Question about Kicker CVR12 Car Subwoofer
Why is there 4 termanals on the back of my speaker
    Problem Solver:
  • 18 Answers
It is a dual voice coil subwoofer.
Posted on May 21, 2010
  • 33 Answers
Your Comp VR12 Subwoofer is a DVC (Dual Voice Coil) Sub. Depending on exactly which model you have it can be used in 4 possible ways.
1 Ohm Load
2 Ohm Load
4 Ohm Load
8 Ohm Load
Without the full model number I can't tell you which you have.
Posted on Apr 14, 2011
Need help finding out which termanals are which on my audiobahn subwoofer
Touch a 9v battery to the speaker terminals for a second. If the speaker cone pops outward, note the polarity of the battery terminals. The + was on the + side of the speaker and - on the - side. If the speaker popped inward it's the opposite.
Aug 10, 2014 | Car Audio & Video
My right speaker isn't working...
If you hook what is now the left speaker does it work on the right hand channel? If not the cable to it is defective or the connections or the Amplifier is defective.
May 03, 2014 | Harman Kardon Audio Players & Recorders
Which side is positive on a ts a1365 speaker?
Take a 9 volt battery, 0r Evan a 1,.5 volt battery will work, Hook up to the termanals on the speaker ,When the cone draws in ward you no you have it hook up right,
Dec 05, 2012 | Pioneer TS-A1365 Car Subwoofer
Negative and positive termanals not marked on speaker for instqllation does it matter?
It matters. Get a 9-volt battery and touch it to the terminals. When the positive side of the 9-volt is connected to the positive speaker terminal, the cone will pop out. If it pops in, then the positive side of the battery is touching the negative speaker terminal.
NOTE: A subwoofer should be strong enough to handle this. If you try this with a small speaker you can damage it!
Nov 08, 2010 | Pyle (PLBW124) Car Subwoofer
I have a 5 ton air conditioner made by international comfort corporation, it bears the model number PAB036N1LA and I need to know what the diagram is to hook up the thermostat. its a commercial rooftop...
on the unit it should have low voltage termanals labled R Y G H H2 the R termanal goes to the t-stat on the r termanal and the y to y on the t stat ang g to the g on the t stat and H termanal goes to h on the t stat etc if thers no termanal block find the low voltage wires and get back with me on the collors
Apr 04, 2010 | Heating & Cooling
Because your speaker has two voice coils to increase power handling and also so you can either series or parallel them to change impedance.
Usually there are two 8 ohm or two 4 ohm coils in those speakers so you can either double by making them series or half by making them parallel.
Two 4 ohm coils in parallel will drop the impedance to 2 ohms.
Make sure your amp is rated for it or you risk damaging it.
Mar 21, 2010 | Kicker CVR12 Car Subwoofer
Receiver shuts off when you turn up the volume.
your safety overload circuit is kicking in and prenting the amp from shorting. you have a bad speaker most likely or horn. try operation it with headphones next. try bookshelf speakers at a moderate level to test if it persists then the amp has a biggger problem.
Dec 08, 2008 | Pioneer VSX-815-K Receiver
2006 chevy uplander rear speakers
look at the speaker directly where the wires connect, there should be a tiny + and - near each wire is connected. or a red dot for the positive side. if the wires have termanals on them, they usually will only fit on one the right mate on the speaker.
Nov 27, 2008 | 2006 Chevrolet Uplander
Instaling a wall thermosstat RTH11/RTH221, the old thermosstat has a yellow wire and a red wire from the wall, Ware do i conect the red wire? on the G-termanal the Rh termanal or W Termanal? Also how do...
RED TO RED YELLOW TO WHITE
If you have a OHM meter, you can test it first to find out which one is neutral wire ( same as white wire position) before you connect the wire, usually red wire or black wire are hot wire.
Jul 06, 2008 | Heating & Cooling
Melted speaker wire
Whats the size of the wire? If they are too small they will melt and even catch on fire. Let me know.
Nov 01, 2007 | Rockford Fosgate 800.2 Car Audio Amplifier
Kicker CVR12 Car Subwoofer Logo
196 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
