Question about Maytag MDB8751BWQ 24 in. Built-in Dishwasher
Dishwasher won't drain--Maytag Quiet Series 300
I have checked all the hoses and cleaned out all the drain areas within the dishwasher--it still won't drain at the end of cycle--l;eaving a good deal of water in the bottom of the dishwasher. How can i fix this problem?
  • Maytag Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your problem...
DishwasherDishwasher won't drain--Maytag Quiet Series 300 - 2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Posted on May 15, 2010
2 Suggested Answers
  • 1382 Answers
SOURCE: Dishwasher won't drain--Maytag Quiet Series 300
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Posted on Mar 22, 2010
The latch is sticking on my dishwasher. How can I
replace the door latch and the handle check to see if the console loops that hold the latch are broken if so replace the console
Jun 02, 2010 | Maytag 24 in. MDB9750AW Dishwasher
Mar 22, 2010 | Maytag MDB8751BWQ 24 in. Built-in...
Dishwasher is not cleaning dishes. Dishwasher
One possibility is that there is collection of waste inside the drain pump and filter. If you have cleaned these parts as per instructions in the user guide and there is no difference, then try using a dishwasher cleaner which is available as a liquid in a special dispenser for one off use in an empty dishwasher. This is available in the supermarket.
Hard to know what the plumbing changes were done, but if the dishwasher was taken out and put back in then make sure the drain hose is connected at the correct height. The pump might be working harder than previously which would leave the muck behind.
Dec 17, 2009 | Dishwashers
1.5 year old Maytag Legacy Series Quiet Series 300 Lock Light on
Hold down the heated-dry button for 3 seconds and the light will clear.
Nov 07, 2009 | Maytag 24 in. MDB9750AW Dishwasher
Maytag Quiet Series 300 won't drain all the way. I've checked the drain tubing and there is no blockage. Can someone help?
When you say you checked the drain hose, was top and bottom meaning did you pull out d/w. If you hadn't remove the bottom hose and check the bottom of the hose as well as outlets for the pump, clean out and run through cycle. If you had, then clean out the drain area in the tub of d/w. , should this not work, your pump is not working properly.
Oct 14, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Maytag Quiet Series 300 Dishwasher will not turn off after it com
MY DISHWASHER KEEPS RUNNING, IT IS A WHIRLPOOL GOLD QUIET PARTNER IV
Apr 05, 2009 | Dishwashers
Maytag quiet series 300 leaks from front
check the float switch on the righthand side on the bottom in the corner it should click and move freely
Dec 16, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Maytag Quiet Series 300. The lights flash in sequence starting from the outside traveling inward. The timer counts backwards from 50 to 1. Then the sequence starts over. and continues over and over. I'm able to clear it when the time reaches 1 or 2. It stays off for a while (3-4 hours) then starts over. I can not clear the countdown until it reaches 1 or 2. After I clear it the dishwasher will work, but until then, no way. This happens with the door open or closed.
Sep 15, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
I have a maytag quiet series 300. When it is done with any of the cycles in leaves about 1-2 inches of water in the bottom of the dishwasher. I can manually hit the start button twice and it will go...
Hi jeffwirch,
I'm Harvey the Master Plumber.
Your problem is: You have a maytag quiet series 300. When it is done with any of the cycles in leaves about 1-2 inches of water in the bottom of the dishwasher. You can manually hit the start button twice and it will go through a 2 minute cycle and pump out the water. You have cleaned the filter inside the dishwasher where it drains and have checked the hose to the disposal and it pumps out fine. It just doen't pump itself at the end of the cycle.
It sounds like a bad control board. It's in the top of the door panel. I don't recomend this repair to the average homeowner. You might consider the Repair Directory to find a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 13, 2008 | Maytag Dishwashers
Maytag MDB8751BWQ 24 in. Built-in Dishwasher Logo
643 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
