Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Dyson bagless brush bar
I cleaned the hair out of the brushbar and cant get the belt off to clean under it. So I turned the vaccumn on anyhow and it makes a loud clicking. how do i fix it??
  • Anonymous Mar 25, 2014
    keeps stripping the end off the brushbar
  • 372 Answers
Your problem is either faulty clutch or siezed bearings in brush roller causing the clutch to slip.
You will need to strip head unit down.
Manuals for this work are available from this site.
http://dysonmanuals.llc.nu/
Posted on Mar 30, 2008
Dyson DC54 brush bar not rotating. Have removed all the hair, cleaned the brush and replaced, still not spinning.
Brushbar not turning Clutch check - Dyson
www.dyson.com/...dyson...not.../brushbar-not-turning-clutch-chec...
DysonBrushbar not turning - Clutch check. Please ensure that your hands are clear of the soleplate and brushbar before completing this test. Clutch check.
Resetting the brush bar (Official Dyson video) - YouTube
? 3:52
https://www.youtube.com/watch?v=AiKnefEr7ns
Jan 16, 2014 - Uploaded by AskDyson
How to clear and reset the brush bar of your Dyson DC41 Mk2, DC55, ... Dyson DC41 Mk2, DC55, DC65, DC66 - Resetting thebrush bar (Official Dyson video) .... Dyson Cinetic DC52, DC54with the Musclehead™ floor tool ...
Dyson DC44 - Remove & clean the Brush Bar - An owners ...
? 4:13
https://www.youtube.com/watch?v=_0a71p84sp8
Nov 12, 2012 - Uploaded by Tom Strong Reviews
Here is the fantastic Dyson Digital Slim Mk2 DC44 Animal. (DC45 in ... Europe) Here I show how to remove and clean the Brush Barof any tr... ... It is and easy operation and one you need to do whenever the brush is not clear.
Dyson DC54 Support - Turbine head not working properly
https://www.dyson.com.au/.../dc54/dc54...not.../turbine-head-not-workin...
Dyson DC54 Support - Turbine head not working properly. ... If you cannot clear an obstruction you may need to remove the brush bar. Use a coin to unlock the ...
Jan 24, 2016 | Dyson Vacuums
Hi there, it's Jack at Dyson.
DC03 doesn't use a traditional user-replaceable belt. Instead it has a brush control clutch mechanism which allows you to turn off the brush bar when cleaning hard floors and delicate rugs.
If the brush bar doesn't seem to be rotating, it's worth double-checking you have the brush control set correctly. When the machine is reclined into the normal vacuuming position, the brush control should move to the Drive/On position:
Please note, as a safety feature the brush bar will never rotate when the vacuum is standing upright.
If you're confident the brush control is in the correct position, but the brush bar still won't rotate, please give our freephone UK Helpline a call on 0800 298 0298. We're available from 8am-8pm from Monday to Friday, and 8am-6pm on weekends. Calls are free from UK landlines.
Sep 16, 2014 | Dyson DC03 Bagless Upright Cyclonic Vacuum
Brush bar doesn't fit back in
Hi Ryan, it's Jack at Dyson.
DC33's brush bar is not engineered to be removed by the user, and we would recommend using scissors to carefully cut away any hair or threads with the brush bar in place. You can remove the soleplate for easier access: http://www.dyson.com/support/dc33/dc33-multifloor/using-my-dyson-list/flo-dc07-gen-how-to-remove-a-blockage/redirect-to-removing-debris-from-the-brushbar-dc33/removing-debris-from-the-brushbar-dc33
For help replacing the brush bar I would encourage you to contact our experts directly - they may be able to talk you through it. You can reach them by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Nov 06, 2013 | Dyson DC33 Multi-Floor Upright Bagless...
Burning plastic smell when using the vacuum cleaner
HI, Thanks for contacting the FixYa team.
