i have purchased a lenovo y510 laptop with following configurations:
processor: intel core 2 duo 1.66 ghz
ram: 1 gb
hard disk: hitachi 160 gb
tv tuner, web cam, realtek high definition audio
recoh multimedia card reader
os: windows vista home basic
my problem is that i have installed windows xp over vista by
formatting. but at lenovo site driver for this os as well as vista is
not available. however, lenovo did gave driver for vista cd but there
is no driver for windows xp. i have installed some driver for xp from
lenovo y410 site which is similar configuration. everything is fine but
only problem is that in device manager one device shows yello colour as
device not recognized. device shows : STK7700D.
Please suggest which device it refers and driver should i install for it.
-   i installed windows 7 and have about 5 or 6 drivers missing where can i get them
-   crackers6200
Apr 30, 2009
-   the same as mentioned above...i face the STK7700D problem-   chennai84
Apr 29, 2009
-   I have installed HP Laserjet p2106, earlier it was working alright, now when I connect using the same usb wire, it says "USB device malfunctioned", I changed the cable from the printer to the laptop, but still of no use, the wire is OK as it is working on other printer. There is only 1 yelloe triangle on the device manager list. Other device skt7700d Pls tell me what to do?-   ranjitsinghc
Mar 04, 2009
-   can't locate software driver for this hardware. if someone know can you tell me the address, please......-   aina_yve
Feb 19, 2009
-   my problem is that i have installed windows xp over vista by formatting. but at lenovo site driver for this os as well as vista is not available. however, lenovo did gave driver for vista cd but there is no driver for windows xp. i have installed some driver for xp from lenovo y410 site which is similar configuration. everything is fine but only problem is that in device manager one device shows yello colour as device not recognized. device shows : STK7700D.-   Guest
Here is the lenovo site for the drivers for you pc. Only download and install the xp driver versions...after which you should be able to update the drivers for the devices that have the yellow color and should not have any problems installing.
You can also check the windows update site...do a custom update and search for drivers...sometimes new driver versions can be downloaded that way.
cannot open CD room and cannot start computor to get into operationg system can get into BIOS area...
(More)
cannot open CD room and cannot start computor to get into operationg system can get into BIOS area but
My D600 does not respond when it is plugged in and charging. If I unplug it, it works fine. It...
(More)
My D600 does not respond when it is plugged in and charging. If I unplug it, it works fine. It charges completly. Any ideas?
I have a lot of interference when my laptop is on ac power when i use my headset and mic i have to...
(More)
I have a lot of interference when my laptop is on ac power when i use my headset and mic i have to go on battery ,,can anyone tell me if i can buy some thing that would help
