Question about Sony Handycam DCR-TRV720 Digital Camcorder
My TRV720 LCD screen is getting power, however has
My TRV720 lcd screen is getting power however has vertical stripes. It appears that the connector ribbon on the board side is not making good contact. Suggestions? Sony offers flat-rate repair that is really high. Is there a source for a replacement lcd? The camera otherwise works perfectly and I hate to buy a new one since I have hundreds of hours of tape and many accessories...
  • 473 Answers
SOURCE: Sony TRV-19 Camcorder - Black screen in camera mode
Fixed it, at least temporarily I had the side off my trv250 examining it, especially the CCD connection. I had read the post about soldering a capacitor to pins 1 and 3 (from the left) on the bottom row. I didn't have the specific capacitor on hand, but I started touching some of the small ones I did have to those pins. I found that after I touched a 100uF, 10V cap to pins 1 and 3 the picture suddenly came back to life and stayed that way after removing the cap. I have no idea how long this will last, and I've set up the cam on a tripod in the livingroom with the LCD display facing me so I can monitor it. If you, like me, figure you have nothing else to lose, you might want to give this a try. Note: my camera was suffering from the green smeary horizontal lines problem, and wasn't completely black. I'm not sure if this makes a difference or not.
Posted on Sep 14, 2005
SOURCE: Video screen has horizontal stripes when viewed
Mine is doing the same thing... Did this solution help you?
Posted on Sep 03, 2008
  • 30 Answers
SOURCE: Sony handycam LCD problem
1-864-761-11(FP185)
Part no.of flexible cable of DCR=HC21
Posted on Jun 09, 2009
  • 8 Answers
SOURCE: I cracked the viewing lcd dusplay on my sony
i couldnt agree more
mostly this cameras wont worth such an expensive fix
Posted on Oct 21, 2009
Testimonial: "Thanks for the backup opinion."
SOURCE: Sony HDR-HC3 LCD touchscreen blacked-out.
I've experienced the very same problem a couple of days ago. Can't believe my bad luck cause I'll be going on holiday in a couple of weeks. I've seen a technican this morning and he advised me to purchase two parts. They're the 186992511 PWB FP-412 Flexible and the A1174647A Mounted C.Board FP-372. I've keeping my fingers crossed and pray that he's right.
Steve
Posted on Feb 26, 2010
5 inch wide blue vertical stripe on lcd
It can be but rarely the main board, most of these sets have either one or two boards that drive the image on the screen, different names like T-con or Y out etc. the right side board could be the problem or a bad connector or ribbon cable for that side of the screen unit.
Several possible cures and none are a snap to find in most cases.
Dec 06, 2012 | Toshiba 46LX177 46 in. LCD HDTV
My Viewsonic N3751W lcd TV has a @2" vertical
you need to clean the vedio connector properly inside your tv , if you dont have good idea about electronic you need a technicien
Dec 29, 2010 | ViewSonic N3751W 37 in. LCD Television
I have a HP 2035 lcd monitor that has a 3cm yellow vertical stripe running though the middle of the screen.
I have smth same... my monitor as gets warm, has a vertical stripe that become blurry, then it becomes worse till the white or black striped, like a zebra line appears? Some electricians have changed the condensators, have put the radiators to reduce the heat, hell knows what is with it, I really like it but no1 can fix it... any1 have any ideas?
Aug 29, 2010 | Computers & Internet
Lcd screen getting broken!
you need to replace the LCD panel. go to the HP site and look for a replacement part.
Jun 02, 2009 | HP Compaq nc6320 Notebook
Dark vertical stripe on monitor
You screen "LCD" is broken , need new lcd panel. Very expensive
Feb 01, 2009 | Samsung T220HD LCD Monitor
Hitachi 60v500 tv has split screen with white vertical stripe down side
Good Day, poandflo;
After removing the power from TV remove the back of the TV (bottom only): Repair: Re-insert PDM connector on both Main Digital module and Drive PWB.
Good Luck, big IRISH. ps. remove cables one at a time and plug back in ensuring that they are seat properly.
Aug 08, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Acer 5670 screen has dark transparent vertical stripe
you will need to check the display cable and if that is ok, you will need to replace the display panel... You're getting a short on the circuit board causing rows of pixels to be blocked out
Here's your display on ebay...
http://cgi.ebay.com/NEW-ACER-ASPIRE-5670-15-4-WXGA-GLOSSY-LCD-SCREEN_W0QQitemZ320249932106QQihZ011QQcategoryZ31569QQrdZ1QQssPageNameZWD1VQQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247
Jun 13, 2008 | Acer Aspire 5670 Notebook
Black Out
Hi Detrix, Check with www.lcdrepair.net if you want a repair. Something is wrong with your LCD controller and or GUI interface circuit or the circuit supplying power to it. If your technically endowed, you may want to open the monitor case and clean the dust and lint from around the circuits using a Small paint brush to sweep away any built up dust. These circuits take the Signal from the computer and controls the 2.5 million pixels on the LCD screen. Dsut can cause major problems with handling all that data. Give it a shot, what do you have to loose, its not dangerous if the monitor is unplugged.
Oct 09, 2007 | Samsung SyncMaster 193P 19" LCD Monitor
Sony Handycam DCR-TRV720 Digital Camcorder Logo
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