1. Plastic Burning Smell - This means that there is friction in a plastic part of your Dyson. The only place this will be coming from is the BrushBar. The brushbar has jammed somehow. The smell arises as the rubber belt is still trying to turn the plastic brushbar but the brushbar is not moving. To solve the problem you will need to unscrew the soleplate using a 2 pence piece, this is done by inserting the 2 pence piece into the 3 plastic screws on the underneath of the Dyson. Turn the screws a quarter anticlockwise. You can then remove the soleplate. You will probably see that there is a build up of debris by the brushbar. This is more common on The Animal version as pet hair mixed with dust gets stuck in here, especially if the machine has been used on a damp or wet surface. So clean this area out and then try manually rotating the brush bar in each direction. If you have been using the machine for too long with the burning smell then it is likely that your brushbar will be melted where the belt attaches to it. If this is the case then you will need to get a new brushbar. If the brushbar is not too damaged check that the belt has not broken. If the belt has not broken then replace the soleplate. Turn the screws a quarter in a clockwise direction. Should your belt be broken then please re-post and we will show you how to sort this. Thank you
Oct 25, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dog hair gets caught all the time in the belt drive spool, is there a fix for this other than having to pull it out all the time by hand? I have replaced the belt and the brush but this hasnt solved the...
My Dyson started making a loud noise when in "carpet" mode. After reading a ton of forums I thought it was the clutch assembly. Got a new one on eBay for a great price. Somewhat hard to replace, but thanks to this YouTube video, I was able to get it in: http://www.ezvacuum.com/dyson-dc07dc14-clutch-assembly-90025204-genuine-p-1636.html
HOWEVER this did not resolve the issue. I realized the beater bar was not spinning or was slipping. I thought I cleaned it all out but realized you need to take the beater bar out and pop the end cap and clean out the INSIDE of the beater bar (tons of lint and cat hair). I additionally sprayed WD40 in there.
It spins great now and in the end I think that's all I had to do was clean out the cat hair build up inside the beater bar. But now I have a new clutch & belts too. Hopefully won't have issues anytime soon.
Dec 20, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
The brushbar is not spinning.
Even though the belts are intact they can still be stretched and will not turn the brush. Here is a link to the belts you need:
Dyson DC14 Replacement Belts
Nov 24, 2009 | Dyson DC14 All floors Bagless Upright...
Beater brush won't spin but belt is intact and ok. Brush is clean and spins freely by hand.
For your beater brush to spin, you have to meet two conditions:
1) the vacuum cleaner has to be reclined (put your foot on the front and pull back on the handle).
2) The clutch actuator (the dial where you switch between BEAR FLOORS and CARPETS needs to be set to CARPETS).
If the brushbar/beater bar still doesn't spin after that, call the Dyson helpline, they will assist you. If you are saying that the brushbar isn't spinning because it is not picking up any dirt, you may have a loose internal hose, a blockage in the machine or the bristles on the brushbar are worn. Call the Dyson helpline for assistance.
Jul 11, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson vacuum cleaner-brush bar is frozen
Hi If your Dyson has a brush protection design - i.e. roller bar on the top of the hood on the left hand side then the DYson can't be repaired by you- serviceman or professional care can replace it.
However if the Dyson doesn't have the roller bar on top of the hood, flip the machine over so that the beater brush is facing upwards, locate three/four screw heads that can be undone with a coin and remove the sole plate assembly. This should give you a clean view of the brush bar, drive belt and dirt channel. Ensure everything is clean espcially if the brush bar has lots of hair or threads tightly corded around. Then locate the drive belt and check to see if it has snapped. Grasp the beater bar gently upwards and the belt and brush can then be removed. Fit a new belt on carefully and check the tension as it will be tight.
Apr 05, 2009 | Dyson DC14 All floors Bagless Upright...
The brush on my Dyson DC17 Animal does not turn
Remove the plate over the brushbar. Gently clean out debris. Put plate back on,plug in and turn on vac and press brush bar button to reset.
Mar 18, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
63 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
