Question about HP Pavilion zv5430us (PR466UAA) PC Notebook
HP zv5430us laptop has no video. Blank
Hp zv5430us laptop has no video. Blank Screen. It Started out with a checkerboard pattern on screen and latched up the computer. Rebooted and it worked fine a few days. Did this a few times again until finally it went totally blank with no picture at all. Tried the external monitor 15pin video out jack. It doesn't work either. Any chance reloading original operating system and drivers could fix it or is it the motherboard?
  • HP Master
  • 2,080 Answers
Take the main battery out, does it run everytime on a/c line pack
power.??? this is first test of any laptop. test 1.
sure there is a chance but that is not step2..
test test to is while doing test 1, see if there is the screen prompts
in text as it did its whole life. "hit ESC key to enter setup(bios)
can you get the screen to show above,battery out?
yes, good do the ESC key, BIOS entry, .see BIOS work.
great , if yes, the the HDD is not booting windows? what?
NO, SCREEN STAYS DEAD NO MATTER WHAT.
Suspect now is the power pack. as low as $15 cost.
the pack is 19vdc, does it measure that? if not its bad. (or the pc is shorted)
at HP, the support ended. and is offically Retired
https://support.hp.com/us-en/retired-products
got any beep codes , or keyboard blink codes there?
does the fan run? and blow, are the vents lint free or packed.
Posted on Jul 14, 2017
  • Larry Ng
    Larry Ng Jul 14, 2017
    take the main battery out, does it run everytime on a/c line pack
    https://support.hp.com/us-en/retired-pro...
2 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: HP zv5430us laptop has no video. Blank
The laptop has a built-in video card and the video RAM uses part of the main RAM.
First, re-seat the RAM modules and if the laptop still does not boot up normally then remove the RAM and get it tested at your friendly computer repair shop.
If the RAM is OK then connect an external monitor to the laptop, power up the monitor first and then the laptop. The video data should divert to the external monitor automatically, if you do not get any video image on the monitor then the video card in the laptop is faulty and a motherboard replacement is required.
A replacement motherboard may not be a cost effective solution and If it was me, I would put my money on a new laptop. I would then remove the hard disk and insert it into an USB adapter case and use it as an external USB hard drive.
Posted on Mar 22, 2010
Checkerboard screen pattern looping at powerup
Try hardware reset.
Remove the battery and power adapter and hold power button for about a minute.
I fathat does not work, remove one of the memory chips and try it again. If that does not work, switch the memory out, and try the other one.
Apr 08, 2014 | HP Computers & Internet
What steps needed to get the blank screen on HP G70-257CL working?
Check the video connection that plugs onto the motherboard.
Oct 15, 2012 | HP G70-257CL Laptop Screen
HP Pavillion 500series to Panasonic TV with DMI port, hooked the HDMI cable from it to the tv, blank screen, made sure the tv was on HDMI, blank screen, unhooked the monitor, blank screen, hooked the...
Most laptops have a "toggle":
* output video only to internal LCD screen,
* output video only to external HDMI port,
* output video to both internal & external.
Set the "toggle" to the best value.
Jun 15, 2011 | HP Pavilion dv9000z Notebook
BLANK SCREEN ON MY hp compaq nx9420. my laptop was working fine and then when restarted I got a blank screen. The power LED and cahrging LED both light up but screen remains blank. have changed the video...
Did it display any video at all with boot options or HP logo? Any POST test or beeps after you started the laptop?
Try removing the power ac adapter and battery. then only boot it up with just the AC adapter (no battery).
Good Luck, JAJ
Mar 30, 2010 | HP Compaq nx9420 Notebook
Mar 22, 2010 | HP Pavilion zv5430us (PR466UAA) PC...
Hp 550 laptop; frozen screen then when re started blank screen
1. Can you get to any screen in the BIOS?
If so, your screen is ok. This may sound silly, but, power OFF and remove & re-seat the memory modules. Video uses some of that.
=== OR ===
2. Connect a monitor to the VGA connector on the back and use the laptop that way and so you can further debug the system
Sep 21, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Hp mini screen is blank
Hello imlapd. If you don't even see words on the screen when you first turn it on (the BIOS puts things on the screen before it boots to Windows), then there are 2 possible causes. First, the video output or something else on the motherboard is bad. Second, the LCD display (the laptop screen) has failed. The cost to fix either one of these will be close to what the laptop cost brand new if not more. The good news is, if your HP Mini is less than a year old or you got an extended warranty, HP will fix it for free. You just have to call their customer service.
800-HP invent
or
800-474-6836
Be prepared to provide the following information: Serial Number (S/N), product name, model number, and a brief description of the issue.
Aug 26, 2009 | HP Mini 1000 Netbook
Screen problem HP DV9000
Please perform system restore on your pc. Restore to factory default and remember to backup your documents.
rate this
Jun 04, 2009 | HP Pavilion dv9000z Notebook
Partial blank screen...
You can try reinstallaing video drivers by downloading then from
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&lang=en&product=65203
or
if this does not rectify problem, then it could be due to a virus or spyware. Use some good antivirus like Kaspersky to get rid of them.
last option could be to contact
Contact HP tech support
May 24, 2009 | HP Pavilion xh555 (F3929H) PC Notebook
HP Pavilion zv5430us (PR466UAA) PC Notebook Logo
54 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
