Question about Samsung 206BW Monitor
My display resolution shows 640x480 only, the
My display resolution shows 640x480 only the system says i cant go any bigger?
  • 11,361 Answers
Please make sure you have correct videeo card driver installed in your PC.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on May 16, 2010
I just installed cosmi casino on my dell laptop. The display is set for 1680x1050. But when I start up the casino games the display comes up 640x480. I go to the display section on my cmptr. and it...
Maybe the game settings is set to 640x480.Here follow the steps below if this will help you.
  1. Run the Game
  2. At the menu screen, go the the Option then check the video or display settings if it is set to 640x480.
  3. If it is Set to 640x480 change it to 1680x1050.
  4. If the display is already 1680x1050 then try the 2nd option below.
Another option.
  1. On your deskop, Right click the icon of Las Vegas Casino.
  2. Then on the menu, choose properties,
  3. On the Properties, go to the Compatibility Tab.
  4. On the Compatibility Tab, check the display settings if the " Run in 640x480 screen resolution " is activated, if Yes then just uncheck the box and then click apply and Ok.
  5. Run the game and you should be in 1680x1050 resolution now.
Goodluck, hope my solution will help. Please give some feedback regarding my solution.
Thank you very much for using Fixya! Have a Great Day!
Jul 10, 2011 | ValuSoft Las Vegas Casino Players...
Windows 7 screen goes to large resolution and needs reset on startup.
Turn on the PC. Press F8 at booting into windows 7. It will display  many options
Select the Enable low resolution video(640x480) then login to system.
then change the resolution as required
Right click on a empty space on the desktop and click on Screen Resolution.
Enable low resolution video (640 × 480)
Jun 08, 2011 | AOC 718Swag-1 LCD Monitor
My HP ProLiant ML350 G5 failed to boot to Windows. After showing Windows 2003 Server, blank screen comes up
There was a critical HP ProLiant ML350 G5 ROM BIO upgrade dated on 17 Aug 2010.
Please bookmark the bio update link HERE for reference.
Check your monitor Hz and display resolution setting.
Did you change any video driver or resolution before reboot?
If all else fail then swap in a simple S-VGA card and let Windows 2003 to sort out the 640X480 display mode.
Jan 05, 2011 | HP Compaq ProLiant ML350 G5 Server
How to get 1200 X800 resolution
It depends upon the notebook you use if it support the resoulution you want. You can change the resolution by display properties in control panel. Also 1280*800 is used only by widescreen desktop or laptops.
Mar 24, 2010 | Compaq Presario 700 470024-192 Notebook
My display resolution shows 640x480 only, the system says i cant go any bigger?
Hello Dbaut72, hi, I have several options you need to try.
  1. try setting up your display on another PC, and see if the problem is your PC or your monitor,
  2. locate you driver CD for your PC VGA graphics, loading the driver to properly setup the video display may help resolve the resolution.
thanks and that all, keep me posted.
Mar 22, 2010 | Samsung 206BW Monitor
How do i get safemode in full screen or full resolution so there is not black borders around the out side
When you power up the computer Press and hold F8 key 5 to 6 times untill you see windows logo then you can see safe mode and other menu enter in enable vga mode then go to start menu->control panel->display ->property ->settings .
change screen resolution to 1024*768 then apply and ok.
Then check .
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 07, 2010 | Computers & Internet
Display
To troubleshoot sound without picture issues, follow these steps:
  1. Reset the resolution of the console to 640x480. To do this, start the console, hold both triggers, and then press and hold the Y button as the console starts. For more information about how to reset your display settings, click the following article number to view the article in the Microsoft Knowledge Base: 911059 (http://support.microsoft.com/kb/911059/ ) How to reset your Xbox 360 console display settings to the default display settings If you see a picture on the display after you try this step, you can continue to use the 640x480 resolution, or you can try to use a higher resolution setting. If you still cannot see a picture, continue to the next step.
  2. Disconnect the VGA HD cable from the display, and then remove the console power cord from the power outlet.
  3. Wait five seconds.
  4. Reconnect the console power cord to the power outlet, and then turn on the console.
  5. Reconnect the VGA HD cable to the display. If you can see a picture on the display after you try this step, you can continue to use the 640x480 resolution, or you can try to use a higher resolution setting.
Aug 08, 2009 | Microsoft Xbox 360 Elite Console
Can't see me during night time even there's is light
Several factors determine onscreen size of a video image produced by a Webcam. The actual Webcam hardware may be limited to a maximum resolution. The percentage of your screen filled by a Webcam image will be a factor based on your desktop resolution and the maximum resolution of the Webcam image. A third factor impacting image size is available bandwidth Webcam software may also play a role in determining image size, but in most cases the software is only limited by the Webcam output. There are several ways to optimize your results to make sure you send a Webcam image viewable at the highest resolution acceptable to relatives on the other end, while also optimizing your system to maximize available screen real estate with inbound images from relatives.
Webcam hardware is often a big limiting factor in determining maximum image size. Most Webcams on the market today output a maximum 640x480 image, which easily fills a television screen. Any of the Webcams currently available from Logitech, Creative, Apple, D-Link or the numerous niche companies marketing Webcams will support 640x480, although some produce better results than others. If you have a Digital Video camera capable of doubling as a Webcam, you may get a 720x480 maximum image size. Apple's iSight camera and some of the higher end Logitech cameras using CCD instead of CMOS image sensors produce excellent images at 640x480 in well-lit rooms.
Knowing 640x480 is the maximum image size, don't expect incoming video to fill your screen if you have your resolution at 1024x768. The graphic below is shows the relative portion of a 1024x768 screen filled by a 640x480 image at 50% of actual size. If you want the incoming video to fill your screen, reset the resolution of your monitor to 640x480 to properly accommodate the incoming video feed. This assumes your relatives are capable of sending 640x480 video from their end. If their sending limitation is 320x240, the best you can hope for is a video filling 50% of your 640x480 screen.
Nov 23, 2008 | Logitech QuickCam Express Web Camera
My screen resolution wont go above 640x480 pixels,16 colors
that probably the highest ur screen can go unless u update ur video card u can purchase some really good video cards at Best Buy or Wal mart Looking to help u Shaun
Nov 15, 2008 | Dell Microsoft Windows XP Home Edition
Samsung 206BW Monitor Logo
81 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
