Question about Philips Magnavox DVD/VCR Dual Player
Dvd player wont turn on, red light keeps flashing
Dvd player wont turn on red light keeps flashing
snakehead
  • 1074 Answers
SOURCE: Magnavox MWD200F not working anymore!!!
since you have plugged out the DVD for 3hrs the conclusion is that you will need to take it to a repairman the problem with your DVD is that it got a surge due to the power failure.that sound you are getting is from the little transformer in the power supply,the current stops at the primary windings and is not crossing over the the secondary winding to complete the cycle.good luck i was the one who told you to plug it out for 3hrs
Posted on Jun 04, 2007
SOURCE: dvd player wont open
Look on the bottom of your player. Between the two front feet you should see a narrow slot that is about 1 1/2" long (it should say "emergency hole". Shine a light into the slot, you should see a black pin about as big around as a pencil lead. Carefully push this pin in the direction of the arrow. It should release the drawer and allow you to open it.
Posted on Aug 28, 2007
ThaMp3Doctor
  • 8596 Answers
SOURCE: my dvd player wont turn on
Unplug the unit - look underneath disc tray for an oblong shaped hole with another pinhole or plastic white piece down inside - use screwdriver to move the white piece to other side of oblong - disc should eject. Then try plugging dvd player in and try again.
Posted on Sep 04, 2008
stonephoenix
  • 563 Answers
SOURCE: memorex dvd player standby light flashing
I work for Memorex tech support. Our phone number is 800-919-3647.
I know this isn't what you want to hear, but the problem you've described can't be fixed with troubleshooting. Your DVD player needs to be repaired. There is a part that has developed a defect and needs to be replaced. The problem is Memorex doesn't repair their DVD players, they simply replace them when a customer has a warranty claim. If your player is no longer in warranty (the warranty is 90 days from the date of purchase) please call the above number to see if your model qualifies for any out of warranty options. Getting the player repaired locally would cost far more than what you paid for it, and that's if someone could repair it without any replacement parts from Memorex.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 04, 2009
masteria
  • 355 Answers
SOURCE: my philips dvp642 dvd player has a blinking red
Here is the solution. This is a common problem with this player.
Common DVP 642 problem (only problem with a great player): They die,
and you have a blinking red power button.
This is actually surprisingly easy to fix. It's really easier than I
make it look, but I'm just being really clear in case anyone reading
this has never seen a soldering iron before. Here are the steps I did
(and note that, if you're still under warranty, this will void your
warranty). The decision to try this is up to your own discretion
and may be a last ditch effort before throwing the player away.
Short version: Check the board to see if capacitor C316 is bulging. If
so, get a 1000u capacitor >=16V and replace it.
Long version:
1. Unplug everything
2. Unscrew the side and rear screws to remove the top cover.
3. On the board where the power cable goes in, look for a capacitor
(looks like a little drum with a '+' on the
top) that is bulging upward either a little or a lot. It may be
leaking some brown fluid as well.
4. I'm betting that the writing on the board at this location says
'C316'. If you google 'dvp642' and 'c316', you'll get hundreds of hits...
5. If that's the case, you'll need to find a capacitor and a soldering
iron. Visit radio shack or similar electronics
place and buy an elecrolytic capacitor that says 1000u (the 'u' is
actually a lower case greek 'mu') with a
voltage greater than or equal to 16v (this is not calculated: it's
simply what others have reported success with.
I couldn't find one and used a 35V one instead). You should be able to
find one that looks somewhat similar to
the damaged one (it might be a little bigger or smaller, but you'll
want the same basic shape). This should cost less than $2.
6. Borrow or buy a cheap soldering iron and some solder. I borrowed
one from a friend at work...this is NOT
my area of expertise, so don't worry about the difficulty!
7. Now the tricky part: back on your DVD player, you need to get that
board out. Unplug the two cables
connecting to the board we're working on, unscrew the screws holding
it down, and, using some pliers, hold
down the wings of the little plastic piece that is still holding the
board down and slide the board up. I flipped
this around to get at the bottom while leaving the power cord in
place.
