Question about Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool quiet wash plus
How do I clean it out
    Novelist:
  • 131 Answers
I assume you are having spray issues, or a grinding noise. If odor is your issue, go to the bottom of the message.
For the dishwasher pictured above, Open the door. Remove the lower rack.
Push in the tabs holding the upper basket rail end caps and slide the caps up and out. Remove the upper rack. Clean the holes in the upper (or middle) spray arm.
Hold the lower spray arm still and rotote the thumb tab clockwise. Remove the lower spray arm. Clean the holes in the lower spray arm.
Use a small flat screwdriver to release the tabs holding the upper spray tube from the dishwasher inner wall and ceiling. Rotate the spray tube to the right and remove the tube.
Using a # 20 Torx bit, remove the (about 10) small screws holding in the top of the sump assembly. Remove the top section with the fingers all around it.
Using a # 15 Torx bit, remove the screw holding the round cover over the pump suction. Remove the cover (grab the tab sticking off the corner with a pliers and pull up.)
Anything stuck in the sump will now be visible. If the screen is completely clogged up, then the blade isn't wiping the screen clean. In this case, the screen should be replaced.
The screen is removable, but difficult to re-install. If you need to re-place it, put an open end wrench between the screen and the rotating blade to hold the spring compressed. Also, notice the screen isn't round. The flat edges fit only in the slots they came from.
If it's odor or white powder you want to clean out, use a dishwasher cleaning product such as Dishwasher Magic.
I tell every dishwasher customer: "You do not need to rinse your dishes before washing. But you do need to scrape them off."
Posted on Mar 31, 2008
5 Suggested Answers
SOURCE: Whirlpool Quiet Wash Plus (927 Series) no longer turns on
water wont drain from dishwasher
Posted on Jan 29, 2010
SOURCE: Whirlpool Quiet Wash Plus Dishwasher
We were given a Whirlpool Quiet Wash Plus and it turns on but does not pump the water into the tub.
Posted on May 31, 2008
Speed boy
  • 76 Answers
SOURCE: whirlpool, quiet wash plus, dishwasher
You should see if the timer finished its cycle,some of them dont open till the cycle is comp.
Good luck.
Posted on Sep 09, 2008
WRMtech
  • 70 Answers
SOURCE: RUN TIME ON NORMAL WASH IS ABOUT 3 HOURS
common failures on that usually are the heating element. Look at the botton and see if it is broken anywhere.
Posted on Mar 22, 2009
What is the capacity of a front loading whirlpool washer MO#GHW9150PWO
Whirlpool GHW9150PW 27 Inch Duet Front-Load Washer with 3.8 Cu. Ft. Capacity, 8 Wash Cycles & Triple Dispenser.
whirlpool ghw9150pw0 capacity Google Search
Nov 25, 2017 | Whirlpool Washing Machines
Whirlpool 'quiet wash plus' top load washer
the washer is over filling because the float part is bad see the link below for details Whirlpool Dishwasher Overflows Replace Float W10345285
Jan 07, 2018 | Washing Machines
Whirlpool quiet wash plus dishwasher
Sounds like the timer module is going bad. Might be getting moisture on contacts. That would explain why it works one time and not the next.Just trying to help!
Aug 14, 2013 | Dishwashers
We have a whirlpool top loader (Gold ultimate care II quiet wash plus). After washing, clothes are stained with grease like spots. Do you have any idea what is causing this?
I am not an expert but I would guess it is your soap. perhaps try a different brand or maybe less.... I have not had this issue with mine but i did have the issue with my old washer and it was actually soap and not grease that caused the issues. I could be completely wrong, maybe you just need to run a cleaning cycle.
Jan 13, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
Hi. I have a Whirlpool Gold Ultimate Care II Quiet Wash plus top loader washing machine. Today as the water went in to rinse the wash it flooded out across the floor from underneath. Is there a filter I...
No problem with Filter.
Pressure switch is not working, it is not sensing the water level. There could be one more reason can cause this issue. Please check the Pressure HOSE whether is punchered or not.
Sep 16, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Quiet Wash Plus Dishwasher is not despensing the detergent properly. After a wash cycle there is still some left.
My Whirlpool Quiet Wash plus dishwasher seems to have died. No power. None of the buttons work, it quiet mid-cycle. No breaker issue, my garbage disposal runs off same breaker and is working fine. Any ideas? I was thinking the comp. board that the buttons work off of is fried. If this is the case any idea how much to replace it? Would it be cheaper to buy a new dishwasher?
Apr 21, 2008 | Dishwashers
Whirlpool GU2400XTP Built-in Dishwasher Logo
2,439 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
