Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I have a liftmaster formula 1 garage door opener. It has become very difficult to open w/ both remotes unless you are right next to the door. I've replaced batteries in both remotes it didnt help. Is there something to do to the receiver in the opener itself?
I had an issue with my liftmaster professional openers with both units where the keypad and remotes lost range all at the same time. The remotes had to be within 1-2 ft of the antennas to work at all. My wife said she pulled into the garage and everything worked but after that we could not use the remotes. Turns our that she had a defective wireless doorbell she was returning and had it in the car (now in the garage!). I opened up the box, removed the battery from the doorbell transmitter and then everything worked fine. That was a fun 1.5 hours...
Posted on Feb 25, 2011
    President:
  • 3,197 Answers
Here are some things to check.
Limited range of your remote controls could be related to radio frequency interference that comes from something in your home or in the surrounding environment. Certain electrical devices can radiate interference; this could be almost anything that is plugged into an electrical outlet.
Please keep in mind that the device can be brand new, or can be an item that has been in use for quite a while. Also, the item may continue to function properly as far as you are able to tell. The only problem with the item may be that it has started to broadcast the interference, with no other symptoms noted.
Some devices are more likely to generate interference than others. This includes TV cable, cable amplifiers, surge protectors, fluorescent lights, battery charging devices (power tools, golf carts, etc.), anything that utilizes a timer (sprinkler systems, lights, alarm systems, etc.), and a myriad of others. If the problem seems sporadic, we can safely assume that the device responsible for the interference is only being operated during these times. Again, please keep in mind that the age of the device does not determine if it is capable of broadcasting unwanted interference. Any electrical device can be the source of the problem.
The first step is replacing the battery in your remote. If the range on your remote does not improve, remove the wall control wires from the overhead unit. If the range does not improve you will likely need to replace the remote control. After replacing the remote, or if you have other remotes programmed in to the opener, and the range problem still exists, please proceed to the Power Down test.
Multiple garage doors:
If you have two garage door units and one is working just fine, you will need to start by unplugging the good unit. This will help determine if the unit with no range starts to function properly. If the range comes back to the bad unit then you will need to replace the logic board on the unit that was unplugged as it is emitting an RF signal that is over powering the other garage door opener. If the range does not improve after the “good” unit has been unplugged, replace the batteries and try programming some additional remotes to determine if the existing remotes are the issue. If the extra remotes do not have any range then you would need to replace the receiver logic board in the “bad” unit.
Power Down test:
To isolate potential sources of interference, turn the circuit breaker off to the garage and plug the garage door opener into an extension cord from another room. If the range improves, then the interference is coming from a device in the garage. If no improvement is seen follow the same procedure, this time turning off the circuit breakers to your home, with the exception of the garage and test the remote controls. If improvement is noted, turn the circuit breakers back on, one by one, until the range problem resurfaces. This will allow you to narrow down what room the problem device is in. You will have to go from there to isolate it further, by unplugging and re-plugging the items in that room.
If you are unable to determine any source of interference, then the receiver logic board in the overhead unit will need to be replaced.
Posted on May 17, 2010
2 Suggested Answers
  • 3197 Answers
SOURCE: i have a liftmaster formula 1 garage door opener.
Here are some ideas and things to check.
If you have two garage door units and one is working just fine, you will need to start by unplugging the good unit. This will help determine if the unit with no range starts to function properly. If the range comes back to the bad unit then you will need to replace the logic board on the unit that was unplugged as it is emitting an RF signal that is over powering the other garage door opener. If the range doesn not improve after the “good” unit has been unplugged, replace the batteries and try programming some additional remotes to determine if the existing remotes are the issue. If the extra remotes do not have any range then you would need to replace the receiver logic board in the “bad” unit.
Power Down test:
Posted on Mar 22, 2010
Garage door will open from remote or car; however, it will not close using these controls. The only way I can close the garage door is to press on the manual control inside the garage until it is...
Your answer is in the last line, unless you have those lights, the opener assumes something is in the way. Make sure you have the green one pointing in the direction of the local sunsets as this is also a problem certain days of the year.
Jul 24, 2017 | liftmaster Chamberlain Garage Door Opener...
Garage door will not close from remote or car. Garage door will open from remote or car; however, it will not close using these controls. The only way I can close the garage door is to press on the manual...
Try reprograming the opener to each remote, if this doesn't work then the command/radio module in the opener is damaged and needs to be replaced. Hopefully you can find one or you will have to replace the whole garage door opener. Good luck.
Jan 21, 2012 | liftmaster Chamberlain Garage Door Opener...
I have a liftmaster formula 1 garage door opener. for the past year, the remote will work every time if in the garage, however, outside of the garage it only works maybe 10 percent of time and then i have...
Yes, replace the remote battery. It is losing power, thus working at short range only. Loss of range is the key indicator for a remote battery going out.
--W/D--
Jan 15, 2011 | liftmaster Chamberlain Garage Door Opener...
I have a liftmaster professional formula 1 and am trying to get the opener to sync with my car. is there a roaming setting on the unit that needs to be worked with in order to have it sync with my...
You have to first have your cars Homelink system learn your current remote (follow owners manual) THEN have the garage door opener learn the cars Homelink (push openers learn button then press the Homelink button you previously had learn your remote. Two learning steps required because the LiftMaster is a 'rolling code system'
Aug 07, 2010 | liftmaster Chamberlain Garage Door Opener...
I have a chamberlain liftmaster formula 1 garage door opener I could able to open the garage door using the remote. How ever I was not able to close it using the inside main panel big white color button....
Check to make sure the sensors in the doorway are pointed at one another and the small light on each one is lit and not flickering. If you cannot get both lights to come on you have a bad sensor.
Jul 12, 2010 | Sears Craftsman LiftMaster Chamberlain...
My garage door opener doesnt close all the way.
The motor is probably either stalling because the door is too stiff, or you have a beam break detector that is being triggered when the door is halfway down.
Nov 23, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
376 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