8. Heat up the soldering iron. Locate the spot on the bottom of the
board where the C316 capacitor is attached.
Remove your new capacitor from the package. There should be one
shorter leg which is the negative side. It
will likely be marked this way as well.
9. One side of the capacitor should have a ' -' on it. Note which side
this is. You may not be able to see it until it
is removed, so be aware of needing to know this as you remove it.
10. After it is warm enough to melt solder, lay the soldering iron
across the joints you identified as belonging to
C316. Tug gently on C316 as you do this and it should soon come free.
This is a little tricky to hold the iron,
the board, and the capacitor all at once, so please don't burn
yourself! Again, note which side is negative and
which hole it came from. This is the negative hole, and the other is
positive. There will likely be some solder
left over around each hole. Just try not to let it run between the two
holes or you will short out the connection.
11. Grab your new capacitor and line up the longer leg with the
positive hole. Lay the soldering iron against
that hole on the other side and push the leg through. Line up the
negative leg/hole and repeat. Lay the iron
across both to heat up enough to push the capacitor legs through and
the capacitor down to the board.
12. Check the connections for each leg. There should be a small *****
of solder joining each leg to the metal
of the board, but not running to any other point of the board. If it's
run to some other points, you'll need to do
some searching to see how to clean up it up a little bit as I'm not an
expert at this. If you need a little more
solder, lay the iron across the joint for a few seconds, then feed
your solder into the hot spot until a small
amount flows over the joint. Remove the iron, wait a moment, then
remove the solder. Look at the other
solder joints on the board for a rough idea of how it should look.
13. Use some wire cutters to trim the legs down to the solder.
14. Pop the board back over the plastic piece and reconnect the cables.
15. At this point, you're on your own. Personally, I made sure I
wasn't touching any metal and plugged it in.
Since I didn't blow any fuses and the player seemed to work, I
unplugged it, reassembled it, and went to watch a movie.
Posted on Aug 12, 2009
Dvd player ,brand name Arrgo. Wont turn on and power indicator light keeps flashing yellow and red .how do I fixit?
You can't fix this, you can't buy the parts, you will need to send it in for repair, which often costs as much as just replacing it.
Aug 12, 2016 | Televison & Video
Audio /video dvd/cd don't play on my system. Open tray keeps opening. Or if dvd/cd sticks in it just keeps reading...and then says cannot play...plshelp. System is 2 years old
turn on the player with the case openned, pay attention to the optic. No problem with the Optic if red light flashes. Replace your motor dynamo player with new one
Jun 22, 2010 | Audio Players & Recorders
Wont work
hello,
the problem of this is from the power supply board of DVD player, try websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 31, 2010 | Sansui VRDVD5000 DVD Recorder/VCR
The players red and green light keeps flashing and wont come on
THIS CAN BE SOLVED BY CHANGING THE MAIN POWER SUPPLY BOARD OF YOUR DVD PLAYERS. The main problem should be the Main Capacitor in the circuit. The safer side is to change the whole board.
Apr 23, 2009 | Televison & Video
GPX DVD player flashing power light
Ihave a GPX portable dvd player that has a broken charging jack on the unit itself. The model is a GPX 808.
Mar 11, 2009 | GPX D1816 DVD Player
Disk drive won't open & lights flash
samsung told me it was defective and to send it in at my own expense. Throw it out and dont buy samsung
Jan 07, 2009 | Samsung DVD-P241 DVD Player
Cant play anything on it
I had the same problem, After googling for a few minutes I found the reset procedure for this player.
1. Turn it on.
2. Eject any disk you have in there and close the tray.
3. Hold down the "STOP" button on the player (not remote) until the green light flashes red and the system reboots.
4. Insert disk and enjoy.
This worked for me... mileage may vary.
Aug 29, 2007 | Cyberhome CH-DVD 300 DVD Player
Philips Magnavox DVD/VCR Dual Player Logo
169 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
