Question about Whirlpool Duet GHW9150P Front Load Washer
It makes alot of noise when its in the spin mode
  • Whirlpool Master
  • 43,501 Answers
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Posted on May 15, 2010
Wash machine won't spin all the time and makes a loud banging noise.
Check to make sure that your clothes are not piled to one side causing the load to be off-balance. If that does'nt fix it then, It may be that your machine has a balance stabilizer on it that has worked its way loose or even off.
Jun 11, 2012 | Frigidaire Affinity ATF7000E Front Load...
When it goes into spin sounds like a plane taken off, alot of noise
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
heatman101
Apr 17, 2011 | Kenmore Washing Machines
Washer making alot of banging noise, I this the part that spins the clothes is off its brackets or somthing. The spinner is very loose.
Check out this tip I wrote about the noise and vibration that front load washers can make..
heatman101
Nov 16, 2010 | Kenmore 43142 Front Load Washer
HE2 Plus Front Load Washer: It vibrates and makes alot of noise....
heatman101
May 05, 2010 | Kenmore HE2 Plus Front Load Washer
Spin cycle is of balance
stpnlok,
Did you follow my post at this link Clutch repair post for your repair ?
I’m a little confused by this description “”there is what seams to be a sealed plastic ring on the top of the stainless drum is there suppose to be liquid in it there is a liquid in there””.
Maybe go to searspartsdirect.com and look at the exploded view and give me a p/n.
“”I had to replace the top bearing on the "drive shaft" it was making alot of noise the cluth assembly seamed ok but still kicks out on spin cycle””
Are you saying you replaced the upper One-Way Roller clutch bearing assembly only? If so that tells me you purchased the whole clutch assembly. I know of no parts supplier that sells the upper One-Way Roller clutch bearing assembly alone. We Are talking about a FAV6800A machine correct? To make sure I’m following here is the clutch parts view.
Here is pic of the same clutch causing dC errors prior to clean up.
Upper One-Way Roller clutch bearing
Is this the part you speak of ""I had to replace the top bearing on the "drive shaft" it was making alot of noise the cluth assembly seamed ok but still kicks out on spin cycle""
If we are talking about a FAV6800A or FAV9800A I can help you.
Let me know....Rich
Dec 08, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Wont spin and makes alot of noise
You could check if its drum by removing the belt turn drum by hand if its okay no noise check motor pulley ....is motor ok ?
Nov 17, 2009 | GE Profile Prodigy WPSE4200A
Not spinning when on Regular wash mode.
sounds like the agitator is damaged and needs to be replaced
Jun 21, 2009 | Washing Machines
Bangs in Spin Cycle even Empty
alot of people don't level there machine properley pull out a level and level the machine what it is when the machine gets up to speed the drum is not level
Feb 12, 2009 | GE Energy Star WCVH6260F Front Load Washer
Load noise in final spin cycle
turn the tub on the inside if it feels ruff as it turns and makes a noise then most likely you have a bad rear bearing, if it is smooth in turning and no noise then turn to drain or spin possibly something stuck in drain pump. the drain pump will start up first if you hear the noise then the drain pump is accessed from the front lower cover, if its the rear bearing probably not worth fixing about 400.00 in parts and alot of work.
Feb 14, 2008 | Frigidaire FTF2140ES King Size Front-Load...
Whirlpool Duet GHW9150P Front Load Washer Logo
151 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
