Question about AcerScan 620PT Flatbed Scanner
Mirascan doesnt work with Parallel to USB port ?
I installed de Mirascan Driver on my laptop but when I open it just appear that i have to check parallel conection...i have a Parallel to usb. But it doesnt work Do I have to install some specials drivers for that?
I am looking for same solution...Have you solved it ?
Posted on Sep 30, 2010
Actullay, sir, i broughted this scanner systems about 10years old that time in pakistan win xp is not produce properly i have orignal cd of scanner but this driver the said cd valid for win98 and millinium...
How to make any Acer/BenQ/Vuego/Brisa parallel port scanner work in Windows XP (note: this procedure does not work in Windows 7 or Vista, only in XP):
Instructions for installing Acer brand parallel port scanners in Windows XP:
For this driver to work in XP you must install the MiraScan software then install the scanner manually.
Step 1. Download MiraScan v3.424 from the web: ftp://12.145.38.159/scanner/drivers/parallel/mirascanv3424p.zip
Step 2. Unzip and install the Mira Scan driver that you just downloaded. After installation , system will suggest you to add a scanner
Step 3. Then, add an imaging device
Step 4. Then the Scanner and Camera Installation Wizard comes up. Click Next at the bottom.
Step 5. Then on Scanner and Camera Installation Wizard screen it will ask you which scanner or camera do you want to install? You want to go where it says "Manufacturer" and then click on "EPPSCANNER" and where it says "Model" it should say "color flatbedscanner". Make sure it is highlighted, also. Click on Next at the bottom.
Note: For additional screen shots of this procedure and installation procedures, please read the pdf file posted here: ftp://12.145.38.159/scanner/manuals/scpinwxp-eng.pdf
The Screenshots show to be for Mirascan v3.423 but the procedure is same for v3.424
Note: Adobe Acrobat Reader is required to view or print this file.
Note: This solution does not work on all computers but many report success with it. The hang-up is caused from certain chipsets in the computer motherboard.
Sep 04, 2010 | Acer ScanPrisa 640P Flatbed Scanner
I have an HP LaserJet printer 4050N with RJ45 and Parallel Port. The Printer is kind of far from the WireLess router and I can't connect it. Unfortunately, my PC doesn't have a parallel port. The best...
Another option is to find an old laptop, with "wireless" capabilities and a Parallel Port.
Connect the printer to the laptop.
Connect the laptop to your wireless network.
Tell the laptop to "share" the printer.
Then, any computer on your network can "find" the networked printer, and can print to it.
Jun 12, 2010 | HP LaserJet 4050 Printer
Cable connectivity with my laptop through a "parallel to usb cable". My laptop has no parallel port but only usb ports.
make sure you follow this step :
1. install driver USB to Paralel port (LPT1) before the cable connected to PC
2. After the driver installed, install the cable - and it supposed to be detected
3. the last think u have to do is install the scanner/printer driver
if it is not work, i guess the problem is on the USB to paralel adapter, or the driver not installed correctly
Jun 01, 2009 | Acer ScanPrisa 640P Flatbed Scanner
I need a driver soft ware to work with windows xpsp2 for acerscan prisa 310p email: elfondkya_ihabmoh@yahoo.com
Instructions for installing Acer brand parallel port scanners in Windowsmag-glass_10x10.gif XP:
Step 1. Download MiraScan v3.424 from the web :
Mirascan_v3424p.exe
Step 5. Then on Scanner and Camera Installation Wizard screen it will ask you which scanner or camera do you want to install? You want to go where it says "Manufacturer" and then click on EPPSCANNER and where it says "Model" it should say color flatbedscanner. Make sure it is highlighted, also. Click on Next at the bottom.
scpinwxp-eng.pdf
The Screenshots show to be for Mirascan v3.423 but procedure is same for v3.424
Note: not all XP systems will work with parallel port scanners. If the procedure doesn't work for you, then you must obtain a newer USB type scanner.
