Question about KitchenAid (KSRD22FKST) Side by Side Refrigerator
Blinking red light on kitchenaid side by side no ice, but still have cold water
As above
  • 12 more comments
  • martha-vila Mar 30, 2008
    Inside the door, on the right panel right there in plain sight. It has a red indicator light, with a blue switch, the words its in the on position, but blinks red, and all our ice is gone in the bucket that sits on the door. I noticed this two days ago. Tried resetting it (if thats possible) by holding it in the off position for 30 sec or so, but to no avail. Also, this seemed to happen when we moved the fridge out to remove wallpaper from the wall but I did a visual inspection and saw no kinks. Model # ksru22fkwhq1 ser SL4943484 manuf date 12/01
    thank you I received the file, I will read it, try these procedures you are referring to, and then post again if I need the help. thanks for your prompt response...
    tech 17, does it matter that I heard some water pouring slowly (not dripping) into the drip pan or is that normal? I seem to remember it doing that one other time before but the ice was fine. martha-vila
  • martha-vila Mar 31, 2008
    We took the backerboard off, cleaned the many dustmites and huge cache of doghair out, and after my husband taking the ice door and motor housing out and resituating it, it looks like it may have been just a case of that sensor mechanism not being able to work from an obstruction of some kind. He said it looked like it wasnt setting level and he repositioned it. Who knew it could be something so dumb. Anyway, I think its fixed now, we listened and the water refilled, the light has gone off and the thing even breathes better! The fan seems to really blow now!! I think it may have done wonders to just clean the darned thing!! Anyway, we thank you very much for your help and will give you an extra high rating for your time and expertise (and the manual you sent)! Thanks again! Martha-vila
    Tech 17, I may have spoken too soon. I just checked and that stupid red light is back on, still blinking. If by chance, I need to replace different components, where do you suggest I buy them from? Is there a parts supplier that you like? I havent tried unscrewing the little doors and checking in there to see what the component looks like. Also, at one of our other homes, we had like a hard water build up in the copper supply line before. Could it be this? I swore I heard it refill when we first "thought" we fixed it. I am going to put this to rest for now, check for ice in the morning and give you an update tomorrow. Sorry.
    Hello not one piece of ice the next morning...I guess I need to keep looking...we could not figure out the barrel/supply hose thing on the back. There is one long plastic hose taped to the back, and one continuous copper pipe all coiled up. Do you think the fittings on that could be corroded? the fridge came with the house and it appears they did NOTHING to service it, otherwise it would have been cleaner underneath.
  • Mikegasior Apr 01, 2008
    Red light is flashing.Twice on pause then repeat.Tried defrosting the top of freezer in case tube was frozen but still no water coming into tray.How much water pressure is needed coming into freezer.Thanks for any info you can give me.Mike
  • rhouck Apr 19, 2008
    I have model # KSRG25FKSS05 MFG 10/03 that stopped producing ice. The water still works but the ice maker is not calling for water. I replaced the water inlet valve thinking that was the problem but it did not resolve the issue. The water line from the valve to the bearing cup assembly is clear as I can blow air through it. The ice maker control on the right hand side of the freezer is not blinking unless I put my finger on the sensor and then it will blink re twice and then pause and repeat. Any suggestions?
  • berta54 Jun 26, 2008
    the red lite is bliking and no ice
  • joelob Jul 31, 2008
    I have the same refrigerator and the exact same problem. I need to know what to do to try to identify the cause and fix it.
  • simardeep Jan 06, 2009
    I have model # kscs25inss01 that stopped producing ice. The water still works
  • bpaal Feb 26, 2009
    Kitchenaid KSCS25INSS00 side-by-side. It is not making ice. When the door is open, the led blinks red. I'm not sure what it means. I've taken everything out of the freezer and let it warm up by leaving the door open - hoping if something was frozen, it thawed. The door is now closed and cooling. Can anyone tell me what the flashing red light means?
