Question about Samsung HC-R4755W 47" HDTV
Have you found a soultion?
I am having the same problem with my Samsung..any insight would be great!
I gave up. Repairman said it would cost $500 to fix.
I'm going to be buy a new TV instead.
Posted on Apr 02, 2008
Samsung c3011 white display jumper solution
samsung c3011 display white problam soultions
Jan 07, 2014 | Samsung Cell Phones
SE-084C Won't work on mac is there a soultion to this?
According to the samsung website the SE084C it can be used with a mac see http://www.samsung.com/ph/consumer/monitor-peripherals-printer/optical-disc-drive/dvd-rw-drive/SE-S084C/RSPN/index.idx?pagetype=prd_detail
Are you using it via a usb hub or is it plugged directly into the usb port of the mac. As it is powered via usb, on the hub it may not have enough power getting to it, so plug it directly into the usb port. If you already have it plugged into the usb port change the usb port and finally check that the usb cable is working, if it isn't change it. Hope this helps.
Jan 08, 2012 | Computers & Internet
Samsung model LN52A850S1FXZA powers on normal but has noticeable distortion on right side of screen and is slow to refresh. After 10-15 minutes the picture quality progressively gets better and eventually...
you should call the shop where you bought your television and try explaining your problem think they will be helpful and also you should try looking the solution online that will also help manual would be great if you had one but anyways best soultion is in the first one
I recommending registering to the best site for earning money online http://www.clixsense.com/?8516905 I recently found and please do that I you find me helpful hahah
GOOD LUCK
Jul 24, 2011 | Samsung LN52A850 52 in. LCD HDTV
Samsung RFG297AA Thin Film of Ice Forming Under Deli Drawer
My be an air leak,wipe/check all seals on doors and make sure doors are closing tight on seals.
Jul 24, 2017 | Samsung RF265AA Bottom Freezer French Door...
Samsung washing machine J1453. Error code 4E constantly recurring despite checking of water supply pressure and pipes/filters. Any suggestions?
Had a same fault code and also sometimes had the reverse kept filling - soultion was that the small flexible pipe up to the pressure sensor had a crack (fatigue mahine was only 1.5 years old) in it next to the sensor - found it by sucking and blowing down the pipe while it was not connected to the sensor (with the electric off ) - Replacment pipe can be found at any good local washing machine parts shop/store
Apr 27, 2008 | Samsung WF203ANW Front Load Washer
Charging camera
from theslug on nother thread. worked great for me.
"Hi,I just found a soultion on another website and it appears to have worked for me.Apparently the battery loses it memory when fully discharged,to fix this take a 9v battery and place the terminals + to + and - to - with the camera battery for 30 seconds or so then put the battery back in the camera and charge as normal.I just did this and it seems to be charging and the red light is solid.hope this helps."
Sep 26, 2007 | Casio EXILIM Card EX-S770 Digital Camera
Samsung HC-R4755W 47" HDTV Logo
37 people viewed this question
Henry  Thomas
Henry Thomas
