Question about Dryers
I just bought a Maytag bravos quiet series 300 dryer. It is taking 2 hours to dry a load.
SOURCE: Maytag Quiet Series 200 Electric Dryer
I also had a similar problem with my maytag dryer which is 3 1/2 years old. It was the idler lever assembly with pulley. The part number is 11222607JG and the cost is about $20.00. Hope this helps.
Posted on Sep 07, 2009
mkh5094
  • 145 Answers
SOURCE: maytag bravos dryer belt needs to be replaced
Check in the back and see if the belt has a wide span on it. If it does, it doesn't only go around the fan pulley but also the drum (Which is usually the case). THis being the case you need to look for and screws you can find on the dryer outer casing because you will need to remove the outer casing to get to the drum. If you look for screw on the upper part just inside the door many times the upper deck is on hinges and will tilt backward so you can view the top of the drum with the belt on it. Remember how it came apart; it goes back together in reverse manner. Once you usually find the belt tension pulley through the back of the dryer compartment, let the tension off the pulley and slide the belt off of it. Once you get the belt off put it back on just like the old one.
Posted on May 02, 2010
aborcass
  • 2651 Answers
SOURCE: Maytag dryer doesn't dry properly
heating element is fine. it either works or it doesnt, cant work halfway, your problem sounds like you hav a clogged vent a kinked exhaust leaving the home. try looking at the exit point form the home can you see any lint around the housing, VENT VENT VENT
Posted on Mar 11, 2008
  • 83 Answers
SOURCE: maytag quiet series 100 dryer
Is there power to the dryer?
Do any lights come on or any sounds?
i.e. Is there power at the power point (plug something else in)?
Posted on Sep 16, 2008
  • 51 Answers
SOURCE: Maytag atlantis takes hours to dry one load.
Most common problem is something blocking the venting process, either somewhere in the vent tube itself,,, or somewhere in the venting system inside the dryer, like maybe the blower fan.
Posted on Mar 13, 2009
I have a maytag bravos quiet series 300 dryer with the error message f73. What does that mean?
Maytag Bravos 7.0 Cu. Ft. Electric Dryer F73 - Questions ...
www.fixya.com/search/p688923-maytag_bravos_7_0_cu_ft.../f73
have a bravo dryer , wont start shows error code f73 ? lights come on but dryer ... I think there was an F73 or F93 error message but we did not write it down.
Sep 22, 2015 | Maytag Dryers
My bravos quiet series 300 will not turn on. what could be wrong
Check for power first must have all the juice one side of electric can be down. check door switch or replace Dryer electronic control board Part #: W10222206
Feb 20, 2015 | Maytag Bravos MEDB200VQ 29" Electric Dryer...
Maytag Bravo gas dryer gets too hot.
Most likely needs a new thermostat. Go online to find instructions on replacement. Make sure it is unplugged. I don't think it is too difficult to do yourself.
Sep 13, 2014 | Maytag Dryers
What does my Maytag Bravos 300 quite series electric dryer take so long to dry clothes?
Those sensor bars can become faulty and that is probably the problem. Try cleaning them off with a clean rag. Good Luck!
Sep 08, 2014 | Maytag Dryers
2 year old Maytag Bravos quiet series 300 is not blowing air out of the exhaust port.
Oh brother. These dryers have 2 belts. The small belt that drives the pulley is probably off the motor. The pulley tends to come loose and fall off. The manufacturer recommends lock-tite on the nut that holds that pulley. REPAIR PHOTO
Sep 05, 2012 | Maytag Dryers
How do you remove a bravos heating element
Take the rear cover off and the heater is a shorty mounted on the right hand side. See page 61
Aug 08, 2012 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
My Maytag Bravos dryer is brand new. It is the quiet series 300, but is the loudest dryer I have ever owned. It makes like a loud vibrating, humming noise. Is this normal? I am now drying my second load of...
People, the first words the poster said were that the dryer was "brand new". All of your suggestions assume the dryer had extensive use. This sounds like a factory defect issue!!!! My brand new Maytag Cabrio gas dryer is also making an obnoxious buzzing sound that seems to cycle on and off as the gas ignites. The buzzing sounds electronic not mechanical. What would buzz when the burner is active?
Oct 31, 2010 | Maytag Dryers
Maytag bravo quiet series 300: Stopped at spin:
We have a Maytag Bravo Quiet Series 300 washing machine, the door latch is broken. I have the replacement part ( the locking mechanism) but I need can not figure out how to get the top of the washer to flip up to give me access to top front of the machine to remove the old part and replace it with the new.
How do I flip back the top (not the door) of this machine?
John
Jan 15, 2010 | Maytag Washing Machines
Dryers Logo
1,268 people viewed this question
Top Dryers Experts
