Question about Grilling
Burner is sooting when grilling with soot on the meat
  • Grilling Master
  • 3,280 Answers
Clean the burner and gas orffice check to see if burner is split if so change it
Posted on May 16, 2010
The gas company red flagged my water heater because of black soot being produced. What could be causing the black soot?
A properly adjusted gas burner does not produce soot. your burner is defective. call a plumber to get it serviced or replaced.
Nov 18, 2014 | Heating & Cooling
I have converted my wood smoker to a gas assist and the problem is soot is covering the meat ???
soot is in complete combustion it would look like this burner is not the one for this , over gassed or out of postion will cause this . wrong size burner , lack of air to burn . you should find out if this model can be uesd for this check with the makes first .
Mar 01, 2013 | Grilling
I have a Char-Broil vertical propane smoker. The past 3 times I have used it, well, my food has black soot all over it! I have to wipe it all off the food before we can eat it. I have the top vent open and...
The propane burner has a slide opening somewhere before the burner so the gas/air mixture can be adjusted to burn better and hotter. you get alot of soot because the gas is too rich, it needs more air mixed in before the burner. the air vent on top and bottom of the chamber has nothing to do with the gas/air mixture to the burner.
Sep 21, 2011 | Grilling
Middle burner of 3 is just a large flame.
Either the burner or the line to burner could be sooted or dirty
Apr 19, 2010 | Kenmore Elite 900 sq. in. Cooking Area Gas...
When the model 41 comeson it makes a woolf sound..also the window is sooted up..can you help?
If the burner mat is loose it will make that sound. A loose burner mat will also cause a soot problem. The soot can also be caused by too little air flow thru the burner.
Jan 15, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
Bbq burner flame too high
If you got water down inside the burner(s), this condition should eventually clear up.
Dec 29, 2009 | Grilling
Black soot on Coleman propane burner
Had same problem. Coleman tech support said, " clean with pipe cleaners". No directions....I would think they would provide a step by step protocol. So, I chose to take the knobs off and use the pipe cleaner where I could. I was able to take one of the two burner control knobs apart. After sticking the clean in every nook I could find, I put back together, and the flame on that burner is back to normal,
Good Luck--Daryl in Burnsville, MN
Sep 11, 2009 | Coleman Grilling
Side burner on Jennaire grill
Hello
The soot stains come from the air mixture, that will show too much yellow flame tips, just adjust the air intake, too have an idea how much to adjust it, and also it wouldn't hurt to clean the flames holes by sticking a pin. Alos make sure you have the right fittings converters. It's the grill LP Gas or Natural?
Hope this help
Eddie Rentas
Tupper Lake NY
Aug 01, 2008 | DCS Double 30'' Grill Cart Side Burners in...
Grilling Logo
280 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