  • robert samples May 11, 2010
    the best thing to do in your case is to send you the test procedures as there could be several things wrong with your ice maker its too large for this site to send so if you send me an e mail at ill help you can hold my rating for now till we fix it ok
    where is the red light located in the freezer
I had a blinking light, two flashes then pause, I did two things, not sure which worked, blow dryer to the black tube, and took a Q-tip to the sensor eyes (on both side of the walls), after a few minutes of trial and error, the light went out and I heard the water from the fridge, so hoping this would solve the ice maker issue!
Posted on May 02, 2010
  • 1,314 Answers
Well your just too welcome ive seen a lot of thoose top fill tubes freeze
Posted on Mar 30, 2008
  • robert samples Mar 30, 2008
    that's probably from the defrost system and its normal you can take the fill tube loose from the back at the connector and blow through it if air don't go through water wont yours was made in 2001 in 2002 they revised the beam that you see blinking but to save money you need to test all the systems to nail it could be a bad ice maker motor module could be a bad water valve could be a frozen tube could be the infrared lites are bad but you have the procedures and for what service tech seem to be charging now days it will be worth the effort we can do this im here for you i had a lady that paid a person 300 to fix her wall oven he pulled it out could fix it told her he had to call and get some help from tech service and just left it sitting in her kitchen we fixed it in a day for free read the manuel i sent with a cup of coffee and ask me if you need to know
    now on that water tube connector at the back of the unit it looks like a little barrel at the top of the connector is a brown piece push the clear tube down into the connector and with your thumbnail hold the brown part down then pull the clear tube out to reconnect just push it back in
I'm having the same problem, but a service tech on another board said that the blinking red light is actually a good sign, it just shows that the infrared is working and is looking for its signal
Posted on Jun 14, 2008
Height above sea level of my house in Southampton
3 metres
Geographic coordinates of Southampton, United Kingdom. Latitude ...
Latitude of Southampton, longitude of Southampton, elevation above sea level of Southampton. ... Coordinates of Southampton in degrees and decimal minutes. Missing: my ‎house
Southampton - Wikipedia Southampton is the largest city in the ceremonial county of Hampshire, England. It is 75 miles .... The city walls include God's House Tower, built in 1417, the first ..... [hide]Climate data for Southampton, elevation 3 metres (9.8 feet), 1981-2010 ... The centre of Southampton is located above a large hot water aquifer that ...
Frequently asked questions about Southampton in Queensland - Bonzle > home > homesteads > Southampton
myBonzle menu: Add to my places Add picture Add story Add note. Skip to map ... What is the elevation/altitude/height above sea level of Southampton? Southampton is at an ... Old Parliament House, East Parliament House Picture relating to ...
An Oceanfront Home Built Above Sea Level ' Southampton, House ...
Southampton · House · House beautiful ... Balconies · An Oceanfront, Southampton Home Built 17 Feet Above Sea Level ...
Height above sea level of my house in Southampton Google Search
Oct 16, 2017 | Computers & Internet
Perform Nozzle Check Pattern of Canon Inkjet Printer without Computer
BJC3000 and above,S300 and above, i450 and above,Pixma ip2000 and above
  • Set A4 paper in paper tray.
  • In stand by condition,hold down Resume/Cancel button until LED indicator blinks twice then release the button.
Pixma ip1200,1300 ,1600,1700,1800,1900,2200
  • Power on the printer, immediately after printer standing by press Resume/Cancel button 5 times within 2 seconds.
The printer start printing nozzle check pattern after procedures above performed properly.
on Dec 02, 2008 | Canon S400 InkJet Printer
Question mark key and slash plus 2 keys above it have turned to eee with accent above - I suggest you check out this article - or you can google yourself - How do I change my Keyboard Mapping? and then see what comes up.
I would appear that you have somehow setup something on those keys - e with an accent above is most likely French
May 28, 2016 | Logitech Computers & Internet
Why is water leaking into cool (deli) drawer?
Hi,have you got a drain at the back of the fridge just above the veg draw,if yes is there eney food above that that is tuching the back wall of the fridge above the veg tray,if so then the water that runs down the back wall will be going onto the food that it tuches and into the veg draw,hope this was some help,all the best.
