Question about Maxent MX-27X1 27 in. HD-Ready LCD Television
Screen goes black, hit the input button and it changes....then black again
My Maxent has been fine until we turned it on and the screen remained black. I changed inputs and the screen remains blue for a second then returns to black. I unplugged the unit and left it for over 24 hours and plugged it back in, no luck same issue.
There was a power outage the night before the issue, however, the surge protector it was on did not trip and all the other devices work fine.....Any ideas?
Thanks 42PULGADAS to party and its cost of shipment to Bogota Colombia could please provide to me to the cost in dollars of the screen of TV MAXEMT MODEL P4202YDOS thanks Attention(or attn). CARLOS EMILIO MONTOYA
EMAIL
[email protected]
Posted on Aug 18, 2008
SOURCE:
I had shut my tv off and was working fine before I had done so: I whent to turn it back on a few hours ago and when I turn it back on it goes to a blank black screen.
Sounds like the input might be incorrect? I would turn it on and hit the input button, make sure it is set where you want (for example, hdmi 1).
Oct 23, 2017 | The Computers & Internet
Maxent 42" flat screen M # p4202yd04
reseat the the LVDS cable inside the set. this is the cable that connects the main board to the panel. if that does not work replace the LVDS cable and the main board.
Mar 05, 2008 | Maxent MX-42HPM20 42 in. Plasma HDTV
Maxnet mx-26x3 tv toconnect toan HDMI input
Maxent ,mx 26 x3 turns on for 5sc.( all white) then picture flickers and screen goes black.. green light on throughout..none of button on the remote or the tv will work expect the power .i wonder is their a way to reset the tv?
Jun 10, 2011 | Maxent MX-26X3 Television
Clear a plasma monitor
I presume you have burned in an image from some source? Plasmas are very sensitive to burning in so be careful when hooking up a device that doesn't have pixel shift or dimming. Think about how a DVD player splash screen looks.
You will need some sort of source device that can give you WHITE and BLACK. If you have a VGA input on your plasma (more than likely) hook up a computer to it using the PC input and bring up PowerPoint. Bring up just a blank new presentation. Hit the F5 button or click on the tripod screen button. This will bring up the full display screen, which should be white. If not hit the "W" key on the keyboard. If the burned image shows up as a gray or black image, leave it on for a few minutes and then check it periodically.
f you don't see a burned image when in WHITE mode, hit the "B" key. This will bring up a BLACK screen. Check your screen again. Keep doing ot until the screen is clean. By the way, this will not completely remove all burned in images.
Nov 25, 2010 | Maxent MX-42HPM20 42 in. Plasma HDTV
Montior goes black i turn off the monitor and turn it back on i can do about 2 things and screen goes black again repeat this as many times as i want. Gateway FHX2300 monitor
My monitor has been switching connections on me randomly. Hit the menu button. The one to the left of the power butter when facing the screen. Hit the left arrow twice then hit the menu button again. This will open up the screen where you can choose one of three inputs. I'm going to assume that it is on the incorrect input so use the arrow keys highlight what input you are using and the hit menu button again and your screen should return to normal. Mine only does this randomly when it goes into screen saver, hibernate or sleep. I don't know how to permanently get it to stop doing it though.
Aug 23, 2010 | Gateway FHX2300 LCD TV
Maxent mx-42vm11 screenflashes black and acts like it loses input
Check on ebay for the repair kit if you are versed with a soldering iron.
Apr 09, 2009 | Maxent MX-42HPM20 42 in. Plasma HDTV
Black screen when trying to adjust settings
Double check to be sure the TV is on the proper input.
Can you still play a DVD? If DVDs still play, reset the system by unplugging the power cord for a minute. The menus should return.
If DVDs don't play either you may have accidentally changed a video setting. Fortunately you can access the video settings from series II and III systems with the buttons on top of the console. If would be best to call Bose tech support so they can walk you though accessing the video settings. 800-367-4008
Sep 17, 2008 | Bose 3 2 1 GSX System
Another question about maxent plasma monitor
Yes problem is repairable sounds like the mainboard (video) needs replacement because the rgb is part of this board along with the rest of your inputs this should fix your problem. There are some models where rgb is seperate but not many I will need the model number of your Maxent to be of further help.
Sep 09, 2008 | Televison & Video
TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Jun 15, 2008 | Mitsubishi WS-73713 73" Rear Projection...
Maxent MX-27X1 27 in. HD-Ready LCD Television Logo
274 people viewed this question
Top Maxent Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
