Question about Water Heaters
Hot water smells - Water Heaters
  • 494 Answers
Do you have a well? How old is the water heater? If I remember correctly, the water may have corroded your water heater valve thermostat bulb. Call the manufacturer ph# on the tank, give then make, model & serial # and see if the unit is under warranty and if they can give you a solution to your problem or a replacement part. Have a plumber or local repairman install part or repair it.
Posted on May 15, 2010
Replace an anode rod in gas water heater, my hot water smells, someone said replace the rod.
The purpose of the anode is to prevent corrosion of the tank. If you are experiencing smelly hot water, that may be traceable to the water source.
Nov 17, 2016 | Water Water Heaters
When a electric water heater smoking and it gits turned off at the breaker box will there be a chemical smell after
No. A water heater is a sealed system it needs to be addressed for the original problem. High sulfur content has been a complaint as far as smell,and I remove the anode and replace with a brass plug because of. Shallow wells in the area largest complaints.
Nov 27, 2014 | State Water Heaters 40 Gallon Select SL...
We have a one year old home with PEX pipe and one year old hot water heater fed by a water softener. In one of the bathroom sinks, and only there it seems, there is a sulfur smell when we first open the...
i would check the softener before the water heater, when was the last time you did a back flush of the system? water sitting at the bottom of a water softener tank can get moldy and begin to rot, which causes H2S gas which smells like sulfur , its a breakdown of decay,, this will also happen if your home is using well water,, so check that first , empty the tank and clean it our ,, then back flush the system
Jul 03, 2011 | Water Heaters
About every two months the the hot water gets a sour smell. To get the smell out I turn both elements all the way up for 3 hours then drain the water heater, its good for about two months. The water heater...
The smell is from bacteria. The high temperature kills the bacteria. Some regions require water heater temp to be set at 135 because of bacteria.
A test to determine if only the water heater is causing problem: Turn off water to water heater. Smell water coming out of cold tap. Turn on water to heater, smell water from hot tap. If only hot tap smells, then water heater is suspect.
Another way to handle the problem long-term, is to reconfigure cold water pipes so you can regularly pour in 2 bottles of hydrogen peroxide during your flushing procedure. Pour in the hydrogen peroxide and let it work for a while. And then flush tank as you have been doing.
You should read up on anode rods also. Many people replace anode rods when tank begins to get odor.
http://www.waterheaterrescue.com/pages/WHRpages/English/Longevity/water-heater-anodes.html
http://waterheatertimer.org/Replace-anode-rod.html
Oct 23, 2010 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
How do you check the condition of the annode tube in a hot water heater?
You'll have to disconnect the water lines from the top to pull the rod up out from within the tank. If you don't have enough clearance above the tank, you'll have to drain the tank, remove the venting and tilt it or lay it down to remove it. The sacrificial rods usually go bad prematurely on well water systems with hard water and causes a sulfur stench in your water. Here's a quick test to try before you do this: Go to the nearest faucet to the water heater and fill a glass full of cold water and another glass full of hot water and smell them. If the hot water is the only glass that smells like rotten eggs, it's most likely coming from your water heater due to your anode rod. Douglas
Oct 04, 2010 | American Standard 40 G Natural Gas Water...
New hot water heater cause smelly hot water.
U can clorinate ur water heater 1 gallon will do it. But you should try changing the anode rod(to aluminum) or removing it first followed by a complete drain, purge and refill.
Mar 29, 2010 | Water Heaters
Hot water is flowing from the water heater into
boiler type? Combi,standard,if your boiler is a combi the non return valve onto your heating line may be defective thus hot water slippng back through cold line best of luck
Oct 27, 2009 | Water Heaters
The hot water smells like rotten eggs., only the hot water
its the mag rod in water heater-if your not using alot of hot water,and water is sitting in heater it will smell like rotten eggs-u can remove mag rod from water heater.it is in top of heater-
Jan 08, 2009 | General Electric GE SmartWater Household...
Water Heaters Logo
51 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