Sep 16, 2015 | Refrigerators
I just bought a 46 inch SAMSUNG LED HD TV from Best Buy and will be mounting it on a brick wall above the fireplace. The fireplace has gas logs with a an 8 inch mantle that extends 8 inches off the...
it is not safe to mount the TV 8 inches above the mantle.
Secondly, the heat will certainly be a danger if the TV is mounted above the mantle.
I would advice you look for another position to mount the TV.
I hope the above is clear.
Sep 27, 2011 | Televison & Video
What is the fluid capacity for a 1986 monte carlo ss
Engine Coolant - Volume: 12.00QTS. ( 11.4L ) - [50/50 mixture of Ethylene Glycol Base Antifreeze and water] - 4.3L Eng - [GM Specification 1825-M.]
Engine Coolant - Volume: 16.30QTS. ( 15.4L ) - [50/50 mixture of Ethylene Glycol Base Antifreeze and water] - 5.0L Eng - [GM Specification 1825-M.]
Engine Oil - Volume: 4.00QTS. ( 3.8L ) - [SAE 5W-30 (Preferred) (Below -20Deg.F to Above 100Deg.F), 10W-30 (0Deg.F to Above 100Deg.F), 30 (40Deg.F to Above 100Deg.F)] - 4.3L Eng
Engine Oil - Volume: 4.00QTS. ( 3.8L ) - [SAE 5W-30 (Preferred) (Below -20Deg.F to Above 100Deg.F), 10W-30 (0Deg.F to Above 100Deg.F), 30 (40Deg.F to Above 100Deg.F)] - 5.0L Eng
Fuel Tank - Volume: 17.60GALS. ( 66.6L ) - 4.3L Eng
Fuel Tank - Volume: 18.10GALS. ( 68.5L ) - 5.0L Eng
Feb 07, 2011 | 1986 Chevrolet Monte Carlo
How to calculate above ground volume. 60' x 30' x 7' house with sloped side yard. house is 1' above ground in front and slopes to 7' above ground in the back. For sizing heating and air conditioning...
Total volume of home is 12,600.
total volume below grade is (6' x 60' x 30')/2 = 5400.
total - below grade volume = above grade volume
7200 cubic feet.
Feb 22, 2010 | Carrier Heating & Cooling
Media show 4 will not start. It says i dont have the right vga hardware or driver to run media show
I checked the system requirements for this software to run in youir PC.
Do you have any of the following requirement
  • Minimum Intel 945 GM and above
  • Minimum Nvidia Geforce 6600 and above
  • Minimum ATI X1600 and above
  • 64MB-VRAM and above
  • Some animation effects may be turned off or degraded for lower-end graphics system
Jan 22, 2010 | CyberLink MediaShow 4 for PC
Acer Extensa 2000/2500 Series --- Far right launch button above the keyboard
Acer Travelmate C Series ---Far left hot key and then choose WLAN from menu that appears
Acer Aspire 1000 Series --Launch Keys above the keyboard
Acer Aspire 1640Z ---- Launch Keys above the keyboard
Acer Aspire 1690 ---- Launch Keys above the keyboard
Acer Aspire 2000 Series ---- Button on the front of the laptop
Acer Aspire 2012 ---- Launch Keys above the keyboard
Acer Ferrari 3000 ---- Button on the front of the laptop
Acer Ferrari 3020 ---- Button on the front of the laptop
Acer Ferrari 3400 ---- Button on the front of the laptop
Acer Ferrari 4000 ---- Button on the front of the laptop
Dec 30, 2008 | Acer Aspire 5003WLMi Notebook
Htc p3450 touch gprs and mms settings
you need to get the settings from your service provider (people who supply your sim) and enter the settings into the connection settings screen on the phone
May 23, 2008 | HTC Touch P3450 Smartphone
KitchenAid (KSRD22FKST) Side by Side Refrigerator Logo
5,921 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
