Question about Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher
I have a Whirlpool GU1500XTLS2 dishwasher that worked just fine on noemal cycle the other day. Now none of the cycle keys will work except the cancel key which starts a 2 minute countdown and you can hear the motor running. After the countdown ends the other keys still won't work. Please help!
DID you get a solution?
Posted on May 29, 2010
ALARM
reset the panel by hitting normal-- heat dry NOT at the same time until all lights flash then push cancel and it should start. this resets the controller.
Apr 01, 2014 | Whirlpool 24 in. ADG7540 Built-in...
AS PER DIRECTIONS FROM TECH, I PURCHASED AND INSTALLED A NEW CONTROL UNIT. THIS WAS BECAUSE MY WHIRLPOOL DISHWASHER GOLD GU2300XTLB3 QUIT WORKING IN ALL CYCLES EXCEPT SHORT CYCLE. PUT EVERYTHING BACK...
This is a common problem with Whirlpool washers.If the clean light is the one flashing then your dishwasher could have a heater circuit problem (depending on the age) or this could simply just be water colder than it is used to getting.
Repeatedly press the Heated Dry and Hi-Temp Wash(scrub) which ever yours has until all the LED lights come on, press cancel twice and try the dishwasher again making sure to run the water at the kitchen sink till it is hot before starting the dishwasher, if this trips and locks you have a problem with the heating element, or temp sensor.
Press the heated dry button followed by the normal cycle button, and then repeat once. You should see all of the lights come on for a second or two, and then the dishwasher will work again.
If you haven't already, take a look under the kick plate in front to see if there is a schematic tucked in there somewhere. Whirlpool has put their diagnostics for specific models on these.
I don't have the specific repair manual for you model.
So, if the above combination does not work here are two more that have worked for me.
HiTemp Wash + Air Dry + HiTemp Wash + Air Dry in less than 5 sec
or
Hi Temp Scrub/Scour + Air Dry + Hi Temp Scrub/Scour + Air Dry in less than 5 sec
Let me know, if you need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 01, 2010 | Dishwashers
No button will work except "cancel" button on model # GU1500XTLS1 Have tried all suggested troubleshooting tips in manual
I have the same problem. The only temporary solution I have so far is to turn off the circuit breaker and wait between 10 & 30 minutes before resetting the breaker. The the dishwasher will work for one cycle.
Aug 27, 2009 | Whirlpool 24 in. GU1500XTLS Stainless...
Kitchen Aid dishwasher will not start
Can not start KitchenAid dishwasher..."child lock" light keeps coming on. Help!
Aug 24, 2009 | KitchenAid Dishwashers
Whirlpool dishwasher gu1500xtls2
HI, this is a control fault and you can confirm failure by shutting off the breaker switch or unplugging for 5 minutes. if the unit continues to malfunction after the 5 minute reset, you will need to replace the electronic control board.
Electronic Control board part number----8534866
May 20, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool Dishwasher won't drain during normal cycle
As you say a clogged line or valve does not make sense.
Try running it without the heated drying and see if it empties or if the cancel button will work then.
The dishes should air dry quickly if you empty it and open the door.
It could be a defective thermostat allowing it to get too hot during the heat cycle
May 18, 2009 | Dishwashers
I have a whirlpool Dishwasher and it will not turn on?
keep the start button pressed in - the machine will empty out the water and cancel the cycle....then start over again.
Jan 07, 2009 | Whirlpool 24 in. DU948PWPQ Built-in...
Whirlpool Gold Quiet Wash Plus GU940SCGZ3
Press the cancel button, Then cut power to the dishwasher for a period of time. restore power to it then try a cycle.
Jul 27, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Cycles won't run
dc, sounds more like a shorted interface, a shorted keypad will act like this. There should be a tech sheet behind the toe panel on the bottom. It should have instructions on how to test the keypad and put the unit into the test cycle. Catriver..post back.
Nov 14, 2006 | Whirlpool GU1100XTLB / GU1100XTLQ /...
Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher Logo
285 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
