Question about HP DeskJet 932c InkJet Printer
I have a Deskjet 932c and it won't print in color black and white is fine though. I just bought a new cartridge and is still doesn't print color. Is it shot??
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 295 Answers
I use a small diameter silicone tube tocarefully "prime" stubborn new carts by sucking a drop of ink out ofthe tiny print holes in the printhead part of the cart. Ink can dry at the headand since these carts work by electrical excitation, there needs to be liquidof each color at the holes. Slap a drop of water with your finger on the holesto start easy hesitant ones. Do not get the contacts wet.
Posted on Dec 08, 2010
2 Suggested Answers
pineworks
  • 4041 Answers
SOURCE: I have a Deskjet 932c and it won't print in color
Hi There
It will need a good clean.
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pinework
Posted on Mar 21, 2010
Testimonial: "Awesome advice, worked like a charm"
Printer will not print in color, only black. We just replaced the cartridges.
If its an HP inkjet printer you may have set it to print in black and white. To change this setting go to "control panel", then "printers and devices", right click on your printer, then "printing preferences", "advanced", then uncheck "print in greyscale"......Good luck !
Nov 03, 2012 | HP DeskJet 932c InkJet Printer
Installed new black cartridge in Deskjet 810C printer and after doing this it will only print in pink color. Please help.
Make certain that the cover is off the jets - if you forgot to pull the strip off or it broke leaving part of the tape on the cartridge, it won't work. Try to do a clean process on the cartridge. If that doesn't work, and you don't have another printer to try the cartridge in, return it to the place you bought it and get another new one. If the printer is printing pink, the color cartridge is probably empty also so that it cannot make black from the other colors. These sound like refilled cartridges - OEMs would have failed with some form of error code or warning.
Apr 11, 2011 | HP DeskJet 810c InkJet Printer
Color cartridge runs out even though I'm only printing b&w typed scripts. Any way to shut it off? Only have use for color printing once in a blue moon Hewlett Packard HP DeskJet Printer #932C
Even though you print a b/w document... unless you say 'black cartridge only' in your printing preferences, all the colors get used.
Find 'black cartridge only' in your printing preferences, or 'print in greyscale' and then print your document. You must specify this for your printer to know that it must use the black only.
Jul 23, 2010 | HP DeskJet 932c InkJet Printer
Hpdeskjet932c quit printing yellow & blue
Just try with replacing the color cartridges may be it is dry.
Sep 24, 2009 | Zebra 110Xi III Plus Thermal Printer
Hp 932 c prints from the color cartridge only
Was it working and now stopped working ?? If so, could be a faulty black cartridge. Remove the color cartridge and see if the black prints. if a new black cartridge, the strip may need to be removed or remove and reinsert black cartridge.
Jun 11, 2009 | HP DeskJet 932c InkJet Printer
My printer has an almost full black cartridge but will not print.
Check the ink lines, the printer head might be clogged, If thats not fixing anything then check your printer settings on the computer and remove the color option. Changing it to black and white can somtimes just be from color, not just black.
May 31, 2009 | HP DeskJet 932c InkJet Printer
Hp deskjet 932c does not print cartridge light keeps on blinking
First suggestion is to install a new cartridge. The #45 black and #78 color have a small circuit board that registers with the printer. That circuit board may not be doing its job.
Mar 22, 2009 | HP DeskJet 932c InkJet Printer
HP 932 RED LIGHT STAYS ON
The light you describe is the ink light.
When that light is blinking, try this.
Turn on the printer. Open the front cover and look at the carrier for the ink cartridges. There is a white arrow right above the latch for the color cartridge.
Once the carrier stops moving, the white arrow should be pointing to a symbol which represents the problem (the reason the light is blinking.) Examples are low ink black, low ink color, sick black ( replace ) , sick color ( replace ).
IF you have just replaced your black cartridge, you might need to replace your color cartridge too.
This printer will not work without both ink cartridges installed and full.
You cant print with a full black and an empty color cartridge unfortunately, even if you only want to print black.
Hope this helps!
Aug 27, 2008 | HP DeskJet 932c InkJet Printer
Not printing color
Loks like there is a "well" under the "docked" position of the heads (at the right end of the unit, facing it - under the control buttons.) In my unit, ink had built up in this well to the point that some of the mechanical bits were scraping the top of the built-up ink pile. After I carefully removed about two TootsieRoll's-worth of old dried ink with a long scewdriver (using a flashlight to illuminate the area), the color printing seemed to be doing better. Can't tell yet if this has completely resolved the problem, as I have not yet printed enough pages to prove the point...
Nov 05, 2007 | HP DeskJet 932c InkJet Printer
HP DeskJet 932c InkJet Printer Logo
99 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
