Question about Danby DPAC8399 Air Conditioner
Is it possible to use the airconditioning and dehumidify at the same time?
  • 53 Answers
Yes of course ,the airconditioning actually condiontions the air just like a humidifier,as though a humidifier takes moistures out of the air.an the a/c supplies the cooler dry air ...so your answer is yes it okay to run both systems.
Posted on May 15, 2010
  • calvin flanagan May 15, 2010
    yes of course ,the airconditioning actually condiontions the air just like a humidifier,as though a humidifier takes moistures out of the air.an the a/c supplies the cooler dry air ...so your answer is yes it okay to run both systems.
2 Suggested Answers
SOURCE: is it possible to use the airconditioning and
Yes
Posted on Mar 22, 2010
HD456E dehumidifier shows it is on but nothing happens - no compressor running. The humidity is 75% in basement and have it set to run at 45%. Any possible fix or is it time to replace eventhough it is...
You can normally hear a humidistat open and close if you listen closely. Also, the water tank has either a float or pressure switch that will shut it down.
Jul 30, 2013 | Haier HD656E Dehumidifier
Dehumidifier runs, but we hwve it set at 35% humidity and it just runs a brief time and then shuts off. is it possible that our air is just dry? It is a cold winter and heat is at 70 in home.
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jan 08, 2011 | Maytag M7DH65B2A Dehumidifier
2003 buick rendezous windows frost up, motor seem to heat up ok 195+, all ready install new stat. getting hard to see here in Minn
Actually the defrosters rely on the airconditioning evaporator coil to remove moisture by freezing it on the coil, kind of a dehumidifying effect. The heater will still put out warm air while it does this. If your airconditioning system doesnt work, chances are the defroster wont be very effective.
Jan 09, 2010 | Buick Rendezvous Cars & Trucks
Where to hook up drain hose
On the bucket there should be a cap. If you remove it your hose can attach to it. Run the hose top a drain. If possible, raise the dehumidifier so the water drains properly. From time to time, pour a little bit of bleach into the hose to keep mold away.
Sep 29, 2009 | LG LHD65EBL Dehumidifier
When I turn the airconditioner on or the defrosters, the heater/airconditioning fuse blows? Any thoughts on where to start looking?
Problem is in the a/c circuit. Any time the defrost is on the a/c compressor will cycle on & off as it is used to dehumidify the air directed to the windshield. That's why the fuse can blow even in defrost mode.
Unplug the power connector at the a/c compressor and see if the fuse still blows. If not, then with a dmm or vom test a/c clutch winding for short. If ok, then test clutch diode for short. The diode is usually mounted at the clutch winding, but I've seen Chevy's with a diode that plugs into fuse/relay block under the hood. I have replaced these so don't overlook it.
If fuse blows with compressor unplugged then first check circuit between compressor and a/c relay (power side) for a short. It's possible for the wire to rub a bare spot in the insulation along it's travel along the block, bracket or manifold to the compressor. If ok, then test from relay (winding side) back to switch.
Good luck.
Jun 24, 2009 | 1990 Chevrolet K1500
1994 Toyota aircondition probelms
i think check for possible malfuntion of condenser fan
Apr 13, 2009 | 1995 Toyota Camry
Comfort-aire dehumidifier 501 cycles on and off
It is possible that the humidity is below the set point of the dehumidifier. They will run for a short time until they get a true fix on the actual humidity then shut down.
Jun 28, 2008 | Comfort-Aire Dehumidifiers
Danby DPAC8399 Air Conditioner Logo
96 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
