Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
Data loss Hi , My Sandisk 2GB Cruzer was detected in windows XP initially and I was able to detect all the data I have.And the US3 software was also detected .. I just made a cut and paste to download the data onto my desktop but it was not pasted correctly.And after that the Pen drive is detected in my system.But I am not able to find the data that was not pasted onto my desktop.Also the US3 software is not there any more. How to retrieve my data as the data are very much presious.
  • 1,006 Answers
Download this program then you can recover data with it!
Download
Posted on Mar 30, 2008
Describe your 2GB Cruzer Micro USB Flash Drive (SDCZ62048A10) Hard Drive Problem my cruzer data loss
For SanDisk flash drive to save the data, use software, U3 Launchpad. This program is used to saved data, repair damaged firmware, and firmware updates.
If you use the operating system
Win XP, download the software from here SanDisk Support
Win 7, download the software from here SanDisk Support
Hope it helps
Sep 17, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Not open the memory card the computerslove probleam
If the flash drive is detected but error, there has been damage to the partition table or firmware. But, if the flash drive is not detected, there has been a hardware damage.
Solutions, flash drive detected but error
To fix the SanDisk flash drive, use the U3 LaunchPad software. This software can be used to saved data, repair the firmware and update the firmware.
For Win Xp, download from here SanDisk Support
To Win 7, download from here SanDisk Support
Solutions, flash drive not detected
Chances are, there has been cracked solder. To fix this, open the flash drive casing, use a soldering iron to heat the solder component flash drive.
Hope it helps
Sep 10, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk Cruzer Blade is not showing data. The drive shows up in 'My Computer' but data is not showing.
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this program to recover your files.
http://www.asoftech.com/adr/
Aug 31, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My scan disk was working properly untill yesterday... now i insert the disk to system... pendrive is not detected light also not coming.....
Looks like your pendrive is dead.
But before drawing to this conclusion, obviously try it on another computer.
If you have important information there are companies dedicated on retrieving loss data.
God Bless You!
Feb 05, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB Cruzer Micro USB Flash Drive Hard Drive is not working,but the light is blinking.my pc could not detect it,why it is so
If it is a windows xp, can be somethig with OS. Try with some other computers onn Windows 7. Not working then also???? Its damaged!
Aug 08, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My black 2GB cruzer is not being recognized by any PC anymore....how doi fix it to where my files in there dont get deleted?
HI:
Unfortunely there is no way of getting the data from this device, I also had the same problem with Cruzer Flash drive, According to SanDisk tech support the memory chip has failed in the unit, windows will not detect the unit if the memory chip is faulty, because it does'nt see any memory to add as a drive. This is why it is not always wise to rely on a certain device to store files, Always backup your flash drives to your Harddisk drive or CD which is better to protect you data in the future. GOOD LUCK!
Dec 15, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Pendrive is not Detecting by any System
some times is not recoved the data also virus is afeted so please go to copmuter repar shoop and they will do the need full to you
Jul 16, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Cruzer micro 4GB can't be accessed
http://files.filefront.com/LLFsetup2361181exe/;7310930;/fileinfo.html
This software will low level format your drive back to factory settings.Just like when you first got it. If your machine racognizes the drive but you get an I/O error this is the fix. GOOD LUCK !
May 24, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk flash drive
Strange... Vista does seem to have a problem with everything Sandisk...
Anyway, this should be all you need:
Launchpad Installer
Launchpad Uninstaller
Mar 19, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Can't detect my scandisk cruzer micro
hi mate, what os are you using on your notebook
it it in't xp its a driver problem, not your sandisk 2gb card
here are the specs for it,
  • Retractable USB connector
  • Brilliant amber LED
  • U3 smart enabled
  • Loaded with the following U3 programs
    - CruzerSync synchronization software
    - SignupShield password manager
    - SKYPE "Make video calls from PC to PC"
    - AVAST antivirus software
  • Hi-Speed USB 2.0 certified (backwards compatible with all USB 1.1 ports)
  • Compatible with Windows 2000, SP4 and XP*
  • Certified Windows 2000 and XP*
  • upgrade your notebook to xp
    Nov 05, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
    SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
    123 people viewed this question
    Top SanDisk Computers & Internet Experts
    Arora Singh
    Arora Singh
    Sandy Moore
    Sandy Moore
    Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
