Question about HP (P2074-63003) Motherboard
CPU fan stops, computer shuts down
My CPU fan shuts off, I get a warning that CPU fan is not working and the computer will shutdown. Tried new fan, but have the same problem. Plugged the fan into a different spot and it works as it should. I still get the same warning and eventual shutdown. Any sugestions?
    President:
  • 2,351 Answers
You must have the CPU fan plugged into the CPU fan power connector or the system can not monitor the fans speed. Your PC will shut down & give you that message. (The fan must be connected to the correct power plug).
If when you did replace the CPU's fan & had to remove the heat sink, which is where the fan screws into & did not clean the old thermal grease off the CPU & heatsink & replace with new thermal grease than your CPU will still overheat. If you add thermal grease over top of old thermal grease your CPU will over heat.
This is all a balancing act. If any one is not correct your system will shut down. (This is better than killing the CPU).
To remove old thermal grease use a clean cloth damped with house hold alcohol & use the same on the bottom of the heatsink. Please allow plenty of time for the alcohol to dry.
Good Luck! Take your time.
Mike
Posted on Mar 30, 2008
SOURCE:
When laptop start window 10 boot screen come up and during the process after 15-20 seconds since the laptop was powered on the laptop get shut down.
hi there.
Laptop performance slowing down, or the laptop isshutting off completely because the laptop is trying to protect itself from damage caused by an excessive heat build-up. ... There are times when a laptop will turn offbecause of a virus or malware, hardware or software problems/conflicts as well.2 Nov 2013
Don't panic!... Is your "laptop shutting off by itself" or "slowing down ...
https://www.youtube.com/watch?v=74agkgZdzkI
What is the problem if laptop shuts down automatically?If removing air doesn't fix shutdown issue, it is a faulty hardware (can be anything), related to overheating or serious power related failure, such as bad battery or adapter. Overheat issue will result in unit turning on, but shuts down after about the same time (i.e. 15 sec).29 Jun 2015My Laptop automatic shutdown in few seconds - Laptops - Laptop ...
What would cause a computer to keep shutting down?An overheating power supply, due to a malfunctioning fan, can cause a computer toshut off unexpectedly. Continuing to use the faulty power supply can result in damage to the computer and should be replaced immediately. ... Software utilities such as SpeedFan can also be used to help monitor fans in your computer.5 May 2017Computer turns off without warning - Computer Hope
How do I get my computer to stop shutting down?Cancel System Shutdown or Restart. You cannot cancel a restart or shutdown using the Shutdown Event Tracker Windows interface. It is only possible to perform this task from the command line. To cancel or abort system shutdown or restart, open Command Prompt, type shutdown /a within the time-out period and hit Enter.1 Apr 2013Stop, Cancel, Prevent, Abort System Shutdown in Windows 10/8/7www.thewindowsclub.com/abort-system-shutdown-windowsSearch for: How do I get my computer to stop shutting down?
or go to this link to find out more.
Laptop keeps shutting off after few minutes
Nov 19, 2017 | Lenovo IdeaPad Computers & Internet
How can i tell if the fan on my vaio CS31S isnt working properly? It seems to speed up and down and the laptop shuts down? Is it te fan or could there be another reason for this shutdown? :-)
Try blowing out any dust from around the fan with compressed air. If the fan is turning on and off a lot, this could be normal, depending on your processor, but if the system just shuts down fully and randomly, it would be a heat issue. The CPU is overheating and the failsafe mechanism is to instantly shut your computer down. The only way to avoid this is to raise the CPU shutdown temp in the BIOS settings, or if you can access the CPU, remove it and apply new, quality thermal grease. Also, ensure the fan is operating correctly during use and dont block any air intake or exhaust ports.
Mar 08, 2011 | Sony CPU FAN CPU Fan
Computer shuts down by itself
There can be many reasons of unexpected shut down of your system.Below are some remedies to solve it
Run an anti-spy ware and anti-virus utility to make sure that the shutdowns aren't being caused by a malicious program. If the shutdowns are infrequent, install a CPU temperature monitor utility to keep track of the CPU's temperature. If the CPU is overheating, or the shutdowns are frequent, then you will need to troubleshoot your computer's internal components.
Check any recently installed internal components to ensure that they are properly connected to the computer's motherboard. Make sure any new expansion cards or memory modules are securely seated in their slots, and ensure that the power and data cables are properly connected to any new drives.
Check for large dust buildups on your CPU fan. If the fan isn't effectively cooling your CPU, the overheating CPU will cause your computer to power off. Carefully pick away large pieces of dust with your fingers, and then spray the CPU fan with a can of compressed air to remove the rest of the dust.
Reapply the heat sink compound between the CPU and heat sink if the computer continues to turn off unexpectedly. Heat sink compound is a pasty substance that fills the space between the heat sink and processor, which increases the heat sink's ability to absorb heat from the CPU. But worn heat sink compound won't properly redirect heat away from the CPU. Power down your computer, disconnect its power cables and open the case. Unplug the CPU fan's power cable from the motherboard, remove the heat sink and fan combination from the CPU, and then apply the heat sink compound to the CPU--refer to your product manuals for details on reapplying heat sink compound.
Thanks .
Have a great day.
