Question about HP Compaq nx7300 Notebook
I M using win xp installation cd but it gives mess that no hdd powered on
    Problem Solver:
  • 6 Answers
Go to BIOS to check the reliability of hdd or if you have a software tool such as "Avanquest System Suite" use it to boot machine from scratch. It will tell u what is really wrong.
Posted on Jun 09, 2010
I use hp nx9010, i want to re-install windows xp but any time i try, the machine shutdown. sometimes is able to move up to copping files sometimes not then shutdown; i don't understand why is only windows...
well that is so easy to answer,
first off you are not using real HP disks are you.
sure. its old Blue Microsoft disks right,
and when you do that wrong, you get no HP chip drivers and lost more missing, even top row, fn keys dead, not just audio.
XP is a dead OS. for 3 years now, zero updates and is now a virus magnet extream.
nx9010 note book shuts down, all 3 os install different. !
old XP runs a very old and very DUMBB seteup.,exe
the newer OS run WINPE for setup.exe. vastly better and boots and loads the OS totally different.
Xp can be installed many ways, not one stated by you.
1-insert, HP install disk in CDROM drive and click, setup.exe running in a XP explorer window, live install
2: boot to HP install disk.
3: boot and hit F11 run HPs on HDD restore partition.
4: same as a above 1, or 2, but is Micro soft disk (wrong, you did it wrong, do not use mS disk) if must ask how, its a long long long story. ive done it all ways, 1000s of time. now since first PC.s ever.
if booting to XP , right or wrong CD. (its a CD right<)> or a stick
that too not stated,
it boots and you answer questions, then it starts copying
if it stalls that means, the CD is bad.
or PC is bad, you do know there are 3million transistors here to fail right? bad HDD, bad Mobo, and more. lots more
even the CPU can over heat and will shut down.
Personally I avoid all CD nows, they sux'd then and do now more.
make and ISO of your CD, (ask its easy and free)
then burn the ISO to a 4GB or bigger uSB memory stick using free RUFUS app.
boot to stick. on my HP hit F9 and pick Udisk USB. boot
bingo no more CD errors ever again.
i bet bad CD. seen it vast times, endless , but not today. too savvy now. to mess with any CD, if you copy it to ISO and get CRC errors
its a bad CD.
end pain.
the problem with real old PC most cant boot to USB
or must be BIOS flashed updated to get that.
ill now ill try to learn what yours can or can not do.
lacking ,what is there now.
but id do this first. go in to BIOS BOOT PAGE
What is the default boot order? The default boot order settings for the computer are configured in the factory. The default boot order for HP notebook PCs is listed below.
  1. Floppy disk drive
  2. Optical drive (DVD, CD-ROM)
  3. Hard drive
  4. USB device (see this?) bingo, can boot and install any OS here
  5. Network adapter
Apr 23, 2017 | HP NX9010: Pentium 4-2.4 GHZ, 512MB...
How do I format C drive with windows 7 on it I want to put windows XP on
hi
thank you for using Fixya
to formate C drive and re install windows XP
1 put widows XP CD in to your CD drive
2 restart your PC
3 it will boot your CD just put Enter
4 if not then selact boot option by presing F12 0r F2
5 it will start reding your CD
then just folow the instruction
it will ask you foue setps
May 16, 2010 | Compaq Presario CQ60-220US PC Laptop
Windows 7 revert back to Win XP
I think that what's important is license key of your Win XP, the installer for Win XP can be downloaded from any download site now a days. If you have a friend or know someone who has the Win XP installer, you can barrow it from them or have it copied on another disc. Then use the license key that you have from your previous operating system (Win XP).
You must also make sure that the installer that you will be using is the same version that you used to have before installing Win 7. I hope this one helped in a way.
Mar 31, 2010 | Microsoft Windows XP Home Edition
I M USING WIN XP INSTALLATION CD BUT IT GIVES MESS THAT NO hdd POWERED ON
this is either the hdd failed for good..or it has something wrong plugged..or is just not seen cause it has some changes in bios...
just go to bios...restore to factory optimal defaults ...and try again ...be sure that you change the boot order after defaulting bios settings ..in such way to boot from cd first ...after that try again ...it may be a sata hdd and it is not seen cause it is not set right in bios..
if this not working ..remove the hdd and have it checked in another computer ...even a desktop if you find and adapter ..to see if it is still working ....
Mar 22, 2010 | HP Compaq nx7300 Notebook
Replaced HD and CD Rom drive, PC will not boot to disk, Do I need to format HD 1st. before loading OS?
Hi Get to the bios screen using F8 or F9, change the first boot device to CD ROM/DVD, then insert a bootable disk into the CD drive and try installing the OS first by completely formatting the HD during installation Win XP and higher OS editions give you the option to partition the HDD Hope this resolves
Nov 05, 2009 | IBM ThinkCentre S50 8183 - P4 3 GHz...
Xp
Hi There,
I just experienced the same problem you did concerning the partmgr.sys blue screen error. I am installing Windows XP Pro SP2 on a pretty old Dell Latitude LS (upgrading it from Win 2000). The XP installation disk gives me the option to format in NTFS, FAT, and both formats in a "quick" mode. I usually do not recommend using the quick mode, however, after trying both NTFS and FAT and receiving the blue screen, I decided to try NTFS (quick). That has allowed me to actually get further into the installation, so you may want to try that.
May 27, 2009 | Microsoft Windows XP Professional
Insataling windows xp problms
i believ ur using 32 bit operating system.change the boot sequence by pressing F12 at restart and select cd/dvd rom option while the windows cd still inside the drive,,format the c drive completely{if possible format the whole hdd} and then reinstall the windows os xp..i hope it will work fine,,just follow the screen prompts very very carefully and u will find everything mentioned,,best of luck
May 14, 2009 | HP Compaq Presario CQ60Z Notebook
"cant install win-xp on CQ-60"
Hello.
Hope this helps...
These are the normal steps on desktop computers but
should work in your case too with a fresh installation
1. Enter bios settings and set CD Drive as first boot device
2. After reboot if you are asked if you want to start on cd chose yes.
3. start Win Xp installation from cd.
4. delete partiton on C; drive
5. create new partition
6. Start installation and format the c:drive
7. Follow the installation instructions,,,
Feb 10, 2009 | Compaq Presario CQ60-220US PC Laptop
Install win xp and erase win vista
Would like too know how to erase win vista and install win xp
Dec 29, 2007 | Microsoft Windows XP Professional With...
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
HP Compaq nx7300 Notebook Logo
43 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
