Question about Maytag PAV2300 Top Load Washer
Washer made a funny noise, stopped working. I shut
Washer made a funny noise stopped working. I shut off the machine and tried to spin to empty tub but nothing works
  • Maytag Master
  • 43,501 Answers
Here is a tip that will help you with the not spinning or agitating problems....
Washing MachineWasher made a funny noise, stopped working. I shut - 2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
Posted on May 15, 2010
Samsung vrt front loading washer loud noises and not spinning
The washer tub has dampers to absorb this spin cycle vibration, your machine must have some broken dampers for the tub.
Oct 26, 2016 | Samsung Washing Machines
Whirlpool wtw5100sq0 clunks when put on spin cycle
Does the washer currently work fine aside from the loud clunking noise? Does the clunking noise continue or is it just one loud clunk when it starts to spin? If its just one loud clunk then that is not a problem just ignore it as that is the clutch spring releasing, it probably starting making noise from the grease getting washed off when the washer over filled.
However how did the washer overfill? That issue should be addressed too. Sometimes though, if the tub is not centered from a heavy load the water will spill over the back but its not really an overfill.
Mar 25, 2013 | Washing Machines
After 8 years of working well the machine vibrates violently. At slow speeds it is not too bad , as ithe spin rate picks up the machine seems to be trying to tear itself apart and I need to shut it down....
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Feb 15, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer motor makes lots of noise as its trying to spin. Hardly spins at all with wet load. Spins slowly and still makes noise when spinning with drum empty. Does this mean the motor is bad or is it the...
If it is a really loud noise that drives you out of the house then probably a bad bearing. If that is the case then time for a new machine. Also check for something caught between the tubs.
Dec 02, 2010 | Maytag MAH6700AWW Neptune Front-Load...
During spin cycle washer drum knock and seems as if it is out of balance, even when empty
"spider" broken. Cast aluminum bracket that attaches shaft to inner tub is coroded. Spin tub and shaft assembly cost approx $300 to replace. Heard that parts may have lifetime warranty.
Sep 03, 2010 | Frigidaire ATF6000ES Front Load Washer
Washer won't spin, but making funny noise and water drains
You have a broke motor coupling broken between the motor and transmission the part is not expencive but a little hard to explain how to put it in.
Mar 29, 2009 | Whirlpool Washing Machines
Washer continues to work even if water is not filled to top and even if i try to stop continues to spin
A defective pressure switch can interfere with the cycles that depend upon the switch to indicate when water has filled or emptied from the tub. It can also result in underfilling or overfilling of the tub. The switch routes current from the timer control to the temperature switch and the water inlet valve when the tub needs to be filled. Once full, the pressure switch cuts the current and reroutes it to the motor on the timer control to continue the cycle.
Dec 07, 2007 | GE WBSR3140DW Top Load Washer
Whirlpool top load washer
Check to be sure inner tub is not spinning freely on spin tube. It can be noisy when this happens. When it's spinning and stops it may continue spinning for a bit when this happens. You usually need to replace spin tube, because the tabs that key into drive block for inner tub break off. Also replace drive block.
Nov 08, 2007 | Washing Machines
LOCK AND LOAD ISSUE
can you be more specific about the funny noise. When does it occur, during agitation or during spin? something might me stuck in the drain area of the tub and as the tub rotates it rubs against it.
Jun 28, 2007 | GE WSXH208A Front Load Washer
Spin Cycle/Machine makes noise and moves
You can't tight up the tub. You should replace the damper pads that located beneath main support housing on base's machine. Goog luck !
Jan 15, 2007 | Crosley CAWC529JQ Top Load Washer
Maytag PAV2300 Top Load Washer Logo
165 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
