Question about Qca Spas Majestic Series Aruba Xl Hot Tub
I have four blinking lights and it reads clean filter cartridges or call for service. First three lights blink jet one jet two and light and also heat light. All four blink and tub will not heat up. Keeps kicking on making a humming noise and cuts back off. I have cleaned the pump from lime and it ran about 2 hours and does the same thing starts blinking again.
Hi we have had this problem a lot - it has ALWAYS turned out to be something to do with the filters e.g. they needed cleaned or a duck stuck in them. So check and clean even if you don't think they are due a clean. On some occasions still had to play about with setting the jets on switching on off always got a positive result
Posted on Jun 27, 2010
  • 8,404 Answers
Is your pump actually moving water?
I think you should replace your cartridge filter or at the very least, do a thorough cleaning in accord with the manufacturer instruction.
There is a possibility you have pump impeller damage or there is other problem with the pump.
Posted on May 16, 2010
Why would my lights all be blinking on my Jet 3
Hello Cathy,there are many short videos to choose from on YouTube.Maybe,type in search bar:Binking lights fault on Jet 3.I hope this helped you
Jan 24, 2015 | Jet Health & Beauty
Clean light blinking
If the clean light blinks four times and then pauses and then blinks four times again and repeats, the problem is your pump motor. If there is water under the DW the pump clamp has probably failed and sprayed water onto and inside the motor. Call a certified Kitchen Aid repair service.
Aug 13, 2014 | KitchenAid Dishwashers
Yellow light is blinking?
If the bottom amber colored light is blinking, the imaging drum needs replaced.
If the yellow print cartridge light is blinking, then replace the print cartridge (yellow toner).
Mar 24, 2014 | HP c9705a - Color Laser Jet 2500l Printer
Clean instructions
First, let me clarify what the red light indicates.
A solid red light indicates the cleaning cycle is in progress. A blinking red light indicates the coffeemaker is off, but due to be cleaned. When the coffeemaker is due to be cleaned, the red light will continue to blink while the coffeemaker is off until the cleaning cycle has been completed fully. The entire cleaning process takes about an hour and a half. And, it is not intuitive. So, here are my instructions.
With the coffeemaker off (with the red light blinking), pour four cups of pure white vinegar (no water added) into the reservoir. Don't short the amount. You'll need four cups to complete the cycle. Remove any filters, but leave the strainer basket in place. Tap the "select" button three times until the red light is on (and stays on, not blinking). The cleaning cycle now begins. It should take between 45 minutes and an hour to complete. Don't be concerned about the 30-minute long pause during the cycle when nothing happens. This is intentional and part of the cycle.
After the cleaning cycle has completed, get rid of the vinegar. Rinse out the strainer basket and the coffee pot. Run a full pot of clean water thru a regular brew cycle (with the pot and basket in place, of course). Then, dump the water, rinse the pot and basket again, and run another full pot of clean water thru a regular brew cycle. Dump that water too. And, you're done!
Feb 04, 2014 | Mr. Coffee JWX27 12-Cup Coffee Maker
All four toner lights blinking
it could be that you need to replace all the toners. I do not own this kind of printer, but if it is the same as my inkjets, you have to replace all empty cartridges or it still wont work. try replacing the other toner and see what happens.
Nov 08, 2013 | Konica Minolta Magicolor 1600W Printer
HI I have a new View Sonic DLP PJD 6221 It does not have very many hours, It turns on normally, after three to four minutes, it blinks for a few seconds and then shuts down. The red lamp light...
is the filter timer enabled. what are the total filter hours it has recorded.
is the air filter and vents clean etc.
it seems to be getting too hot as you suggest
Apr 20, 2011 | ViewSonic Office Equipment & Supplies
My F4280 has blinking on light and blinking cartridge lights and the letter "E" in the Start Copy window, cannot scan or make copies but printer part works. Message in desktop says "Scanner Failure" but...
The product uses various combinations of flashing lights to indicate its current status.
  1. Turn off the product.
  2. Disconnect the power cord from the electrical outlet.
  3. Wait 60 seconds.
  4. Reconnect the power cord to the electrical outlet.
  5. Turn on the product
Issue
The Check cartridge light is blinking. Cause one
The cartridge door is open.
Solution one
Make sure that the cartridge door has been completely closed. Cause two
The cartridge is missing or not seated correctly.
Solution two
Insert the cartridge by sliding it forward into the slot correctly. Cause three
The tape was not removed from the cartridge.
