Question about Whirlpool Calypso GVW9959K Top Load Washer
Just replaced the motor and pump, 3 weeks ago.
Just replaced the motor and pump 3 weeks ago. Now I am getting an ld and then an fl?? Calypso Kenmore washer Elite
  • 15,935 Answers
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$
Posted on Sep 21, 2010
Both the coupler and the lid switch have been replaced yet unless you lift and close the lid it won't engage the spin cycle
Search Results
    Why am I getting an FL error code on a Kenmore Calypso ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kenmore Calypso washer model 11022062100 and there is water in ... Why am I getting an FL error code on a Kenmore Calypso washing Machine?
    fl error code on calypso washer-need help!! - Home Forumsths.gardenweb.com > Home Forums > Laundry RoomJul 22, 2006 - An FL error code keeps flashing on my Calypso Washing Machine. I can't do laundry. Could someone please tell me what I need to do to ..."F dl" light come on - Kenmore Elite HE3 Washing Machinehttps://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock Error... The Kenmore Elite HE3 is a washing machine by Kenmore. ... On Amazon I was able to get the CCU (Kenmore CCU Central Control Unit .... and a dose of WD40 on those contacts should keep that from misbehaving in the future as well.Kenmore Elite Calypso FL error code - ApplianceBlog
Jan 27, 2016 | Washing Machines
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
Kenmore elite washing machine with calypso - cycle ended with water in tub after partial wash of 3 towels, signnal was LD - re-started machine and it stopped with signal FL - machine will not re-start
Fl stands for flooded. Either your pressure switch is bad or plugged in the tubing from the tub to control panel or the sensor is bad. But check and make sure the water is draining or pumping out like it should, if not the problem may lie in your drain pump or hose.
Mar 13, 2011 | Kenmore Washing Machines
I GET THE FL DISPLY ON MY KENMORE ELITE CALYPSO WASH MOTION. HOW CAN I REMOVE THAT SO IT CAN START WORKING AGAIN
unplug your washer for 5 minutes and try it...these washers are known to have pump issues..if its older one..the pump can be replaced...if its newer..the motor/ pump has to be bought and replaced...
Jan 22, 2011 | Kenmore Washing Machines
Error Code FL
The FL (Over Fill) error code indicates that the flood pressure switch is open (tripped). It is likely that you are getting the LD (Long Drain) fault code because the control detects that the flood pressure switch will not reset after running the drain pump. Your likely failure is in the flood pressure switch
Tapping on the flood pressure switch with the handle of a screw driver may reset it. Reassemble the washer and see if it will work properly. If not, then you will need to replace the flood pressure switch. The part number for the flood pressure switch is 8054767. You can order this part from the Sears PartsDirect website. The part number for the flood pressure switch is 8054767.
Jul 28, 2010 | Kenmore Washing Machines
Just replaced the motor and pump, 3 weeks ago. Now I am getting an ld and then an FL?? Calypso Kenmore washer Elite
Flood Condition:
Mar 21, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso: LD error message
hi replace the hall sensor... this will remove ur LD error code...
thank u
rate me!!
May 24, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
FL code on a Kenmore Calypso top loader
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$#@!
Jan 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
90 people viewed this question
Dan Webster
Dan Webster
Sal De
