Cold water inlet not allowing water through it
  • Washing Mach... Master
  • 43,501 Answers
Hot water fills with hot and cold not strictly hot what is the fix
see the causes: and proceed with common sense. God bless you
Some washing machines allow hot water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally. If you're sure the machine isn't working the way it used to--or should--try these tests: Is the hot water turned on? If not, turn it on. Is the washer getting cold water but no hot water? If so, check to see if the control panel settings are correct. Is there hot water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, completely replace it.
Some washing machines allow cold water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally. If you're sure the machine is not working the way it used to--or should--check the following. Is the cold water turned on? If not, turn it on. Is the washer getting hot water but no cold water? If so, check to see if the control panel settings are correct. Is there cold water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, you need to replace the
Sep 22, 2012 | Roper Washing Machines
When trying to wash with hot water only machine fill slows and adds cold water then adds hot this continues until load level is reached and you end up with barely warm water is there any way to fix this...
see the causes and use the common sense. God bless you
Kenmore Stackable Washer cold water does not work
Hello there
There's no cold water Some washing machines allow cold water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally. If you're sure the machine is not working the way it used to--or should--check the following. Is the cold water turned on? If not, turn it on. Is the washer getting hot water but no cold water? If so, check to see if the control panel settings are correct. Is there cold water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, you need to replace the valve.
It should look something like this picture below
Nov 09, 2010 | Kenmore 98702 Stacked Washer/Dryer
The washing machine won't fill with water at all. we have cleaned the pump valve and we have checked the water lines. are there any other things that could be causing this problem?
You will want to check and make sure the door handle/lock is switching on. the front load unit will not fill with water with the door open. Check that the latch is engaging.
Oct 05, 2010 | GE WSXH208A Front Load Washer
Cold water is not filling machine when place on cold washer cycle
Jan 11, 2010 | Kenmore 24032\24036 Top Load Washer
No cold water function, cold water to machine but will not cycle. all of a sudden no cold water
Jan 10, 2010 | Washing Machines
NO COLD BUT ONLY HOT WATER ENTERS WASHER
  • Is the cold water turned on? If not, turn it on.
  • Is the washer getting hot water but no cold water? If so, check to see if the control panel settings are correct.
  • Is there cold water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, you need to replace the valve.
Apr 01, 2009 | Maytag Washing Machines
No water going to feed machine
There's no hot water Some washing machines allow hot water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally.
  • Is the hot water turned on? If not, turn it on.
  • Is the washer getting cold water but no hot water? If so, check to see if the control panel settings are correct.
  • Is there hot water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, completely replace it.
There's no water at allIf there's no water at all, make these checks:
  • Is there water getting to the machine?
  • Is the water-volume selector switch set properly and are the control panel buttons pressed in all the way?
  • If you have a Maytag® washer, is the fuse (if there is one) in the control panel at the lid-switch bracket blown?
  • Is there a faint buzzing or humming noise coming from the water-inlet valve? (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If you can't hear anything, the water-inlet valve may not be getting any power. If you can hear some noise and there's water present, you may need to completely replace the water-inlet valve.
  • From Repairclinic
    Oct 12, 2008 | Dishwashers
    Can't get the cold water to turn on. I have 1. switched hoses 2. no kinks 3. water is turned on Model 1220
    Aug 17, 2008 | Hoover Washing Machines
    Cold water doesn't work in my washer
      if this helps please vote me a fix ya
    Jul 18, 2008 | Washing Machines
    Washing Machines Logo
    103 people viewed this question
    Top Washing Machines Experts