Oct 03, 2010 | Dell Inspiron 537s PC Desktop
Why my computer automatically shut down eventhough it working 10 to 15 mins?every time i restart it will shut down again...what is the cause? do i need to replace the new one(motherboard)?
You could have a problem with your OS, it could be viruses, or other things.
It could also be a force shut down by your motherboard. Before you replace the motherboard, check to see if you computer might be over heating. Touch the heatsink on your CPU/Motherboard. Feel if it is too Hot or Cold. You only want it to be warm.
Mar 08, 2010 | EliteGroup P4VMM2 Motherboard
The computer shutdown and I tried to turn on and
If you are getting through the bios before it shuts down, you may want to make sure that the CPU cooling fan is working and that there is plenty of airflow around the CPU heat sink. Make sure the reset and power buttons are working properly as well. Check that all of your RAM modules and any add on cards are seated properly as well.
Jan 03, 2010 | HP Compaq Presario F500 F700 and G6000...
Dell 5150c shuts down orange flashing light
As a temporary measure, taking the side panel off the dell 5150c stopped it from shutting down, so in my case it was clearly a heat problem, as suggested by previous the poster. The following instructions assume you're comfortable replacing computer hardware components - do at your own risk!
The solution is to buy an 'air duster' and some thermal compound for the CPU heat sink. If your CPU fan doesn't sound healthy (mine didn't), also buy a new one (ca. £20 on ebay: search for G9474 ).
Read the service manual: http://support.dell.com/support/edocs/systems/dim5150C/en/sm/index.htm for details on how to install / remove the fan and heat sink.
Clean out dust from the heat sink with air duster. Remove the fan, and clean or replace (recommended). Also clean the grill in front of the fan. Clean off old thermal compound from the CPU / heat sink and replace with a thin layer of fresh compound. Replace heat sink and side panel and you're done.
Mar 16, 2009 | Dell Dimension 5150C (DIM515CMIN) PC...
Toshiba Satellite shuts-down by itself in about 1 minute
Could be hardware or software problems, IF its hardware issue the only problem makes this if the Cpu fan doesnot work, so the Cpu gets hot and then it shutdown in order not to be damaged. but mostly its software issue that remeber if you installed any program before this is happen, and try to stop shutdown by this command, if you did this and this stop shutting down your laptop this is absolutley software problems or programs conflict:
hit Start, then Run , then type this : shutdown -a
this will stop your shutdown if it works, try to uninstall the last programs causes this issue,if it doesnot let you use safe mode command.
Regards
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Mar 01, 2009 | Toshiba Satellite M45-S265 Notebook
Ga-m61sme-s2l motherboard always shut down within 5mins
It sounds as if the motherboard is having a temperature safety shutdown. This occurs when the temperature of the CPU exceeds a certain limit.
First off: Please check your CPU fan, power supply fan, and graphics card fan(if you have a gfx card) that they are working. If not, I would highly recommend replacing the fans or at least cleaning them and attempting to get them started by rotating them manually.
Please enter your BIOS (See Here for instructions) and navigate to "PC Health Status" - check the entry for the CPU temperature. While in the BIOS there is little strain on the system, but if the temperature is above 40 degrees Celsius in this state it may be prudent to check the fan setting. Also, check if there is a CPU Fan fail warning/CPU warning temperature - on average the limit should not exceed 60-65 degrees Celsius, max. Set any Fan speed or mode settings to maximum if able.
Try again.
If problem persists, and you are sure the temperature is not too high and/or the CPU fan is working, it may be the power supply itself. It is possible for the power supply to shut itself off in extreme cases such as when a power supply's fan stops working, and the temperature of the power supply rises to an unsafe level. Sometimes the fan will work initially but quit after a certain time. The fan requires replacement if this is the case.
Let the computer sit for a while and check to make sure it is at or near room temperature. Attempt to restart the installation process. When the power is cut, feel where the power supply meets the case to check whether or not it is particularly hot.
Replacement of the power supply's fan should solve that problem. I recommend taking it to a repair shop.
If that is not the problem, a last resort is that the harddrive is overheating and causing a system crash. With the case open, start the computer (mindful to be careful and always touch a large metal object such as the computer case itself before getting your hands near any components to prevent static damage), and wait for it to crash. Place your hand gently on the harddrive. If it is very warm or hot to the touch, most likely the harddrive's actuator arm, circitry, or data plate is malfunctioning and the drive should either be taken to be repaired or replaced.
If none of the components in your computer are particularly hot, please come back with more information on your computer, such as the parts, what you are cd you are booting, any new hardware, etc.
Dec 16, 2008 | Intel Motherboard
Shutdown
There could be any number of reasons for this to happen. However, the most likey reason - assuming that it runs for a bit, and then shuts down - is that the heatsink/fan on the CPU is not working, or not installed properly. Once the CPU heats up to a certain point, it will shut down to prevent damage. Perhaps the CPU fan as gone bad, or is completely clogged with dust.
Feb 03, 2008 | Computers & Internet
Shut down problem
if it gives you 60 secs warning , abort the shutdown by ---- shutdown /a---- command....and check for any servivice termination from administrative tools > services... check if all the automatic strted services are running
Jan 26, 2008 | Microsoft Windows Server Standard 2003 for...
Computers & Internet Logo
1,125 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
