Question about Drills
Makita 14.2 volt drill--has low power
14.2 volt drill--has low power and battery tests 14.0 volts speed is slow and can easily stop with hand. Model# 6337d ser# 458583a
5 Suggested Answers
scrodamoon
  • 659 Answers
SOURCE: I have a 18 Volt
oh I hate when that happens. ushally its due to not being lined up right inside the unit. happens with my cheaper drills more so then not.
I ushally just secure the bit into my vice, and then tap the the key with a hammer to loosen the threads..
sounds like she might need a bit of oil I ushally use air compressor oil just a couple drops work for me.
Posted on Aug 13, 2008
frankzen
  • 19 Answers
SOURCE: Hi. I need a Sears Craftsman 16 volt battery
www.craftsmancordless.info
Posted on Apr 04, 2009
SOURCE: Need to replace power cord to battery charger of cordless drill
it takes a 24V DC 200mA  The one I have is a Ktec Model KA12D240020034U
Posted on Aug 29, 2009
dmftrucker
  • 1922 Answers
SOURCE: My makita drill is weak/ has no power.
did you check the battery under a load condition?as in check the voltage under drill operation,most batteries will check their normal top charge voltage when not being used,this is known as a surface charge,but under load the voltage may severly drop leading to burned or overheated armatures,have it load tested
Posted on Jan 02, 2010
How do i convert a makita charger model DC18RC at 110 volt to 240 volts?
The DC18RC are most likely to charged the BL1830 battery, which is the most popular of 18V Makita power tools. It is a Li-ion battery.
And the DC18RC battery charger has two volt 110 Volt and 240 Volt.
The 240 Volt DC18RC charger can replace model DC18RA & DC18SD because of its improved performance and full compatibility with Makita's NEW 'Star' labelled batteries that communicate between the tool, battery & charger. And, it is a fast charger.
It can charge a Makita BL1830 Battery in approx 22 minutes.
But, I do not recommend to convert a makita charger model DC18RC at 110 volt to 240 volts.
The reason is as below:
1. This will void product warranty ! If you follow this mod, you do it on your own risk !
2. There are several comments that described
same model # but with different design and components.
Please beware that this mod might not work on your charger
or worst, will damage it.
Only perform this mod if you know your way around with electronics !
Sep 20, 2013 | Makita Drills
My Makita BHP451 Li ion battery drill periodically the varible speed does not work, ie. the button works as a on/off switch - any idea what's wrong. Thanks Bjarne
Bjarne, odds are the variable speed function of the trigger is failing. There are Makita repair centers that perform repair, and sell parts if you want to take it on as a DIY project. Before proceeding, I would make sure the warranty has expired. If it is still in warranty a Makita repair center should repair it for no charge.
Dec 19, 2010 | Makita LXT202 BHP451 18 Volt Hammer Drill...
Makita 14 volt cordless drill, model 4337, just decided to slowl down and go dead.\r\ndrill is beyond warranty period and has been used only 5 or 6 times. does any one have any ideas???
The batterys don't last for ever dosn't really matter how many times you use it but never leave it in the garage or cold places that will distory the battery life and mermorey. Its a good gun so it may be worth getting new batterys just try to run them down all the way before recharging and never leave batterys in the cold and it will work and least 3 to 4 years before you need new batterys
Dec 14, 2010 | Makita Drills
I cannot see where to connect the power supply! I have no manual with this second hand cordless drill, and cannot see any holes to insert the power supply.
if it has removable batterys then you have to install in the charger, but if it has a different type there should be a charging port either on the underside or back of the drill. Let me know the model number and I will be more specific
Aug 31, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
My Makita battery charger does not work it is a model DC1414 purchased about 5 years ago
The battery could be bad after 5 years. Check the contacts on the charger with it plugged up using a volt meter to see if it's putting out.
Jul 20, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
Dc1804f charger
If you have tried discharging the batteries prior to charging them already with no result and from what you describe in your post, then I would have to say the charger has issues. Go to HD or Lowes (not sure if Lowes carry Makita) but another charger and test your battery again. If you get the same fault, there is an issue other than the charger, if not you need a new charger anyway. If you get the same fault with the new charger, you can always return the new one. Short of opening up the charger and using a volt meter, this is the easiest way to test to pinpoint the real problem. I hope this helps and good luck!
Nov 06, 2009 | Makita 18V LXT Lithium - Ion Cordless...
Hi I have a makita drill 18 volt. I lent the drill to a friend and got it back not working properly. When I squeeze the button, the motor is running but the head of the drill is not turning and doesn't...
Check the speed control. There is a speed control usually from hi to low... sounds like it's in between speeds... try adjusting it back and forth...
It should go back into one gear and work fine.
Oct 06, 2009 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
I have a mikita 12 volt and when I charge it it wont hold charge.
do you have a volt meter toi check the charger voltage? if so then read the voltage out of the charger, it should be 1 or 2 volts higher than the listing 12v would be 13 or 14 volts. if it's working you probally do have a bad battery. if the charger is out then you have a bad charger.
Aug 03, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
I have a makita dc18sc battery charger that dosn't seem to be working, (no indicator lights). I have power to the unit. Is it time for a new charger?
Maybe sometimes it is the battery do you have 2 batteries you can check it with if it charges the other then its just the battery .If you have a local industrial distributor in the area usually they can test it for you
Nov 30, 2008 | Makita 12 Volt Cordless Drill/Driver Kit
Drills Logo
78 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
