Model LSQ9659PWO washer does not spin , just makes
Model LSQ9659PWO washer does not spin just makes humming noise>
  • Washing Mach... Master
  • 43,501 Answers
Here is a tip that will help you with the not spinning or agitating problems....
Washing Machinemodel LSQ9659PWO washer does not spin , just makes - 2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
Posted on May 15, 2010
WHY IS MY FRIGIDAIRE FRONT LOAD WASHER MAKING ODD NOISE AND NOT SPINNING?
Hello Friend, thank you for your post!
Often when a washer does not spin, it is because your washer cannot properly drain and dispose of the water and detergent solution. Does your washer make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, your washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair washer.
Best regards! - Z
Jul 11, 2014 | Frigidaire Washing Machines
Top loading Kenmore h e washer roars while spinning
kind of hard to solve without more info.but it could be unlevel find a level or borrow one and place on top of washer.make sure it reads between bubble on level.check both sides on top of washer.if you hear kind of grinding noises and shifts hard it could be transmission..
May 26, 2014 | Kenmore 24032\24036 Top Load Washer
Frigidaire washer won't drain or spin. Makes noise when spin cycle begins. Any suggestions?
Good Afternoon Friend, thank you for your post!
I see you are having trouble with your Frigidaire washer (GLTF2040ES0) not draining properly or spinning. Often, this is because your washer cannot dispose of the water and detergent solution. Does your washer make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, your washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair your appliance. Best regards - Z.
May 21, 2014 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire affinity front load washer
If the unit will not spin at all and makes a humming noise, sounds like something has seized up in the back of the unit. This could be a belt broken, motor seized up, or the transmission, if your unit has one, is gone.
Jul 17, 2012 | Frigidaire ATF6000ES Front Load Washer
Make a humming noise and spins very slowly
MINE DOES THE SAME. HOUSING IS CRACKED THAT ATTATCHES TO DRUM. WHITE METAL CANNOT BE REPAIRED.
Jul 25, 2010 | GE WPXH214A Front Load Washer
Whirlpool direct drive top loader will not spin
Hi, Is the humming noise coming from the timer area? Do you know if it agitates ok?
When you have it in spin cycle, Try lifting the lid and see if the hum stops.
The reason for these questions is that on this model, if it drains the water out but does not spin, it is either lid switch, coupler, or transmission.
If it's the coupler, it will not agitate either.
Please let me know so I can assist you further.
Thanks
Vic
May 30, 2009 | Whirlpool LSR8433K Top Load Washer
Washer makes noise, will not fill
turn it on and just makes a hummins noise??? not filling with water??? at very least the machine if powered correcly will fill with water, the humming if happening is hte washer trying to fill check your incoming water supply. try alo changing water temp select from cold/warm/hot.
Dec 03, 2008 | Roper RAS8244KQ Top Load Washer
Model numer RAS6233RQ0...only get humming sound, and nothing else
yes i have a roper ras6233kg top load washer. I have not had any problem with it until about Two weeks ago, it over filled and it would only make a hummuing sound. Now it has dried out and have been working beautifully. Then Three days ago it stopped agitating,will not spin only making a loud humming noise. I guess its time to get another one.
Jul 24, 2008 | Roper RAS6233KQ Top Load Washer
Buzzing noise coming from timer control area
Is your water on ??if yes than you may have a bad timer.
May 04, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
134 people viewed this question
Top Washing Machines Experts
