Question about Motorola Mobility W375 Cellular Phone
Motorola w375 I have just purchased a new phone ,i charged the battery up ,when i turned it on nothing happened.
  • Shabbir  Dole
    Shabbir Dole May 11, 2010
    Did you check that everything is properly setin their places????
THIS IS BECAUSE OF THE BATERYY PROBLEM IF YOU HAVE PURCHASED WITHIN 7 DAYS THEN ASK RETAILER TO ASK FOR DOA REPLACEMENT FROM WHERE HE PURCHASED IT.YOU WILL BE REPLACED WITH NEW SEALED BOX
Posted on Mar 30, 2008
I lost my drivers. it s not getting connected to pc
HOWTO_Connect How to connect Motorola W375 to a Windows computer Introduction¶ This document describes how to connect your Motorola W375 to your computer in order to use it as a modem, or to administer it with Motorola W375 Manager software.
Connecting¶ To connect your motorola W375, follow the next steps:
  • Download and uncompress Motorola W375 Driver from this site.
  • Connect your W375 to your computer with its lid closed.
(You can also connect the device with its lid open, and choose "not" when it asks for permission to connect as an storage device)
  • When Windows asks you for a driver, select Motorola W375 driver folder.
This way, the next time you connect your mobile phone closed, your computer will recognize it as a new communications port and you are ready to use it with Motorola W375 Manager. If you open this "COM" port with a terminal emulation software (i.e Windows Hiperterminal) and type "AT", the mobile phone will respond you with an "OK" string.
Using it with Motorola W375 Manager¶ To use your mobile with Motorola W375 Manager, simply connect your mobile phone closed and then, start Motorola W375 Manager software.
Using it as a modem¶ To use your mobile phone as a modem, install "Standard 19200 Modem" driver and select the communications port associated to your motorola W375.
About Motorola W375 driver¶ Motorola W375 driver is basically the same driver known as Motorola USB Charging Driver. You can download Motorola USB Charging driver from motorola US support web site for Motorola W375. If you try to use Motorola USB Charging driver directly with your Motorola W375, device type will not be recognized, but if you change device ID from "USB\VID_2811&PID_0702" to "USB\VID_22b8&PID_4061", this usb charging driver will become completely compatible with wour Motorola W375 mobile phone. The driver you can download from this site, is exactly a Motorola USB Charging driver with the mentioned modification.
Dec 07, 2010 | Motorola Mobility W375 Cellular Phone
Unable to charge motorola w375,need a solution
Check the contacts between phone and battery, if necessary align or clean. Are you using original Motorola charger? This solved my problem; I was trying to charge it with one of those "universal" chargers.
Hope this helps!
Feb 18, 2010 | Motorola Mobility W375 Cellular Phone
Wont charge
Usually when a rechargable  battery won't take a charge it need to be replaced.  I have had good luck purchasing replacement phone batteries on ebay but you can also try a local phone store or Radio Shack.  Its possible your charger is bad but it is usually a bad battery as they have a finite life where the chargers seem to work forever unless damaged by being dropped
Apr 25, 2009 | Motorola Mobility W375 Cellular Phone
Motorola W375 won't charge online!
You'll need pc charging drivers to charge your phone with a pc and a USB cable, you can get the driver at the motorola website.
hope this helps.
Mar 31, 2009 | Motorola Mobility W375 Cellular Phone
Lost the back cover of my phone
ya it will be available in all mobile accessories shop and u can purchase it...
 rate me
Jan 23, 2009 | Motorola Mobility W375 Cellular Phone
My motorola w375 will not charge suddenly
this can happen if the charger is drained internally or gets leaked due to over charge.also if the pins of the charger gets crooked or loose .also if the socket in the phone where you insert the charger if that socket of your phone is dirty it will stop charging.in that socket there is a round mettalic connector if that mettalic thing gets loose from the phone this can hasppen.also try changing the charger and check out first before taking the phone to the repair center. new charger caB BE AVAILABLE AT. www.radioshack.com websites/.
Jan 06, 2009 | Motorola Mobility W375 Cellular Phone
Battery charger conncection
the connector or charging pot of mot w375 have 5 wire connetions ,which connects the charger to the phone . if the connections are unsoldered the phone won't charge propaly , just resolder the wire connections it will start to charge propaly
Dec 06, 2008 | Motorola Mobility W375 Cellular Phone
Not charging
when battery cannot charge, try another battery. If it is still cannot, then the problem is the charging port is not working. Need to replace it.
Mar 18, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Motorola Mobility W375 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
