Question about Oster 6804 16 Speed Blender
Blown fuse! I managed to blow the fuse. The only fuse number I've been able to find is 5S5A125V. Can anyone recommend a common (Littlefuse, Buss, Cooper) replacement? Duane
I found the answer with a bit more research on the Internet. The replacement fuse is GMA-5ABC5, available at Lowe's or Home Depot.
Duane
Posted on Apr 01, 2008
How to repair motor
If the motor is running then the fault must be with either the clutch on top of the motor or the blade clutch it engages with.
Aug 30, 2014 | Breville BBL600XL. 5-Speed Blender
I Need to Remove Fan from a Breville BBL600XL blender. I believe the fuse has blown -- I can get everything off but the fan... please, if anyone has done this -- how do I remove the fan so I can open it...
Hold the fan still and then turn the top and it will start to loosen the bolt you can see on the fan.
Side Note: If you need to remove the bottom completely then you also have to remove the screws hidden under the rubber feet.
Jun 05, 2011 | Breville BBL600XL. 5-Speed Blender
My cuisinart blender doesn't work. We've only used it about 4 times. It worked yesterday, and today it lights up but doesn't do anything. Not sure why
Pretty much that is what happened to me. I found that the motor has 2 "thermal cut-offs" (SEFUSE 113oC). If the motor heats up even a little, these babies kill your blender. They are thermal fuses. Once they blow, it is over until they are replaced. To fix this, the motor must be removed. The spline gismo on top of the blender unscrews with reversed threads. I suggest unsoldering the lead wires from the power supply board, and replacing when done. The cut-offs are inside the taped on white cloth insulation on the top of the field magnets near the brush assemblies on both sides. I replaced them (both were blown) with 2 of NTE8242 ($1.60 each, 240oC 15A). These are way too hot, but that is what I had on hand. I thought that the electronics were defective at first, and I replaced the entire board assembly with a small/cheap ceiling fan wall switch /speed controller from the hardware store (600W 5A) for $10. The root cause of all of this is that the motor fan is not working. The airflow is blocked by base. I put small extenders on the feet and now there is much more airflow. Only time will tell if this is an effective fix. It appears to me that the device my have started out "nice" when it was designed, but cheapened (probably by middle managers taking bonuses for "improving" the design) many times. The fuse is gone, the case is plastic, etc. It really makes me wonder how it got past UL approval.
Aug 03, 2010 | Cuisinart BFP-10 7-Speed Blender
Fuse has blown and i replaced it under the top cover left hand side but it blew again 6.3amp,it does work with a higher rated fuse any ideas
Did you check to see if the original fuse was a slow blow version.
If you replace it with a normal or fast blow the start current could pop it
Other problem could be a developing problem on the heaters which as causing the current draw to rise
For that your need a megger to check for resistance through the machine or a PAT test should show it up
Nov 05, 2009 | Blenders
Breville 600XL not turning on
My BBL600XL stopped working because of a blown fuse. You need to remove the phillips and torx head screws out of the bottom. Then remove the base. There you will clearly see a fuse on the circuit board.
It appears to be a 10A 250V fuse.
Jan 28, 2009 | Breville BBL600XL. 5-Speed Blender
No power beyound the touch pannel
I managed to fix my Cuisinart SmartPower Duet blender. I had the same problem, lights and buttons work, but no motor action. There are two thermal fuses, one tape attached to each stator winding. Both of mine were blown.
In addition, when the fuses blew, it must have spiked the triac. I had to replace mine. It's the black 3-legged transistor looking device with a small metal heatsink attached to it. This gizmo directly throttles the power to the motor under control of the microprocessor. There are some guides on the internet on how to test it.
Also, the clutch was very hard to remove and needs to be removed to more easily replace the thermal fuses. I clamped down the end of the motor shaft to a bench vise real hard and then I used a 7/8-inch open-end wrench to wedge into the clutch prongs which made it much easier to apply torque. Remember that its screw threads are reversed from normal screws so that it does not unscrew during operation. You have to turn it counter-clockwise to unthread it.
It took about 1-1/2 hours and definitely needs to be done by someone who knows their way around electronics. Hope that helps!
-Vince
Aug 24, 2008 | Cuisinart SPB-7 SmartPower Work Top...
Received the Breville Ikon 600 blender as a Christmas present in 2006 and have used it 3 times, with the third time being this past weekend. The product is now out of warranty and low and behold, it...
My IKON 600 Blender fuse had blown. It was located on the circuit board and can be found by removing the bottom of the blender. Fuse is Fast Blow 10A, metric 5mmx20mm. The fuse blew because the bearing in the bse of the jar froze. Bearing # 608-RS. The beraring froze because the seal in the base of the jar was leaking. Solution: Clean seak surfaces, replace bearing and fuse. Total cost of $6 with my labor.
Apr 16, 2008 | Breville CBL10 BlendMaster Classic Work...
Can't get my back to basics blender opened
I removed the motor coupling and after troubleshooting the blender found that the thermal fuse was blown. I think Radio Shack might have the fuse I need if not I know an online site that definitely does.
Mar 17, 2008 | Back to Basics Blender Solution 5500...
Oster 6804 16 Speed Blender Logo
909 people viewed this question
Top Oster Blenders Experts
Dan Webster
Dan Webster
Dave
Dave
Angel Joseph Jr.
Angel Joseph Jr.
Are you an Oster Blender Expert? Answer questions, earn points and help others
