers now a days! they are not in the service industry. make it, sell it, dump it, make a new one. and the cycle goes on and on. You may be able to find a repair person who can fix the fans for you at a reasonable cost.
Posted on Feb 09, 2008
  • 423 Answers
SOURCE: Check/add oil to a hunter ceiling fan
If you are asking for instructions on checking and possibly adding oil to a Hunter Original fan. Here are instructions:
Check oil level immediately after filling the reservoir. To check oil, bend an ordinary pipe cleaner into a 1/2" long hook and dip it into the oil reservoir.
If oil touches the end of the pipe cleaner, the fan has ample oil. If it does not touch, add SAE 10 non-detergent oil slowly until it touches the pipe cleaner.
-Hunter Original fans rarely/ never need oil unless they were relocated or tipped. ...Or if the fan was improperly installed.
-Hunter sells an oil refill / oil level check kit with good instructions. They also sell a relocation kit that includes the same kit plus all mounting hardware needed.
Good Luck!
Posted on May 05, 2009
SOURCE: Hunter fan/light with remote installed turns on by itself
Many times this is caused by stray frequencies in the neighborhood. And, sometimes changing the frequencies on the remote and receiver reduce the occurrence.
But it sounds like this may not be the case, here. If not, the receiver in the fan is the culprit and should be replaced. No danger, just annoying.
Posted on May 31, 2009
Hunter ceiling fan pull chain for fan broke
First write down which color wire goes in which slot on switch.Turn power off! Disconnect wires from defective switch by inserting a paper clip or something a little bigger into the wire connection.Then press the spring down and release the wire to insert in new HUNTER switch. DO NOT CUT WIRES!Call 1-888-830-1326 with model # to order the correct switch.
Mar 24, 2013 | Hunter (25417) Ceiling Fan
The pull chain came out. how do i fix it?
It's actually a very easy repair. Those pull chain switches are very generic and can be found at home depot or any hardware store for about $3. As far as changing the switch, there should be three screws holding the light fixture to the fan, then one plug will connect the light to the fan. then unscrew the brass cap where the chain broke then cut the wires close to the switch, then there are only 2 wires to wirenut together and there is no incorrect combination to reconnect them.
Sep 09, 2009 | Hunter Ceiling Fan Control Switch
Ceiling fan pull chain connected but does not click on
There is a pull chain switch inside the fan termination housing. you will have to take the little cover off and remove the switch. it has 2 small screws with wire landed under them. Turn off the power at the breaker before working on the switch. take this little ****** out and put in a new one. you can get them at the Home Depot or equivelant. it don't matter if the new switch is a little bigger but it still has to fit. use some judgement here. wire it in the place of the old one, turn the power back on at the breaker and it should be ready to go. Presto.
Aug 16, 2009 | Hunter 20531 Vista Brushed Nickel Ceiling...
Remote does not consistently work
You can include a push chain switch, if theres enough room in the ceiling fan housing. This is a job for a professional electrician or appliance serviceman who is willing to modify an appliance. It will need to be tested for intrinsic safety and the work should carry some sort of warranty since the pull chain modification (if made on the ceiling fan house) will likely void any warranty. Instead, I advise that the pull switch could be intalled elsewhere in the room. However, it still remains a job for a profession electrician who can install the pull switch in parallel with the existing switch.
This would however be able to control all three fans with just one pull switch if you wanted.
May 10, 2009 | Hunter 52" Ceiling Fan With Light And...
Wire diagram for pull chain on ceiling fan hunter original
if you indeed have a 23852 hunter original...
Black goes to L, High is Red, Gray is medium and yellow is low. Make sure you have the right switch.
Mar 21, 2009 | Hunter 23852 Classic Original Ceiling Fan
Hunter Douglas Ceiling Fan Does Not Work
have hunter douglas fan glass globe broke cant find repalcemants i have all the serial no do you no wher i can go to find 91/2 globe
Oct 30, 2008 | Dryers
were crossed.
Du-uh!
Jul 23, 2008 | Hunter 23852 Classic Original Ceiling Fan
Pull Chains Replacement
Replacements are available at Home Depot and Lowes. This is a regular 4-wire single-layer switch.
Mark the old wires, so you know which ports they go to in the switch (marked L, 1, 2, and 3) -- then remove the old wires by pressing a paper clip into the hole of each wire while pulling firmly on the wire. Then just push the wires into the new switch, into the marked holes.
I hope this helps! If you have any more questions, please feel free to ask!
May 22, 2008 | Hunter 22451 The Brookline Brushed Nickel...
Hunter ceiling speed.
A fan that old has a muilti speed capacitor. It could be that or the swicth. First thing to do is test the swicth with a voltage tester to see if power is switched to different posts if it does switch it is prob. the cap. Good luck trying to find one.
Apr 06, 2008 | Hunter Low Profile III 20807 Ceiling Fan
Dryers Logo
210 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
