Question about Coleman Powermate Premium Plus 6250W Portable Generator
Ignition coil spark is weak. And where can i find
I have a older coleman 6250 and ignition coil spark is weak. And where can i find a replacement? will any coil work?
2 Suggested Answers
  • 5603 Answers
SOURCE: ignition coil spark is weak. And where can i find
FIRST check the gap of the flywheel magnet to the magneto coil. Use a business card as a spacer and adjust the gap. If unit has points rather than electronic triggering, check those and timing and gap.
Posted on Mar 24, 2010
Generator 6250 coleman spark plug will no fire
First check your oil level. The low oil sensor kills the ignition to protect the engine from damage.
Second, replace the spark plug.
Sep 17, 2014 | Briggs & Stratton Electrical Supplies
Why a weak spark 1987 dodge 5.9 v8
this can be caused by a weak battery check battery and charging system to verify a good working system. it could also be a weak coil not being able to supply enough output voltage for the ignition system. you don`t say if its weak coming out of the coil or at the plugs. if spark is weak at the plugs it could be a bad cap/rotor, ignition wires. it could also be an ignition module problem or pick-up coil in the distributor.
Aug 25, 2014 | Cars & Trucks
1990 30 HP mariner #689L532392, has weak spark on plugs, (ignition coil is new)
if the ht leads to the plugs is separate to the coil/s replace the leads
they are carbon cored and fail with super high resistance causing weak spark
Jan 23, 2018 | Cars & Trucks
Briggs & stratton I have an older craftsman lawn tractor. 16Hp cast iron sleeves and flywheel, electronic ignition, no points, 24 yrs old. while using it went dead. no spark whatsoever, bought a new...
You bought a new ignition coil, how far from the flywheel was it mounted? Did you replace the spark plug?
I hope you get the old machine running soon.
Aug 12, 2011 | Garden
Weak spark on no. 6 terminal on the coil. coil is good, ignition module is good, crankshaft sensor is good, powertrain module is good
Swap the coil with one of the other coils. If you still have weak spark out of that tower than replace the coil. If you have strong spark once swapped and the other coil tower now has w eak spark replace the module.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
May 27, 2011 | 1998 Oldsmobile 88
Have a coleman powermate 6250 model #pm0545007,won't start,what to look for?
Fresh Fuel
Clean carburetor if stored with fuel in the tank and wasn't shut off
Clean fuel filter
Clean air filter
Proper oil level
Clean spark plug (just replace it, it is easier and faster)
May 20, 2010 | Coleman Powermate Premium Plus 6250W...
Mar 22, 2010 | Coleman Powermate Premium Plus 6250W...
Coleman powermate 6250 no spark, switch on, has oil. changed spark plug.
check wiring most likely loose wiring, happens when your generator viabrates
Nov 11, 2009 | Coleman Powermate Premium Plus 6250W...
The blower stalled after running for 15min.it is getting gas,i cleaned the carb+ replaced the gas filter.the air cleaner is clean and i replaced the spark plug.i seem to be getting a very weak spark.any...
Hello . If you have a weak spark it could be the ignition coil that needs adjustment or a bad ignition coil . To find the ignition coil simply follow the spark plug wire . To readjust the coil get a piece of paper , loose the bolts on the coil and put the paper between the coil and the flywheel (higher part of the flywheel or magneto) tight the bolts and remove the paper .
Check for spark . If still a weak spark just replace the ignition coil .
Hope this help.
Jun 30, 2009 | Husqvarna Garden
Coleman Powermate Premium Plus 6250W Portable Generator Logo
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
