Does not spin drains ok - Washing Machines
  • Washing Mach... Master
  • 43,501 Answers
Here is a tip that I wrtoe about washing machinesdoes not spin - 2_bing.gif that don't spin out right..
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
Posted on May 15, 2010
My Samsung WA13V9 washing machine doesn't drain or spin, but I think the pump motor is working. where can the problem be?
Check that the wiring inside is not damaged, if ok check that the start timer is not stack, if ok check that the drain pump is not blocked eg a coin stuck in it, if ok check that the start capacitor for the main spin motor is ok if not replace with same rating, if ok check if main spin motor is ok eg using continuty tester to check windigs or simply smell it and if burnt expect a pungent smell from it.
Aug 03, 2015 | Samsung Washing Machines
What happen while washing and draining ok,but not spinning?
Check and replace the spin clutch solenoid ,they get water on them and seize up.
Aug 31, 2014 | Conia Washing Machines
My Servis M3001 washing machine will not fast spin , it will spin and the belt seems to be ok , the machine is filling and draining ok , can you help at allThank you
Some times on front loaders if it is out of balance it will not go into fast spin. Try to remove some of the cloths and see if this helps.
Best of luck
'RR
May 15, 2014 | Washing Machines
Cloths come out wet after spinn
The water drained out ok? If yes, the timer is telling the motor to reverse and run in the drain spin direction and it is likely ok. If the draining is slow the clothes could come out wet, if the belt is cracked or streatched the clothes could come out wet. If the motor is not running through the entire spin/drain mode the timer could be at fault.
Will Not Spin
• Check for unbalanced load.
• Check for broken or slipping belt.
• Does the house drain system accept water from
machine?
• Check for blocked drain hose.
• Check for binding tub seal.
• Check for partial engagement of brake assembly.
• Check for obstruction between tubs.
• Check for broken impeller on pump.
Jan 02, 2012 | Amana NAV5800A Top Load Washer
Washer will not drain or spin with pipe in specific washer drain but will if placed in the sink We have moved house and the new house has the usual pipework behind the washer. The machine will fill and...
Hi.
ok Did you say the drain hose was placed on a spiggot underneath the sink???
the appliance is obviously working as you have tried the drain hose in the sink.
You may find, if you unscrew the drain spiggot, there is a blanking cap. your previous owners put this in place to stop a huge water leak when using the sink
remove cap, refit hose and it should work ok.
Please let me know if I was right?
regards
aardvark Repairs
Nov 18, 2009 | Hoover Washing Machines
My washer won't complete the final spin cycle. It goes through the wash and drain OK but won't spin, clothes are soaking wet. I removed the drain pipe and made sure it was not blocked, also removed and...
Hello, problem here is the spin control board is bad. Remove panel under the door and you can locate the spin control at the rear right of the machine screwed to the floor. Replace it and you will be all set. Mike
Nov 09, 2009 | Frigidaire ATF6000ES Front Load Washer
GE WCXR1070T5WW washes OK but won't spin and drain
It depends on what type of pump it has.If its an electric pump it could drain without spinning,but if the pump runs off the same motor as the washer then the motor has to be running for it to drain,and it will probably spin.There is no guarantee,but the switch that closes when you shut your washers lid is probably bad.Try bypassing this switch,and see if it spins.Please if it spins replace this switch.It is a safety measure that you should really want to keep intact.
Jun 05, 2009 | Washing Machines
Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Feb 09, 2009 | Kenmore 23822 Top Load Washer
Washer wont spin
is it draining ok or does it m ake any noises as if trying to spin?
Mar 05, 2008 | Zanussi F1045W Front Load Washer
Kenmore model #110.22802100 drains but no spin
If it is draining, then the motor is ok.
If it is agitating properly, then the motor coupler is ok.
This leaves the gearcase, clutch, basketdrive(brake), basket drive block, or timer.
Raise the lid and hold the lid switch down. Start a rinse cycle and let it go through the cycle. It should drain the water, then stop the motor for a split second then kick the motor back in and start spinning. If it doesn't drop out that split second then the timer is holding it in neutral drain. You can recreate this by letting it start draining, then let off the lid switch, then depressing it again. The basket should start spinning. If not,
Raise the lid and hold the lid switch closed. Start it in spin and see if you can get it started spinning by hand. If so you probably have a slipping clutch.
Post back with any questions.
You can go to sears.com, click on parts, and enter your model number and see parts diagrams of the washer. This can be helpful.
Nov 25, 2007 | Zanussi F1045W Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