Mar 22, 2009 | AcerScan Prisa 620U Flatbed Scanner
INSTALL AN UMAX ASTRA 1220P TO AN USB PORT ON A LAPTOP USING XP
The 1220P (P = Parallel) does not have a USB port and Windows XP does not support it.
Jun 16, 2008 | Umax Astra 1220P Flatbed Scanner
Canon BJC 2000 question-1284 to usb
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} USB to Parallel conversion requires translation by XP and Vista's 'hardware interleave' software as well as the USB device manufacturers driver. The software package just doesn't work well with older peripherals that use legacy parallel or serial com ports. Too many sloppy layers.
THE BEST WAY to add an LPT printer port to your laptop is to use a PCMCIA to Parallel adapter card.
The PC Card slot provides access to the laptop's data bus, and the PC Card adapter easily sets up as a native LPT port within almost any OS.
There is no delay, or connection problems as I've seen in so many complaints about USB to Parallel or Legacy Serial adapters. Printing is Instant.
PCMCIA is a mature standard, and works seamlessly with XP and Vista, and almost any other OS.
PARALLEL is the old standard fast data protocol. IEEE 1284 ECP mode up to 1.5 Mbps.
The BJC-80 and the BJC-85 have the same print speed. The BJC-85 just added USB.
INFRARED is ver 1.0 on the BJC-80, and printing is a bit slower at 115.2 kbps. Even the BJC-85 with its higher IRDA transfer rating and a laptop's built-in IR port, the XP print spooler has problems with it, and can hang if printing more than one page, and especially with more than one document. It will not scan.
I use IR for printing single pages only with either the BJC-80 or BJC-85.
USB to IRDA adapters work fine, and are less expensive $5-6 than
PCMCIA to Parallel adapters, $20-25.
I have tested and used several PCMCIA adapters from different manufacturers, and they all work perfectly as a hot-pluggable, instant LPT and/or Legacy Serial port for my laptops.
TIPS:
After installing the PC Card driver, check Device Manager for the LPT port number.
Install the printer manually from the list of printers, and select the proper LPT port.
Most laptops have two PCMCIA slots. If you change slots, the adapter card driver may reinstall, and assign the next available LPT port, LPT2.
To scan with the BJC-80, you must have an LPT port.
The PC Card adapter also allows the use of the IS-12 scanner cartridge within XP or Vista.
Within Vista, set the Canon ISScan software to run in Windows 98 compatibility mode, to allow use of the TWAIN driver.
Jun 05, 2008 | Canon BJC 80 InkJet Printer
BJC 80 Won't Print
Try disable bidirectional support
Jun 02, 2008 | Canon BJC 80 InkJet Printer
Lexmark z11 Vista Compatible?
Looks like I've cracked it [Touches wooden desk]. Need a USB to IEEE 1284 36-pin Parallel Printer Cable, like the one I received today (ordered yesterday from www.cables2u.co.uk). First, connect it to Z11. Turn on Z11 and boot up Vista PC/laptop. (I run Vista Business on my laptop.) Connect cable to computer. Message appears "Installing device driver software". Click it for status. 'Found New Hardware' box appears. Click 'Locate and install driver software'. A message appears "Error loading LXADSUI.DLL. Specified module could not be found". Click 'OK'. Message appears saying driver software installed successfully. ["Yeah, right ..."] (Have faith, folks!) Now, click Start, then Control Panel and double-click Printers. Right click on Z11 and click on Set As Default Printer. Right click on Z11 again and click on Properties. Check on Ports tab that Port USB is ticked for Z11. On Cartridge Maintenance tab, check right cartridge is showing. If not, click 'Install/Change Cartridge' and follow instructions. Then 'Clean Print Nozzles' and 'Align Cartridges'. Check settings on the other tabs in Properties look OK and try printing a test page! It looks good to me!
Jan 15, 2008 | Lexmark JetPrinter Z11 InkJet Color...
Time consuming
Try installing the latest driver: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=230&modelid=7998
Aug 23, 2007 | Canon BJC 80 InkJet Printer
AcerScan 620PT Flatbed Scanner Logo
187 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
