The capacity of the hardisk change from 30gig to 1.5 gig
    Sergeant:
    Champion:
  • 221 Answers
Partition Problem. Have you recently partitioned your Hard Disk? If yes, contact your System Vendor/Engineer and tell him to create larger and fewer partitions.
Posted on Mar 30, 2008
Hard drive on my computer is reporting 75MB left on a 20 gig drive with only word and a couple smaller programs on it - someone please give me an idea.
Hi!
Let's see how much left on your hardisk and how much space that your programs used in your disk..do this..
Double click the "My Computer" icon
Right click on your "Local Disk (C:)" drive and click properties...
The blue color indicator will tell you how much space was used by your programs on your hardisk..
The pink color indicator will tell you how much free space left on your hardisk
The capacity value should be more or less 19 GB..
See if this capacity value match in your drive..
If the capacity value of your drive is below 10 GB then my guess is you have a wrong setting for your hardisk... Look physically in your hardisk. Between the port of ide cable and power supply connector you will see terminals with jumper on it.. The jumper is used to short the terminal. the function of the terminal is to assign the hardisk as slave, master, cable connector and or limit the capacity of the hardisk to some amount.. Check the label of the hardisk.. schematic diagram on it will explain where to put the jumper...
If the setting of the jumper was correct and the capacity value of your drive match to approximately 19 GB... then I suggest you browse the files on your drive. Check all its sizes.. There could be movies there that eats your space.
I hope I explained to you everything you need to know..
Much appreciated if you rate this help.. thanks
May 22, 2010 | Maxtor Hard Drive
Need to increase size of split hard drive
I would say the best way is to compress your files on your selected drive by going to my computer right clicking on the drive that you want to increase the capacity, click properties, then the tools tab. U should be able to defrag, compress from there. But I am pretty possitibe that the 15 gig drive is for backup of files for your computer incase the bigger drive crashes.
Apr 24, 2009 | Sony Computers & Internet
Motherboard 3 beeps
The three beeps is a diagnostic code. The beeps can represent a range of problems depending on which brand of mother board you have and what chipset it has. You can sometimes find the diagnostics related to the beeps online. The first thing to check is to make sure all your cards and ram are properly seated into their respective slots. I suspect your ram. Speaking of which 256 meg sdram is not enough to run todays applications. You should step up your ram to at least 1 gig and if you are running Vista, you'll need 2 gig.
Feb 21, 2009 | Computers & Internet
Ipod 30gig/more gigbits/ capacity expansion
Yes you can get up to 160 GB or more now.. If you want to keep the same iPod, you can have the hard drive replace with a 60 GB. You will also have to change the back and battery to accomodate the larger hard drive. There are a number of companies that will do it for you and some will even send you a postage paid box. Just do a Google search for ipod repair. Hope that helps.
Sep 16, 2008 | Apple iPod nano
Pls help
configure wireless network
Press Fn (Function key) at the lower left hand corner and F2 at the same time.
select Internet tab>>click on wireless networks.
select the wireless network that you have, and click connect.
this is where you need to know what kind of encryption you have on the wirelss network.
select encryption type. (WEP, WPA or other).
enter passkey for the network, and Press OK
Sep 12, 2008 | ASUS Eee 4G Notebook
Have just bought an 80 gig hard drive second hand i have formated it but it says its only a 31.4 gig
there could be 2 things wrong 1 is that there are to many bad sectors on the harddrive to read 80g
or they sold you a 30gig hard drive
Jul 14, 2008 | Computers & Internet
External hard drive enclosure
I too purchased a Nexxtech Hard Disk Enclosure and my Vista-based computer keeps telling me to try a USB 2.0 setup...the USB's ARE 2.0...did you try the setup disk that came with your unit?...I tried on mine but still a no go...I may have to return it to Best Buy & try somrthing different.
May 19, 2008 | NexxTech Portable Hi-Speed USB 2.0 Kit...
I can't get the full capacity of 320 gig drive
the hard drive you bought is not compatible with your motherboard. I am pretty sure that your board is only compatible with IDE ATA hard drive. you can still use it as external hard drive though.
Feb 09, 2008 | Gateway M305CRV Notebook
SD capacity of sandisk e280
2 gig for a version 1 player and 4 gig for a version 2 player.
Jan 03, 2008 | SanDisk Sansa E280 MP3 Player
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
