Question about Philips Audio Players & Recorders
Phillips car 400 radio
How do i store radio stations so i don have to keep retuning
Phillips car 400 -6 safe
Posted on Jun 04, 2008
Radio Station Keeps Changing Automatically
hi there is a option in the settings to automatically search for the station if frequency changes try turning it off to see if that helps
Mar 23, 2014 | 2006 Hyundai Accent
How to keep radio stations tuned in when radio turned of
If your radio has memory locations where it stores station frequencies then you can store those frequencies for easy recall. But if your radio does not have memory storage then it will usually tune in to the last station every time you turn the radio on.
Sep 14, 2013 | Audio Players & Recorders
Motevo gtv x3 touchscreen: I don't know how to set radio stations. Once I find a radio station I try to store it, but I don't have a clue how. Can someone explain it to me or tell me where I c
I just bought a used honda city that has this Motevo GTV-x3+ installed. I was successful in storing the channel using the remote. After I go into the radio section, I touch the "Scan" button on screen and once it pauses on a channel I like, I touch the "Scan" button again. This stops the tuner from moving on to the next channel. Next, using the remote I long press a number for example 1 and the channel is stored in the list on position 1.
Oct 22, 2012 | Motevo GTV-X3 - 6.2" Touchscreen...
Have lost all my favourite radio stations on honda jazz 2005 how do i retune ?
Select the AM or FM wave band.
Tune the radio to a station then press and hold down the 1 or 2 or 3 pre tune station button until it beeps. Then this radio station is then set to which pre tune button you have selected.
Repeat to set the buttons for other radio stations.
Aug 01, 2012 | 2005 Honda Jazz
I just bought a 32bv701b. When doing auto scan no digital channels appear. My previous TV received them all fine. Help!
Do a retune to this TV.
Press MENU button on the remote control and select
Install and Retune by using Left or Right button.
Press OK button and the following menu screen
will be displayed
Select Automatic Channel Scan (Retune) by using
Up or Down button and press OK button. Automatic
Channel Scan options will be displayed. You can select
options by using Up or Down and OK buttons.
Auto Channel Scan Menu Operation
Digital: Searches and stores aerial DVB stations.
Analogue: Searches and stores analogue stations.
Full: Searches and stores both analogue and aerial
DVB stations.
Whenever you select an automatic search type and
press OK button, a confi rmation screen will appear
on the screen. To start installation process, select
Yes, to cancel select No by using Left or Right
and OK button.
After auto channel scan type is set and selected
and confi rmed, installation process will start and
progress bar will move along. Press MENU button
to cancel process. In such a case, located channels
are not stored. The television will start to search for
all available stations. You must allow the television
to complete the search.
Jun 13, 2012 | Panasonic Televison & Video
I have a Phillips under the counter tv/radio. I need to figure out how to reset my preset radio buttons
try tuning into the new station you want then press and hold a pre set button and it should store the new station
May 30, 2011 | Philips Audio Players & Recorders
Car radio won't work all it keeps saying is lost TP TA, what does this mean? please help.
TP is Traffic Programme. It is set if the radio station is likely to give traffic bulletins. You can search and store only those stations with the TP flag set if you want.
TA is Traffic announcement and is set when the tuned station is braodcast a bulletin. It then swiths the audo from mute or cassette or CD to receive it.
EON is extended other networks and is only I think available on BBC stations, so if you are going along listening to Radio 4 say and BBC SCR puts out a bulletin then the radio retunes to SCR for the duration of the bulletin, or longer if they do not switch the flag off!
As for volue, it seems to take the last volume used when the TA/EON flag was last used.
As for it going silent, keep pressing the TP button until you get a full set of TA, TP, EON, REG icons up!
Do not confuse all this with RDS-TMC which drives the data for the ETA on the TNS 200 and TNS300 Nave systems.
Hope this helps.
Jan 28, 2011 | Car Audio & Video
When you locate the stations and store them then leave the car for any period of time or turn radio off, all the stations you previously stored have all disappeared and you have to retune again!
There are 2 battery supplies to the radio,.
The main one via the ignition key circuit for the radio itself.
The other one is a permanent battery feed to the radio memory.
It is this second (permanent) feed that is missing.
Check the fuse, connectors + wiring to see if there is anything obvious.
If you have a multimeter or test lamp then that can be used to prove the problem
Sep 04, 2010 | Pioneer DEH-P4100
Losing station on cd radio
THAT TYPE OF CONFIGURATION MUST BE OBTAINED FROM THE USER MANUALS
Aug 06, 2008 | Clarion DB245 CD Player
I have a Wharfedale WH170 car stereo. I have programmed the radio channels, but whenever I turn off the ignition, the programmes are lost and I have to retune and store the channels again. Is there...
This is usually caused by having the memory and power connections swapped (one stays on all the time, to store stations etc, and the other turns on with the ignition to provide the main power)
Try swapping the two power wires over - they're usally thick yellow and red wires IIRC, and almost all modern stereos have in-line 'bullet' connectors to let you swap them over easily (because not all car manufacturers have them the same way around!).
Jun 21, 2008 | Car Audio & Video
412 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
