Neo mp3 players
A little while a go i notyiced that only one of my headphones was working. after testing them on other things i realised that it wasn't the headphones that were the problems, since one of my friends had dropped my mp3 player a little while before i wondered whether something had come loose and therefore wasn;t connecting properly (Sure enough i can hear somehing loose inside it). however, the jack on the player is small so has an adapter with it so that i can use other types of headphones and speakers. this adapter can also be used for the music player on my phone and as it turns out only one headphone works so now i can't work out how to find out which bit needs fixing or replacing. i don't really want to have to take the player apart if all i need is a new adapter.
Only one of my headphones is working i started to notice it a couple of days ago what does that mean?
Posted on Jun 17, 2008
SOURCE:
The headphone port is not work properly
I suggest you try a different head phones to test your MP3 player. The fault may not be the headphone port, it may be the headphone usually the wires near the headphone plug break.
Oct 01, 2010 | SanDisk Sansa c250 (2 GB) MP3 Player...
Headphone port is not working properly. when using normal headphones the sound cuts out and comes back after manipulation the jack.
check the headphone plug likewise the headphone port. Also test the player with another headphone.
Best regards.
Feb 09, 2010 | Sirius STILETTO 100 MP3 Player
I put the ear plugs in and nothing happens.. not
To get the basics out of the way, is the volume turned up and not muted at all... if it's turned up then try another pair of headphones that you know work in something else or test these headphones in something else...( cd player, radio etc.) use a pair that you know work to retest your mp3. plug them in, turn it on and play a song the gently wiggle the end plugged into the player back and forth. If you hear a crackling or snippets of song, then it's probably the jack inside the player....try these things and get back.
PS. post the make and model of your player, it helps with problem identification
Feb 20, 2009 | Coby MP-C883 MP3 Player
Headphone Malfunction
It's probably the jack inside mp3 player who needs a little bit of solde on his contact.
open it and good luck
Dec 20, 2008 | MyMusix PD-6070 MP3 Player
Side light is not turning off and i can't switch the player on
i put the player in the usb port and the light came on but after a little while i realised it was not turning off so i took the player out and tried to switch it on. that didn't work and the light's still not turning off
Feb 22, 2008 | Samsung YP-U3 MP3 Player
Headphones
The headphone jack is loose from the circuit board.
If its less than 1 year old, SanDisk will replace it.
Otherwise, you can take it to a electronics repair shop, or someone who knows how to solder.
Best of Luck.
Oct 14, 2007 | SanDisk Sansa e130 MP3 Player
Cannot hear music
The bad news is that your headphone jack is most likely shot. The soldered connections inside are most likely broken. This is not repairable generally, at least not for a cost that would be reasonable. Music will play through your computer because it can be read off your player through the USB connection. Use it as a data storage drive and buy a new one, or a used one. I've seen used T30s on Amazon for around $30 to $40.
Mar 26, 2007 | iRiver T30 MP3 Player
49 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
