Question about Baby Trend Snap-N-Go LX Double Stroller
Hi- My husband and I were assembling the double stroller rear axel wheels and ran into problems. One side clicked in whereas the other side didn't. What can we do? Thanks.
    Problem Solver:
  • 5 Answers
If you have problems with your stroller, Call baby trend they will send you new parts, or even get a new stroller. You could take it back to the store first to get the store associates to help you, I know places like toys r us helps assemble strollers.
Posted on Sep 18, 2010
Adjust belt drive rear wheel
Raise the rear wheel safely (with a motorcycle stand of some type) Loosen the rear axel (27mm wrench works good) Adjust the tensioner bolts at the back of the swing arm(both sides) evenly until the belt is within specs. Turn the wheel forward and check to make sure the belt is spaced evenly between the sides of the rear pulley. Tighten the axel. Double check the belt tension with the wheel back on the ground.
Aug 13, 2013 | 2006 Victory Touring Cruiser
When pushing my quinny the back wheel starts to come of byitself
Hi Lisa - It could be that if there is dirt and debris on the wheel axel or inside the connection it would prevent the wheel clicking in properly. Remove both back wheels and give a wash in warm soapy water then dry thoroughly before putting back into place. Does the same side wheel fall off even if you swap the back wheels over? If this is the case it would indicate a chassis problem rather than a wheel problem. If it is the same wheel that always falls off it would suggest a wheel problem. Contact customer services on 01284 413 141 Mon-Fri 8.30-4.30 or e-mail to uk-customercare@dorel.eu for further advice
Nov 14, 2011 | Quinny Buzz 3 Stroller
How do I attach the net bag to buzz 4?
Good Afternoon
Remove the front wheel by using the buttons either side of the front wheel unit and sliding it out of the chassis. Fit the front of the shopping basket on and now attach the back of the basket around the rear wheel axel using the velcro tabs.
Dec 28, 2010 | Quinny BUZZ 3 Capri Stroller
Where is the serial number and the manufacters date on the stroller
It is engraved on the frame, on the right rear, above the right rear wheel. (City Elite Single )
It is engraved in the frame, on the right side of the stroller, on the lower side of the right folding handle, under the logo. (City Elite Double )
Dec 03, 2010 | Baby Jogger Onyx 2010 City Select Stroller
My Baby Trend Jogger's front wheel wobbles when we get past a slow walk towards a moderate walking speed. How do I solve this problem?
check that the axel is not bent and see if the wheel on the axel fits snguly twist it side to side it may have have woren the axel hole out
Aug 30, 2010 | Baby Trend Expedition LE Jogger
I need a new back wheel and can't find any information on website about where to get one.
I have the same problem Wendjg. Only place I could find in the UK to supply was www.pramsnthings.com. I am buying the axle only (cheaper than the wheel), if you want I can post again when the item's delivered and let you know if they're any good.
T
Oct 30, 2009 | Regal Lager Phil & Teds Sport Buggy Double...
Evenflo strollers
To remove the wheel, there is a small silver ball on each side of the wheel assembly. This part is located on the part of the stroller where the wheels assemble and the frame of the stroller meet. Push in on this silver ball and pull the wheel assembly off. Sometimes you may need to use a ball point pin to push that ball in so you can get it in far enough. Once you have the old assembly off, the new on will simply snap into the same place.
Let me know if this isn't what you needed!
Nov 14, 2008 | Evenflo CitiTour Double-Tattersall...
Phil & Teds Vibe - Back Wheels
I had the same problem.  What worked for me and they don't tell you in the instructions is that when you have slid the mud guards on and into place, you have to push the bottom of the mud guard (the bit nearest to the floor) in from the out side till it clicks!  then the wheels went on and locked.
Sep 16, 2008 | Baby Gear
Wobbly wheel and broken seat back
Problem suggests that the stroller needs a good servicing.The equipment is now being operated ignoring the safty standards and may turn out dangerous.It is recommended that you may get a authorised service engineer to look into the problem.
Jun 25, 2006 | SafeTech Double Jogging Stroller
Baby Trend Snap-N-Go LX Double Stroller Logo
88 people viewed this question
Top Baby Trend Baby Gear Experts
Jennifer Rock
Jennifer Rock
Mike
Dennis Crouse
Are you a Baby Trend Baby Gear Expert? Answer questions, earn points and help others
