Question about Magic Chef 31000 Gas Kitchen Range
My pilot light comes on< but the oven will not
Magicchef gas range - my pilot light comes on but the oven will not light. I got a whiff of gas when pushing the thermostat in. I am not familiar with gas ranges as I just moved into this home which already had the range. It is an older model I would say 10 yrs or so. The cook top works fine just the oven. The pilot light gets warm but no flame. I am also concerned about safety/gas leaks but mainly due to not being familiar with the gas range.
  • Magic Chef Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Posted on May 15, 2010
2 Suggested Answers
  • 18 Answers
SOURCE: My pilot light comes on< but the oven will not
igniter is weak,replace it
Posted on Mar 28, 2010
I have a gas stove/oven, when I turn on the oven the pilot light comes on but the burners don't ignite to heat up the oven. was told that is was not the element if I have a pilot light ????
Heater elements are found in electric ovens, you have a gas oven. It sounds like your main gas valve is not opening because the pilot would light it if it was open. It could be the gas valve itself of the flame sensor. Best to get a tech on it.
Jan 28, 2014 | Frigidaire FGF337BC Gas Kitchen Range
Tappan 32-1272-10/07056-8509-4080 gas range/oven pilot light works,main oven burner won't come on
You will need to look and see if the igniter is glowing a bright red. If it is weak, the oven will not light. Here is the igniter if you need to order it.
Also check and make sure your getting 3.2-3.6 volts AC to the valve.
Dec 01, 2012 | Tappan TGF320 Gas Kitchen Range
I have a Garland Sunfire 36 inch gas Range. oven does not come on again after reaching temp.
You probably have a bad thermocouple. Try cleaning it off with sand paper. It's the part that the pilot light is igniting.
Mar 15, 2012 | Garland SunFire SX-10-26 (Gas) Stainless...
The pilot light on the oven is on how ever the burner will not come on when the oven is turned up.
Their is 2 possible things that are causing the oven to not heat.
1) the pilot burner is clogged with build up and not burning corretly...the standing pitol light is small and when the oven is turned on the pilot enlarges and heats a small bulb connected to a tube on a gas valve,if the pilot burner is clogged it will burn the small pilot but will not enlarge to heat that bulb so the gas will flow to the main burner.If that is whats happening the pilot burner needs to be replaced.
2) the pilot burner is properly heating the bulb connected to the above mentioned gas valve but that gas valve is bad and not opening once the pilot has heated the bulb..so in that case that gas valve would need to be replaced
GENE
Sep 17, 2011 | Premiere Ranges GCK100 Gas Kitchen Range
I have a Frigidaire gas range, model #FGF316BSA. When I attempt to operate the oven it won't light. The glow bar comes on but nothing happens after that.
Hi
Thanks for using FixYa. From what you have described it seems that possible oven control is not sending gas for the pilot light. The pilot light works but no main burner ignition - possible pilot assembly is dirty and the pilot flame is too small, safety valve and thermocouple is faulty, the bulb from the safety valve is out of position and the pilot flame is not touching the thermocouple bulb. Some ranges use a standing pilot light ( small flame is on all the time ) while others use an spark ignition to light the pilot light flame and the pilot light flame heats up the thermocouple bulb to allow the main gas to flow through the oven burner.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 15, 2010 | Kitchen Ranges
Garland H283 gas range. Right oven wont come on.
I just read this here:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=13&newsdesk_id=117
that explained how to test if the problem is the thermostat. It said to watch the pilot as you open the thermostat to turn on the oven. If the thermostat is ok the pilot should get bigger, if the pilot does not change when turning on the thermostat, then the thermostat is bad.
Mar 04, 2009 | Garland H283 Gas Kitchen Range
Where is the pilot light for the oven?
Look inside the oven where the burners come into the oven. Right at that point you should find the pilot light. Here is where you light the pilot.If you smell a lot of gas when you open the door, turn off the gas altogether and let it dissipate. Then turn ot on and then you can light it.
Jan 30, 2009 | Tappan TGF320 Gas Kitchen Range
Commericial stove oven problems
the end of the thermo coupling needs to be in the flame of the pilot light
Apr 22, 2008 | Garland H283 Gas Kitchen Range
Magic Chef 31000 Gas Kitchen Range Logo
233 people viewed this question
Top Magic Chef Kitchen Ranges Experts
paulcarew
Dan Webster
Dan Webster
Mike Carew
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
