Question about Canon IXUS 80 IS Digital Camera
My camera says no memory card but its has one inside and its not locked
  • Canon Master
  • 4,738 Answers
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Posted on Oct 24, 2010
I have a canon ixus65 with memory card error i have tried new card and sliding the cover back and forth
The actual switch to lock the memory card is inside the camera and not on the card. If the switch inside the camera is damaged, the camera will think every card you use is locked. It might be fixable, but you might have to replace the mainboard of the camera. A good used board is probably available for $25 or so, plus $30 to install.
Hope this helps!
Thomas Drayton
Owner www.darntoothysam.com
Affordable Digital Camera Repair
Aug 03, 2011 | Canon PowerShot SD630 Digital ELPH / IXUS...
Memory card error message
Cards are coming in different formats and it might be possible that you brought a card which is not suitable or functional with your camera. The other reason could be that we are having options to lock our memory card in digital camera and you might have taken out your earlier card without unlocking it. The system might be broken from inside and this could be a reason that you are still getting a message that memory card is locked. It seems possible based on problem you are sharing.
May 28, 2010 | Canon PowerShot SD780 IS / IXUS 100 IS...
Memory card is not locking , i mean if we push memory card inside then it is not locking
Well, it's the mechanical problems inside the Memory Card holder.
There's nothing you can do here, except take it to the Canon service center for repair.
Dec 08, 2009 | Canon PowerShot A75 Digital Camera
"Card Locked"
Hi!
There's a small switch on the memory card reader inside the camera which detects that the card is locked. Most likely this switch is broken. You can try to point it with needle or something but I'm afraid you will have to give it away for a repair to a local repair shop or Canon service center.
Tom
Sep 23, 2009 | Canon PowerShot A590 IS Digital Camera
Memory card is locked w. Canon Powershot SD1000
Your Sd1100 is compatible with a 4gb card, so that's not the issue. If the lock-switch is in the correct position, the only logical conclusion (which you have already come to.....good troubleshooting on your part!) is that the camera is busted. Send your two "friends" the bill. What a drag.
May 27, 2009 | Canon PowerShot SD1000 Digital Camera
Its saying the memory card is locked. its not
if you have checked the SD card was not locked, you may need to open the camera to check the SD card slot inside,
here is a tips shows you where to check
http://www.myfixtips.com/blog/digital-camera/how-to-fix-a-%e2%80%98card-locked%e2%80%99-problem-125.htm
May 16, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Memory Card Locked.... how do I un-lock it?
there should be a little swith on the side of the card. switch to the opposite and then try
Dec 20, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Your memory card has a small white "switch" on the side. Move the switch and your card will unlock. It is a saftey so you don't erase anything accidentaly.
Jun 27, 2008 | Canon PowerShot A560 Digital Camera
Card lock
Dear geogie:
If your camera gives you "card locked" error messages with several cards and you KNOW that the cards are indeed not locked via the sliding lock mechanism, then your camera needs to be sent in for service as it has developed and electrical communications problem within the memory card control function.
I would first however try a hard reset by resetting your camera to the default settings, removing the battery and memory card for two minutes, and then replacing them. Retest the cards for the error message. If it still occurs then call 1-800-828-8080 for your options.
Hope this helps.
Sincerely,
HeavyDLB
Jun 09, 2008 | Samsung S630 Digital Camera
Canon IXUS 80 IS Digital Camera Logo
250 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
