Question about Sharp 13VT-R100 13 in. TV/VCR Combo
I have a Sharp 3 in 1, remote is G1687SA, I would
I have a Sharp 3 in 1 remote is G1687SA I would like to know how to set the vcr to tape something please.
2 Suggested Answers
hardrocko
  • 1476 Answers
SOURCE: Sharp vt 2128m
You didn't say whether the unit was shutting down. Usually when there is a fault in the VCR the TV shuts down to protect the unit. Your unit has a fault in the tape system. It has a bad sensor or something in it which is triggering a fault. Sometimes kids put things in the slot and cause this kind of problem. Using a flashlight look into the slot and see if there is an obstruction. If there is try to get it out. If you are capable and understand TV safety, unplug the set and remove the back to look for any foreign objects in the set. If there are no foreign objects you will probably have to have the set looked at by a shop if you want the VCR to work. If you have composite video and audio inputs on the unit you can hook up an external DVD player with an RCA patch cable. Hook the same colors together on each unit. Yellow for video, red and white for audio. You will have to select the input through the menu. Good luck.
Posted on Jul 12, 2006
Sharp vc-a412 will not reset to zero
You have to press the clear button on your remote control to put the counter to zero.
Oct 25, 2014 | Sharp VC-A410U VCR
Sound and just a Static picture when playing a VCR tape on a Sharp 13vt-N100
More likely a damaged tape got inserted, if the video heads get blocked or even partly blocked every tape after will do this, heads can be cleaned manually (careful if not sure how to do it) or a cleaning tape MAY clear this up or not.
Oct 15, 2012 | Sharp 13VT-N100 Combo
I need instruction to set recording for sharp h952 vcr
You need remote to get menu to set the clock then go to timed recording setting. Then you load a new tape, then shut down the vcr and wait for the timer to start the vcr and recording for you.
If you need a manual, google for sharp vcr manual download free from sharp website.
Aug 26, 2010 | Sharp VC-H952U VHS VCR
Setting up used VCR
did you check the channel select swith on the toshiba?
Sep 06, 2009 | Toshiba W612 VCR
Cant set clock or access menu using universal remote
Haven't found answer to that, but there is a remote contol specifically for your unit now on EBAY at http://cgi.ebay.com/SHARP-VCR-RRMCGO173AJSA-Remote-Control_W0QQitemZ350117240995QQcmdZViewItemQQptZLH_DefaultDomain_0?_trksid=p3286.m20.l1116. The whole thing is under $10 including shipping. If nothing else, copy the model # of the remote and you might be able to find it cheaper someplace else.
Dec 04, 2008 | Sharp VC-H973U VHS VCR
No remote
Check e-bay for SHARP RRMCG1236AJSA TV/VCR REMOTE
There are some for under $10 total
Jun 15, 2008 | Sharp VC-A410U VCR
How to set the tape lenght when recording
on older vcr's there should be a sp/slp or ep button on your remote or vcr. if not when you set a program to record, the option to choose should be there. sp= 2 hrs, ep =6 hrs.
wg
Feb 17, 2008 | Sharp VC-H810U VHS VCR
Sony SLV-D350P DVD/Video cassette Player
I have the manual. Are you trying to record something live? if so:
1) Turn on both the DVD/VCR and your TV.
2) Switch the input selector on your TV so that the signal from the player appears on the TV screen (this is usually something like 'input 1' or 'line 1' and so forth)
3) On your remote, set TV/DVD-VIDEO to DVD-Video, then press SELECT VIDEO to control the VCR. These buttons are at the upper left hand corner of the remote controller.
4) To record from a cable box, turn it on.
5) make sure the tape is longer than the total recording time.
6) insert a tape into the VCR.
7) press CH +/- on the remote to select the channel or line input video source to record.
8) select the tape speed SP/EP (SP provides better quality, EP provides three times the recording time as SP)
9) Press the record button to start recording. The VCR display will display the message REC.
Nov 25, 2007 | Sony SLV-D350P DVD Player/VCR
Sharp 13VT-R100 13 in. TV/VCR Combo Logo
133 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
