Question about Cateye Fitness Cateye Gamebike Exercise Bike
I need to replace the controller on bike. The
I need to replace the controller on bike. The wires got wrapped around pedal and were ripped out from controller
  • kimbraskids Sep 08, 2017
    This number I provided has been taken over by Spam Scam apparently Game Bike is no longer servicing their product or has changed numbers. KK
I have a 1 800 for the repair/service.
For the parts list it has the controller marked as #13 don't see any prices . 1800-872-1105 my manual is 3 years old not sure all still accurate.
Posted on Aug 20, 2010
The wires to my oxygen sensor that is located in
check your fuses. chances are ones blown at least
Aug 29, 2017 | Cars & Trucks
Volvo s80 t6 after putting my serpintine belt back on when i started the car a good size of the belt ripped of and wrapped around my harmonic balncer to the timming belt and shut my car right down
Did the piece of serpentine belt actually make contact with the timing belt ? The timing belt should have been behind the timing cover.
And does the engine crank normally ? Normal compression ?
Jan 24, 2014 | 1999 Volvo S80
The coaster brake on bike doesn't work, when pressing the pedal back, it just rotates and the brakes don't grab. What could the cause be?
Perhaps the torque arm is not attached to the chainstay. The torque are is a metal bar about 3 inches long X 1/2 inch wide, and the chainstay is the tube of the bike frame that runs from the pedals to the rear wheel hub. There is usually a little metal clip that wraps around the chainstay and is attached to the end of the torque arm with a small bolt.
Sep 02, 2012 | Electra Bicycle Company Rockabilly Boogy
Just installed the schwinn hitch rack 3 on the hitch of our vehicle. How to we fasten bicycles on rack? men'a AND women's bikes.
For the ladies model you need an adapter bar to make it like a mans model. , mens, you just set arms on the bike's top bar and bungee it or if it has straps use them. Make sure that your pedals do not scratch your trunk by either buying foam pedal blocks or wrap and tape them. Put the womans bike on first.
Oct 02, 2010 | Schwinn Cycling
Cord wrapped around unit while polishing and shut down. cannot restart
possibly ripped the wires from switch or broke the wires in the cord itself. You can go to Makitatools.com for a breakdown on this tool, but would have to guess at the above.
Aug 31, 2010 | Makita 7" 9227c Buffer Polisher Sander Kit...
Drove over something and ripped wires in front left of car- need the wires put back together
You may need to strip the wires and solder them back together, you should reroute the wires to where they will not do this again. Make sure to splice the wires well and wrap them with electrical tape. Also make sure you use the right gauge wire, 12 gauge or 14.
May 10, 2010 | Cars & Trucks
Orange wire at tranny wiring harness [hot] cant find where it goes
Wow, never heard oof this happening. Yes on the sensors , reverse lights, neutral safety switch, and shift speed . Good luck.
Jun 01, 2009 | 1999 GMC Safari
The tension adjustment does not get difficult enough
If you are refering to a regular bicycle this means the derailer is not making the chain jump from gear to gear. You probably need a new shifter cable or the shifter cable came unhooked from the derailer. I would take your bike to a bike shop to have this reconnected and then they will adjust it for you.
If you are refering to an exercise bike then here may be your solution. From what I have seen on exercise bikes there are three different kind of bikes. I am refering to how there resistance works.
First type has a strap that wraps around the wheel. There is a some kind of a nut and a bolt that holds that strap around the wheel. You simply need to tighten that nut. The strap will stretch over time and that is why you do not have the same resisteace you had when the bike was new. Afer you tighten this you will find that regular tensioner works better.
The Second type of exercise bike has what appears to be brake pads contacting the wheel. Basically your peddaling the bike with the brakes on. Pretty simple concept. Again there should be some sort of adjustment around this pad that is touching the wheel. Probably a screw or a bolt. Some even have adjusters that you can turn with your fingers.
The new and improved exercise bikes have what is called magnetic resistance. This is where your resitance is created by a magnet and some sort of power source such as batteries or your bike being plugged into a wall outlet. If you are using batteries replace them. I found that with my elyptical exerciser new batteries made a world of difference in the resistance settings. If changing the batteries doesn't help then there may be another problem. This could be the computer. Just check your user manual and I am sure you can get it replaced.
Mar 14, 2009 | Cycling
Need parts list for fisher price smart cycle
The child has wrapped the connector cords around one of the pedals of his Fisher Price Smart Cycle and it has completely severed the cord from the cycle. Is there replacement parts for this problem?
Feb 20, 2009 | Fisher Price Computers & Internet
Cateye Fitness Cateye Gamebike Exercise Bike Logo
588 people viewed this question
Top Cateye Fitness Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cateye Fitness Cycling Expert? Answer questions, earn points and help others