Solution three
Make sure that the plastic tape has been removed before inserting the cartridge into its slot. Cause four
The cartridge is not intended for use in this product.
Issue
Solution one
Solution two
Solution three
Issue
Solution one
Solution two
Solution three
Issue
Solution one
Solution two
Solution three
Aug 06, 2010 | Office Equipment & Supplies
Cartridge light blinks
Try cleaning the print head first in the software options on the printer and then lightly with a qtip and alcohol or electronics cleaner. The ink jets sometimes dry up and cause the nozzels to get plugged.
Sep 02, 2009 | HP DeskJet 845c Printer
Orange cartridge light error keeps on blinking!
clean the carriage home
check the data cable for the carriage home
check the media sensor on the left of the plotter media bar
Mar 12, 2008 | HP DesignJet 450c InkJet Printer
Priner problems
Issue After you install a print cartridge, or during normal operation, the print cartridge light and one or both of the Start Copy lights begin to blink. Solution NOTE: The procedures below refer to a 'problem' cartridge. The 'problem' cartridgeis identified either by a computer message or by the Start Copy lights. If a computer message indicates a specific cartridge, that is the problem cartridge. If there is no computer message, look at the Start Copy lights - if the Black Start Copy light is blinking, the cartridge on the right is the problem cartridge. If the Color Start Copy light is blinking, the cartridge on the left is the problem cartridge. If both Start Copy lights are blinking and there is no computer message, perform the procedures below on both cartridges. Work through the sections below in order. When the print cartridge light stops blinking, you have solved the problem. Step One: Remove, inspect, and reseat the problem cartridge The print cartridge may not have full electrical contact with the printer. Removing and reinstalling the cartridge may help. NOTE: HP cannot guarantee the quality of remanufactured or refilled cartridges. Make sure the printer is on. Press the Power button if it is not lit. Open the printer cover, then wait until the print cartridge carriage is idle and silent. Press down lightly on the end of the problem cartridge to release it. Slide the cartridge out and inspect it: CAUTION: Do not touch the copper electrical contacts or the ink nozzles. Check the electrical contacts for debris. Make sure all the clear nozzle protective tape has been removed. CAUTION: Do not attempt to remove the copper electrical strip! Look at the number on the print cartridge label and make sure it is compatible with your printer. Compatible print cartridges are listed in the Printer Reference Guide supplied with your printer. If the cartridge is compatible, reinstall it in the printer: Cartridges marked with a triangle go into the left carriage slot. Cartridges marked with a square or pentagon go into the right carriage slot. Step Two: Clean the problem cartridge contacts If the steps have not solved the problem, clean the electrical contacts on the print cartridge and in the carriage in the printer. Gather the following items to clean the cartridge and print carriage: Clean distilled water. Use bottled or filtered water if distilled water is not available. Tap-water can contain contaminants that damage the cartridge. Clean cotton swabs or any soft, lint-free material that will not stick to the cartridges (coffee filters work well) Sheets of paper or a paper towel to rest the cartridges on during cleaning Open the printer cover and wait until the print carriage stops moving. Remove the cartridge and place it on a piece of paper with the nozzle plate facing up. NOTE: Clean the contacts quickly so that the cartridge is not outside of the printer for more than 30 minutes. If the cartridge is outside of the printer for too long, the ink can dry and clog the nozzles. Unplug the printer. Dip a swab in the clean water, and then squeeze it to remove most of the moisture. The swab should be only slightly damp. Clean the print-cartridge contacts. Do not touch the nozzles. Clean the contacts in the print carriage, inside the printer. Either let the cartridge sit for ten minutes to allow the cleaned area to dry, or use a new swab to dry it. Reinstall the cartridge, plug the printer back in, and close the printer cover. Try to print again. If the issue still appears, proceed to the next step. Step Three: Repeat reseating and cleaning steps If the problem is not solved, repeat the reseating and cleaning procedures above. Step Four: Contact HP If the problem has not been solved by the steps above, either the printer or the problem cartridge is defective
Sep 02, 2007 | HP Photosmart C3180 All-In-One InkJet...
Qca Spas Majestic Series Aruba Xl Hot Tub Logo
85 people viewed this question
Top Qca Spas Pool & Spa Experts
Ian Kime
Ian Kime
byrdhaus188
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Qca Spas Pool and Spa Expert? Answer questions, earn points and help others
