Question about Lexmark Wireless X4850 All-In-One Inkjet Printer
Lexmark printer x4850
Managed to set up a wireless connection with one laptop but cant do it with a second aswell, how can i get multiple computers to recognise the printer via wireless connection? it doesn't even turn up on my laptops printer search...can you help please?
Set up a wireless connection
Posted on May 24, 2008
My Lexmark x4850 has stopped prin?t the computer. What is wrongting . Sometimes it will print when I restar
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/lY7NTO. Select your operating system, download and execute the file. After the install process, try to print a document again to verify that the problem is fixed.
Oct 23, 2011 | Lexmark Wireless X4850 All-In-One Inkjet...
Wireless printer communication unavailable via USB
Hi. Hope you got it working fine now on your Windows 7. If not, go to Start Menu > Devices and Printers > right click on the Lexmark print object > Troubleshoot. Make sure the printer is on and is still connected to the computer via the usb cable.
Mar 12, 2010 | Lexmark Wireless X4850 All-In-One Inkjet...
I am running Vista Home 32 bit and have a Lexmark X4850. It will not communicate with the printer from either wireless or USB. I got it to print a test page from both, but that was one time after a...
Have you talked with Lexmark Technical Support? I suspect you may have to escalate this beyond level one. Vista on Mac is likely to have issues that differ from other Vista environments.
Sep 24, 2009 | Lexmark Wireless X4850 All-In-One Inkjet...
Can't connect wirelessly to a lexmark x4850
Try:
  1. write down the MAC address of your Lexmark,
  2. log into the router and reserve an IP address with that MAC
  3. Setup the Wireless parameters (SSID, Encryption to WPA or WPA2 Personal, assign a Pass Phrase you can remember. Then save the config and reset the router.
  4. on the Lexmark console, navigate to wireless settings and configure with the matching parameters as set in step 3.
  5. If the wireless connection is matched and connected, open up Internet Browser and type in the IP address in Step 2
  6. It should have a web-interface allowing you to customize it.
  7. Install the printer with the driver disc but should now look for a Networked option. or simply Add or Change the Port of your existing Printer's Properties.
Jun 15, 2009 | Lexmark X4270 All-In-One InkJet Printer
LexmarLk X4850 fax wireless set-up
Printing: since Lexmark say you can either connect wirelessly or wired and not both, you must either connect your daughter's machine to the hub by wire or yourself to the printer wirelessly.
Fax: this will need a phone line.
May 27, 2009 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X4850 wireless how to make it find the wireless network. I've had this printer working with my Vista laptop till recently; then I moved to another area, configured my new home network and Internet...
If the printer itself is wireless, it does not need to recognize your wireless computer network. Call Lexmark to walk you through proper installation. Lexmark's manuals are not adequate regarding setup, in my opinion.
May 07, 2009 | Lexmark Wireless X4850 All-In-One Inkjet...
Lexmark x4850 ink levels won't reset with new cartridge
Hi...
Silly question, but I have done this myself. Have you removed the tape from the bottom of the cartridge?
Jan 25, 2009 | Lexmark Wireless X4850 All-In-One Inkjet...
Lexmark X4850 Wireless wont connect
Had a similar problem with my router, which was a 2WIRE router (furnished by AT&T - I have Uverse). Fixed it by going to the router's GUI (mine is 192.168.1.254), click on "View the home network". On the right side of the resulting screen, there is a section titled "wireless settings". Under that, click on "edit settings". Enter the login information (the default password is on a tag on the router). The next screen is "Configure the Wireless Network". Scroll down to the bottom and click on "Rescan". When I did this, my X4850 miraculously connected and started working.
Rick from Austin
Aug 16, 2008 | Lexmark Wireless X4850 All-In-One Inkjet...
Fax issues
Thanks for the response! I managed to do this myself,I was not aware that your PC must have a "phone modem" card! Once I installed one I already had on hand, it went flawlessly! Windows XP likes this printer!!! Nice "all in one" printer,for sure. I used the Lexmark to replace our Epson scanner and seperate printer, AND our clunky old fax mach. Thanks for such a helpful website. Regards, Jim
May 30, 2008 | Lexmark Wireless X4850 All-In-One Inkjet...
Lexmark X4850 wireless set-up
I have a Lexmark X4850, every time I print a job it prints a blank page first then the document. I have tried to tell it to print 1-1 or 1-3 but it continues to print that blank page first. any suggestions.
Oct 05, 2007 | Lexmark X4270 All-In-One InkJet Printer
Lexmark Wireless X4850 All-In-One Inkjet Printer Logo
129 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
