Pci simple cmmunication cntroller modem driver
I wish to know how can i get the subject matter
    President:
  • 2,351 Answers
Hi rajamke, that statement (PCI simple communication controller modem driver), means your modem is missing it's driver software. If you have a driver CD that came with the PC you should be able to find the driver. There will be more than one. You install the driver that matches your Windows version.
Have more questions, feel free to ask.
Good Luck!
Mike
Posted on Mar 30, 2008
SOURCE:
Pci simple communication controller
PCI Simple Communication Controller is a 56k PCI Modem, to know which exactly you have, use Unknown Device Identifier ( Download Here for free ), that will tell your the Model and Manufacturer, then Google for the drivers.
Sep 27, 2013 | Western Digital Computers & Internet
I cannot find the driver for my thinkcentre desktop pci simple communications controller. It's a p4 2.2ghz pc
Get onlineand got to www.google.com In the google search box type: "IBMSupport" or "Lenovo Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the Modem drivers and any other driver you need.
I think the pci simple is the modem or chipset driver.
Jun 03, 2012 | Computers & Internet
Hp nc6400 PCI Simple communication controller required please.....also unknown device driver???
The PCI simple communication controller is probably bluetooth or modem. Also install the Texas Instruments Media Card Reader driver. All the drivers for this model are (CLICK HERE)
Apr 18, 2011 | Computers & Internet
Drivers for pci simple communication controller for toshiba
Check out the Toshiba Support Site.
Select your Toshiba model to download the require drivers.
PCI simple communication controller - ie the 56K internal modem drivers.
Hope it helps.
Mar 23, 2011 | Computers & Internet
PCI Simple Communacation Controller
Hi, Thanks for using fixya.
Not to much information here but I'll try and guess.
Shows up in device manager: Right click on the line with the Yellow ! or ? choose uninstall then reboot the computer and new drivers will be searched for the network card or the modem. If you know the name of the network card and modem do a search for the drivers. If you can't get online search from a friend's computer save the drivers to a flash drive.
Hope this helps.
Terry
If you have any further questions regarding this matter feel free to post a comment or if you are satisfied with my answer, please give it a rating for this is the reason I do this work.
Feb 28, 2011 | Biostar K8M800-M7A Motherboard
Modem not detected
check your computer , the PCI device listing says simple comm controller. check your modem device manager see if its visable and not a question mark in the device manager
Jun 08, 2010 | Conexant chipset 56K V.92 PCI Data/Fax...
I cannot use internet for my modem driver has ? i need driver for pci simple communication controller. please help me.. so that i could use internet again. i'm using windows xp.
Look for the brand name of your modem and model. You can find it in the box of the modem. If you have it then go to there website in the internet and download there the driver.
Nov 29, 2009 | SimpleTech SimpleStation (STI-PNPR/PCI) PC...
HP Pavillion dv1000 running XP Pro SP2
Ok, the modem is a simple one. You need to manually install it. Right click on MY COMPUTER, PROPERTIES, HARDWARE, DEVICE MANAGER. Right click the PCI Communications error icon and click HAVE DISK. Scroll down and select the Lucent Win Modem and ignore any error messages and load that driver. You should be good to go. As for the audio, I'll have to send that to you via another account as gmail and sbcglobal doesn't allow the sending of EXE files. The subject line will read DV1000 sound driver.
Nov 18, 2008 | HP Pavilion dv6000z Notebook
PCI Simple Communications Controller
Hi, I have a solution. If you go in device manager, click on the pci simple communications controller, go in property and then go in details. You will see a code like per example PCI/VEN_8086&DEV_27D8&SUBSYS...
The VEN code means vendor and the DEV code means device: in my case the vendor is 8086 and the device is 27D8.
Once you have the two codes, go to www.pcidatabase.com. Enter the two codes and you should get the name of your
hardware. From there you can search for a driver download for your hardware.
In my case the pci simple communications controller was a Microsoft UAA Bus HD audio. I also had another pci
device that didn't work properly, using the same method I found out that my pci device was an HSF PCI internal modem with code number CX11252-11. I had a hard time downloading one of the drivers, after 6 or 7 times the download started so be patient if you have the same hardware
NOTE: to access the device manager, go in control panel, then performance and maintenance, system, hardware and finally device manager.
Hopefully this helps you, good luck.
Dec 07, 2007 | Gigabyte GA-7VT600 1394 Motherboard
Open Questions:
Computers & Internet Logo
434 people viewed this question
Ekse
Alun Cox
