Whirlpool washer door will not unlock
I have a front loading ge Whirlpool washing machine. I ran a rinse and spin cycle but the door will not unlock. I am unable to change any of the settings or open the door.
  • 343 Answers
Most likely the 'interlock' which prevents the door from opening during wash has failed. This is an electrical component and probably needs to be replaced...Not a big job for a tech...Good luck...Nomess
Posted on May 16, 2010
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Jan 28, 2016 | GE Washing Machines
Door won't open on front load washer
How to Unlock a Whirlpool Duet Washing Machine ' Home ...
homeguides.sfgate.com > Mortgages > Mortgage Options
If you must manually unlock the washer door after each wash cycle your drain ... to Change a Water Inlet Valve for a Whirlpool Duet Front-Loading Washing Machine ...Causes and Repair for a Whirlpool Washing Machine That Won't Spin or ...
How to open a washing machine door that won't ... - YouTube
? 3:57
https://www.youtube.com/watch?v=-65_eoT6zuk
Aug 22, 2013 - Uploaded by how-2-repair.com
Your washing machine door won't open this video will show you a technique ..... Front Load Washer Repair - Not Draining or Spinning - How to Unclog ... Washing Machine Repair - Replacing the Door Bellow (Whirlpool Part
Nov 05, 2015 | Whirlpool WFW70HEBW Duet 4.1 Cu. Ft. Front...
Just bought a front load whirlpool wash machine. when i turn it on it locks door then unlocks door, it does this 2 to 3 times then the washer fills with some water only spins about 3 times then it waits...
This washer will stop and start a number of times during fill as it is sensing how much water it needs. Also you must hook both water line up and have both on. Also you must use HE soap and very little of it.
Feb 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
GE front load washer will not complete the rinse & spin cycle
1) 1st check the filter under the machine (it unscrews behind the access panel 2) open front door and pull back the rubber membrane to see metal and clean out the debris blocking drain holes 3) remove the drain hose from the machine (spring clip) and try and run water thru it and keep blowing out the junk and re-attach 4) run the machine thru 2 cleaning cycles w/bleach and without bleach 5) start using less detergent
Apr 09, 2010 | GE WSXH208A Front Load Washer
My Whirlpool GHW9250ML is having problems spinning
My Whirlpool Front Load Wasehr Model# GHW9250ML is having problems spinning on the final rinse cycle. The machine shuts down and the letter F appears on the digital read out.
Mar 06, 2010 | Whirlpool GHW9250M Front Load Washer
Ge front load washer won't go into rinse cycle.
Check the cold water hose. My brand new machine had this behavior until I discovered a kink in the cold water hose - works great now.
Jun 03, 2009 | GE WSXH208A Front Load Washer
Door will not unlock
You should be able to do this by removing the top of the unit by removing 3 or 4 tork/hex head screws in the back at the very top , then slide the top back and it should come lose.
Let me know how this works.
Phil
Apr 10, 2009 | Whirlpool LHW0050PQ Front Load Washer
Door unlocks and won't spin or drain
it sounds like a clogged filter
Please remove the filter on the side of the machine or the front.
Make sure you have towels handy.
Clear the filter out. If your pump cant empty the machine out you will get these problems
Make sure waterline is not obstructed
Apr 15, 2008 | GE WSXH208A Front Load Washer
Door on washer will not open
Select Drain/Spin to remove any water remaining in the washer. The washer door wil unlock at the end of the spin.The washer door will not unlock if the unit has not drained.
Nov 09, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
