Question about Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Dishwasher i took it apart and cant get the door back together
  • Anonymous Apr 10, 2008
    I have a Bosch dish washer model # SHU3006UC-06 And when I took the door apart to replace the soap dispencer (which was a very hard problem to get the new ont to fit)Thier were 2 plactic pc. that fell on the flor and I do not know where they go. can anyone help.
    Marv at marvin.pfeiffer@sbcglobal.net
These push on to the hinges with the angled side pointing outwards.
Posted on Apr 27, 2008
It's Bosch model HBL 5650. Went to clean door. Took it apart and can't get it back together
then you need to call a repairman . our arms are too short to assist you
Oct 25, 2016 | Bosch Ovens
Took apart to clean and cant put back together
What part(s) do you need assistance with exactly?
Aug 17, 2012 | Frigidaire 24 in. FDB1050RE Built-in...
Replace cover on Bosch Dish washer> Now a C6 code is displayed in the window
I had the same problem after replacing the white panel on my Bosch SHE45M02UC with a stainless panel. I got the C6 error code. I called Bosch customer service twice and neither rep was helpful. One guy told me he didn't know what the C6 code meant. He suggested that I call a local appliance repair guy and he would know what the code meant. I replied, you mean to tell me you work for the manufacturer of the dishwasher and don't know what the error code stands for but a local repair guy that doesn't work for Bosch does?
After all this frustration, I took the panels off and tested the dishwasher with no buttons. It worked fine! Turns out, each identical button isn't identical. Each one is labeled A-G. After putting it back together, no more C6 code! On a side note, try reseting the dishwasher. With the dishwasher on and door closed, hold down the cancel/reset buttons for 5 seconds and release. The disher should drain and reset.
Mar 27, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Having trouble putting door together
Whenyou took the door apart did you take note of how so you can reverse the proceedure Sorry it is difficult to explane in words on how to put a door together all I can say is try placeing the panels from the top down and bottom up then if anything works put in all the screws halfway then after all the screws are in then tighten them as evenly as possible
Jan 22, 2009 | GE Nautilus 24" Built-in Dishwasher
BOSCH SGS6302GB
Hi nikkij
It is simple to put them back on. the plastic pices fit on the bottom of the hinges. there is a cut out where they fit in. when you look at the door at the bottom you will see the hinges and the cut outs, the plastic pices fit in the cut outs flat side in. hope this helps
Sep 15, 2008 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch Door Handle: Loose
I had the same problem with my Bosch dishwasher.I came to this web site to find out how to get the door off.I took the experts advice,placed 4 pillows on the floor in fromt,opened the door,took out the screws and the front panel dropped down.It was so easy,the plastic spacers stayed in place.I put a little J B weld on the handle screws and tighted the handle and put everything back together,12 minutes tops.Thanks for the help,thankful in Georgia
Jun 09, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch 3000 dishwasher
Don't. Just attach your hose and the end of the Bosch hose together. Just wind up the Bosch hose and tape it to the back of the machine.
Jan 15, 2008 | Bosch 24 in. SHU66C05 Stainless Steel...
Bosch Dishwasher
Hi ED, It sounds like a real problem here. If the springs are still in one piece, my best guess is to to remove the springs from the door. Then attach the springs to the dishwasher body first, then reattach the spring to the door. Not an easy job, good luck. If you have further problems check with www.repairclinic.com, as the repairguru there may be of more help.
Sep 25, 2007 | Bosch 24 in. SGS43C12 Classixx...
Bosch 24 in. SHU43 Built-in Dishwasher Logo
99 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
