Question about Whirlpool MH3184XP Microwave Oven
What is a F7 code on the display mean - Whirlpool MH3184XP Microwave Oven
  • Whirlpool Master
  • 9,098 Answers
I have a Kenmore Elite Speedcook Microwave oven, model #665.63783600. What does error code F7 mean on this model?
F7 Error Code On Microwave Ovens With Inverter Board
An F7 error code could be an inverter board failure. Anything else that prevents microwave energy may also cause an F7 error, and must be checked. The technician should perform the following procedure to test for an F7 error code:
1. Check the magnetron.
2. Check the magnetron TCO (it should be closed).
3. Check the 3 interlock switches.
4. Check the harness wiring.
5. Check the electronic controls.
6. Check the inverter board.
For more free help, feel free to contact me via my site with your detailed symptoms and full model number and FCC ID number as shown on the tag in or on the oven.
Nov 18, 2016 | Kenmore Microwave Ovens
How CAN i TEST MY MICROWAVE?
Most common cause of an F7 code on these models is a bad inverter or magnetron. Generally it is best to replace both the magnetron and the 1100 watt inverter board at the same time, since a bad magnetron is usually what burns out the inverter board.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jeffrey_634abadf963e31e5
Jul 24, 2014 | Whirlpool Gold GH5184XPS 1.8 Cu. Ft. Over...
My display shows F7 how do remove it. and what does it mean?
Is it a Whirlpool? If so, this is a generic "will not operate" code, and the microwave will not turn on. A couple of things to try: 1. Check to make sure the door is properly aligned on the microwave. Adjust as needed. 2. If you have a removable exhaust panel (probably on top) remove this along with the filter underneath and reinstall.
When everything is back together, try the microwave again.
Jul 31, 2011 | Microwave Ovens
F7 error code displayed
Hi jruszas,
This F7 error code that you have on your display is all about the function key stuck on ERC. The only way to resolve this is to replace control board (also called ERC or clock). You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. Just get your model number ready when you call.
Hope this helps.
Thank you for using FixYa.
May 22, 2011 | Whirlpool MH9181XM 1100 Watts Microwave...
The oven (10+ years old GE True Temp double wall oven) beeps and displays an F7 error message. We can temporarily stop it by pushing the Clear button, but it starts again in a few seconds. We don't know...
I'm a GE tech, the F7 means there is either a stuck button on the keypad or relay on the board behind the keypad. Shut off the breaker. Remove the 3 screws under the keypad and lift the panel a bit to remove it. Lay it face down on the top rack and disconnect the ribbon cable. Turn power back on and if f7 goes away the problem is in the keypad. If f76 returns it's in the control. We typically replace both together because usually if you replace 1 it will come back later then be the other part.
Mar 26, 2011 | Microwave Ovens
Error code F7
Hi drk2676,
This error code F7 means that you have a function key stuck on ERC. You can solve this issue by replacing control board (also called ERC or clock). You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Feb 01, 2011 | Whirlpool GH6177XPS Microwave Oven
KitchenAid KHMS 2050 SSS, doesn't heat up and indicates "Error Code F7, VH SMPS feedback, call for service"
Hi asoleyma,
This error code F7 from a Ktchenaid oven means that the function key is stuck on ERC. This can be fixed by having the control board (also called ERC or clock) be replaced.You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. Just get your model number ready when you call.
Hope this helps.
Jan 30, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
F7 code on Whirlpool Microwave model GH9185XLT - 1
Power to magnetron
interrupted
12. Replace inverter.
13. Replace all parts and panels before operating.
14. Plug in microwave oven or reconnect power.
15. If problem persists, unplug microwave oven or disconnect power.
16. Replace electronic control.
17. Replace all parts and panels before operating.
18. Plug in microwave oven or reconnect power.
19. If problem persists, unplug microwave oven or disconnect power.
20. Check for reversed plug connection on controls or loose wiring.
21. Replace all parts and panels before operating.
22. Plug in microwave oven or reconnect power.
May 23, 2017 | Whirlpool GH9185XL Microwave Oven
Error F7
Microwave will not operate (cook). F7 error code
appears on the display.
Electrical circuit interruption between L1 and Neutral in
the microwave inverter circuit.
Possible reasons:
1. Check door, hinge and cavity front alignment and adjust
as needed.
2. Check the operation of all interlock switches.
3. Check over temperature protector for the magnatron.
4. Check all Cavity Thermostats for closed circuit.
5. Unplug the oven for at least 40 seconds. If this solves
the problem
A. Check the Cooling Fan for proper operation or
blockage
B. Check the resistance of the magnetron thermostat.
It should be 0 Ohms, replace if necessary.
6. Check that the control cable to the 1100 watt inverter
is properly connected to plug P2 on the display PCB
& Adjust or Reconnect
7. If interlock switches operate correctly, replace 1100W
inverter.
8. If problem persists, replace control assembly.
Nov 18, 2009 | Whirlpool GH9176XMS 1100 Watts Microwave...
F7 Error code on Kenmore Ultra Wave Microwave Hood Combination Model 665.61652100
The 665 the model number prefix means it's made by Whirlpool. F7 means it has a problem with the control board or keypad.
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
If it still has a problem, we repair these for customers nationwide with our guaranteed $39.95 service. If a new keypad were needed, that would add about $60 to the repair cost.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jul 03, 2008 | Kenmore Microwave Ovens
Whirlpool MH3184XP Microwave Oven Logo
934 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
